need help on setup of qtvcp
25 May 2019 11:29 #134886
by Reinhard
need help on setup of qtvcp was created by Reinhard
I tried to follow linuxcnc.org/docs/devel/html/gui/qtvcp.html
but I already fail on section 2.2 ...
(designer starts and qtvcp -h shows help screen)
The last sentence does not match my system (debian stretch)
I don't have a directory named .scripts and I could not find a file called rip-enviroment all over the system.open a terminal, set the environment for linuxcnc . scripts/rip-environment
then load designer with : designer -qt=5
25 May 2019 14:30 #134896
by pl7i92
Replied by pl7i92 on topic need help on setup of qtvcp
the side you foloow is only for the Master at github to be selfcompilt
so you do not need the rip-envirewrment
as ypu installd latest stretch ypou shoudt alredy< have the QTvcp invirerment
25 May 2019 14:37 #134899
by Reinhard
Replied by Reinhard on topic need help on setup of qtvcp
Hm, that's only partially true.
I can start the programs, but the qt-designer does not know anything about linuxcnc.
So I need a bridge to close the gap
25 May 2019 19:20 #134918
Replied by cmorley on topic need help on setup of qtvcp
yes sorry the directions are incomplete...
in usr/lib/x86_64-linux-gnu/qt5/plugins/designer/python
add a link to qtvcp_plugin.py:
On a RIP linuxcnc it would be something like:
(home name and linuxcnc project name may be different for you)
/home/chris/emc-dev/lib/python/qtvcp/plugins/qtvcp_plugin.py
I'll have to look up wher it would be on an installed version...
Chris M
Chris M
25 May 2019 20:34 #134924
on an installed version look in :
/usr/lib/python2.7/qtvcp/plugins/qtvcp_plugin.py
It's an educated guess - I have no installed versions of linuxcnc available to look in.
Chris M
Chris M
- Thank you received: 5945
25 May 2019 21:17 #134929
Replied by tommylight on topic need help on setup of qtvcp
Chris M
26 May 2019 03:13 #134949
by Reinhard
When I know, how things should be, I can search on my own.
On my system, /usr/lib/x86_64-linux-gnu/qt5/plugins/designer contains only compiled shared libs - no directory python.
I tried both: linking qtvcp_plugin.py directly and creating a subdirectory python and put the link there ...
No change - the designer keeps on ignoring linuxcnc.
by the way - i found qtvcp_plugin.py in /usr/lib/python2.7/dist-packages/qtvcp/plugins/qtvcp_plugin.py
May be searchpath of designer is different for shared libs and python modules?
This kind of advice is better than in the tutorial.in usr/lib/x86_64-linux-gnu/qt5/plugins/designer/python
26 May 2019 04:07 #134950
by Reinhard
Here some more info:
When I create the python directory at usr/lib/x86_64-linux-gnu/qt5/plugins/designer and put a link to usr/lib/python2.7/dist-packages/qtvcp/plugins/qtvcp_plugin.py inside that directory, designer comes up with the messages from file logFirst.txt
... so I checked installation:
and indeed - python-pyqt5.qtsvg is not installed.
So I installed that module ...
...and now designer crashes at start with messages from logSecond.txt
ii python-pyside.qtsvg 1.2.2-2+b1 amd64 Qt 4 SVG module - Python bindings
ii python3-pyqt5.qtsvg 5.7+dfsg-5 amd64 Python 3 bindings for Qt5's SVG module
ii python-pyqt5.qtsvg 5.7+dfsg-5 amd64 Python 2 bindings for Qt5's SVG module
26 May 2019 04:27 #134953
Yes I pushed an update to the docs - I'm sure I'll have to update them again when we figure this out.
yes /usr/lib/x86_64-linux-gnu/qt5/plugins/designer/python is the right directory - you may have to add the python folder.
yes the link should be to /usr/lib/python2.7/dist-packages/qtvcp/plugins/qtvcp_plugin.py
next you have copied the libpyqt5_py2.so file into /usr/lib/x86_64-linux-gnu/qt5/plugins/designer ?
and is it the right version - looks like 5.7?
running from the terminal may give some error messages (if you are not already)
python.pyqt5 versions of libraries is what you need.
What distribution are you using?
SVG library _should_ not actually be necessary - just one widget is not available (but I haven't confirmed recently if it would cause a designer error - but it would give an error message in the terminal)
Chris M
Chris M
26 May 2019 04:28 - 26 May 2019 04:29 #134954
Duplicate
Last edit: 26 May 2019 04:29 by cmorley. Reason: duplicate
Time to create page: 0.202 seconds
