need help on setup of qtvcp
26 May 2019 05:31 #134966
by Reinhard
Replied by Reinhard on topic need help on setup of qtvcp
As the library was already in place, I did not copy anything. See attachment
Library in place matched the lib from 5.7 in size
Anyway - I copied the lib over the existing now - and that did not change anything respect to designer.
26 May 2019 05:34 #134968
by Reinhard
Just an idea: is the search path to the widgets coded in the library?
May be that path is different or not existant on my system?
26 May 2019 05:34 #134969
Replied by cmorley on topic need help on setup of qtvcp
Well I'm confused then. No distribution supplies that library. either you compile it your self or u copy the precompiled version we supply.
Anything else will be the wrong version.
26 May 2019 05:36 #134970
search path in library searches:
/usr/lib/x86_64-linux-gnu/qt5/plugins/designer/python
or
~/.designer/plugins/python
and we create a link to where ever out library actually is
Chris M
or
Chris M
26 May 2019 05:39 #134971
So what does it say in the terminal now when you load designer?
26 May 2019 05:40 #134972
by Reinhard
I beg your pardon, but I can't remember, what I did last year ...
Usually I use prefix /usr/local for selfcompiled experiments ...
No, I don't refer to search path of shared libs, but python search path to python widgetssearch path in library searches
26 May 2019 05:42 #134973
by Reinhard
I already mentioned: no change at all.So what does it say in the terminal now when you load designer?
26 May 2019 05:49 #134974
Ok just so I'm on the same page:
you have copied over the 5.7 version (from linuxcnc) of libpyqt5_py2.so
to /usr/lib/x86_64-linux-gnu/qt5/plugins/designer
you have a link called qtvcp_plugin.py that points to the same named file in
usr/lib/python2.7/dist-packages/qtvcp/plugins/qtvcp_plugin.py
Chris M
Chris M
26 May 2019 06:07 #134975
by Reinhard
I would say yes - but look at attached file
26 May 2019 06:19 #134976
Here is how Kurt builds the library:
gist.github.com/KurtJacobson/34a2e45ea2227ba58702fc1cb0372c40
I see he sets the path for the library with:
export PYQTDESIGNERPATH='/path/to/plugin/directory/'
But that should not be necessary - but I'm running out of ideas.
Chris M
Chris M
Time to create page: 0.370 seconds
