need help on setup of qtvcp
30 May 2019 03:55 #135348
Replied by cmorley on topic need help on setup of qtvcp
I'm glad you found gladevcp to work for you.
What do you mean? Gladevcp and qtvcp work very much the same.
Chris M
I searched a lot and I came up in reading docs for the qt-designer - but then I had to stop myself. That's nothing I wonna do. So may be qt is not the right tool for me.
Cheers Reinhard
Chris M
30 May 2019 04:17 #135350
by Reinhard
The point is, I don't get the qt-designer to show linuxcnc-widgets or run without crash
So the tool is not a tool but a work preventing system like windoz
The glade designer shows linuxcnc widgets at first run - so it is really a tool that might be useful
I don't wont to bother with tools but only use them. They should help me
... at least in my opinion.
So I try the glade way ...
Replied by Reinhard on topic need help on setup of qtvcp
Well, they should - if everything works fineWhat do you mean? Gladevcp and qtvcp work very much the same.
Time to create page: 0.244 seconds
