writing chip conveyor component , user input wanted
- smc.collins
- Thank you received: 109
23 Feb 2024 12:51 #294075
by smc.collins
writing chip conveyor component , user input wanted was created by smc.collins
I am writing a conveyor component, it'll have some basic features, a sensor input to see if the conveyor is moving, estop out, washdown turn on output , after spindle off feature and a few other little basic items. Anyone think of any other features that would be nice to have ? what prompted this, my conveyor jammed while i was letting the machine run un-attened, the motor performed a spectacular smoke show.
basic configuration
Spindle enable start conveyor
Hall effect sensor is a deadman switch that is reset every time the trigger passes by the sensor " chain whell in my case"
After run timer, to run conveyor after the spindle is turned off " to clear chip bed and hal adjustable"
Washdown output with timer " setup a washdown pump and chip wash system " to clear swarf around the machine enclosure
Estop output or error notification system " notify of malfunction stop machine is required or turn on red light on cabinet"
Auto reversing and stoping, run motor in rever with 2nd contactor or reverse the dc drive controller etc, and stop conveyor to help unjam
are there any features I am missing ?
basic configuration
23 Feb 2024 14:24 #294077
by scotth
Replied by scotth on topic writing chip conveyor component , user input wanted
For the cost of a reversing contactor you could almost install a cheap VFD. You get better current control, speed control and easy reversal.
23 Feb 2024 15:24 #294080
by spumco
Maybe something like:
Replied by spumco on topic writing chip conveyor component , user input wanted
Couldn't tell from your explanation, but having an adjustable run on/off timer would be nice.
- Mode 1
- On with spindle on, off-delay when spindle off
- M100.1 FWD
- M100.2 REV
- OFF at M101 or M5
- Mode 2
- On-off repeating cycle while spindle on, off-delay when spindle off
- i.e. set to come on for X seconds every M2/M30 or 2 minutes or some other frequency
- Saves wear on the conveyor. I have small parts that don't need constant chip clearing, but still need periodic dumping
- M100.1 Px Qx (P-on time, Q-off time)
- Mode 3
- Manual FWD/REV/OFF override
- No M-code needed, just straight pushbutton activation.
- Useful if you're standing there and timing how long it takes to clear chips per cycle, or just need to clear some out while it's running a program
23 Feb 2024 16:07 #294085
by scotth
Other advantages are reduced start current and less coolant drag out at reduced speed. Look at the "The Laws of Fans and Pumps" for power reduction by reducing speed. A VFD will give a pretty good payback.
23 Feb 2024 16:21 #294086
by spumco
I think you may be confusing the OP's intentions here. He's writing a (mostly) hardware-agnostic software component to manage conveyor control, not retrofitting hardware to a conveyor.
Aside from possibly incorporating speed control in his software component, the VFD vs contactors thing is a non-issue at this point.
@scotth,Other advantages are reduced start current and less coolant drag out at reduced speed. Look at the "The Laws of Fans and Pumps" for power reduction by reducing speed. A VFD will give a pretty good payback.
- Thank you received: 5943
23 Feb 2024 16:41 #294087
Replied by tommylight on topic writing chip conveyor component , user input wanted
Adding a VFD "can" not change anything, set the speed manually and use it just as run fwd/rev, so the component sees it as two relays.
23 Feb 2024 19:23 #294105
by chris@cnc
One interval function is nice to have. Reduced the coolant drag out.
I don't think so. VFD is an intelligent device. Usually you have three single inputs and could select motor speed over there and have a current control.
Replied by chris@cnc on topic writing chip conveyor component , user input wanted
23 Feb 2024 21:13 #294118
All VFD i have worked with can be set to be controlled just by fwd/rev pins, at whatever speed you set them on the VFD panel.
You seem to be thinking of the option on some VFD's to also choose a preset speed, but that is not a feature on all VFD's.
23 Feb 2024 21:18 #294119
Reading this again, i really hope you are not thinking about the analog control inputs with 3 wires and 0-10V or 0-5V or 0-20mA ???I don't think so. VFD is an intelligent device. Usually you have three single inputs and could select motor speed over there and have a current control.
23 Feb 2024 21:59 - 23 Feb 2024 22:01 #294125
by chris@cnc
Last edit: 23 Feb 2024 22:01 by chris@cnc.
Time to create page: 0.138 seconds
