Newbie to GladeVCP
10 Mar 2017 10:37 #89324
Replied by andypugh on topic Newbie to GladeVCP
The paths given will be relative to the INI file. So if the glade files are in the same folder as the INI you would remove the ../
10 Mar 2017 16:37 #89339
by AThayer
Replied by AThayer on topic Newbie to GladeVCP
So my best option would be to put the glade files in the same folder as the INI file and then remove the ../?
10 Mar 2017 16:39 #89341
You can put them anywhere you want, but then need to give a correct absolute or relative path to them.
I can't really speculate on which is best for you.
10 Mar 2017 16:44 #89343
by AThayer
Can anyone explain file structure to me?
11 Mar 2017 03:04 #89398
That's something of a generic (not LinuxCNC) question. Windows and Mac use the ../ to burrow down a level too.
I suspect that a Google search will turn up a better and more complete answer than any of us can type.
11 Mar 2017 11:51 #89412
by AThayer
Ok thanks
Time to create page: 0.155 seconds
