Glade 3.20.will not work with LinuxCNC , please follow this for 3.8.6
23 Nov 2017 01:50 #102241
by Gene1934
Cheers, Gene Heskett
"There are four boxes to be used in defense of liberty:
soap, ballot, jury, and ammo. Please use in that order."
-Ed Howdershelt (Author)
Genes Web page <geneslinuxbox.net:6309/gene>
Replied by Gene1934 on topic Glade 3.18.3?
Looks like a major surgery on a wheezy install.
However, I finally hit the magic twanger last night, and with one remaining niggle, its working at any screen size I can muster up on a 1920 display.
Near the bottom of the xml file saved by glade-gtk2 from the 3.80 release, there were a couple "placeholders" defined. Using geany, I nuked them, and that got rid of the error exit. The remaining niggle is that at certain screen sizes and aspect ratios, it jiggles like a cold bowl of jello. Adjust the axis window a couple pixels either way and its dead stable. I can live with that. Now all I need to do is fine tune the #99 tool, and learn how to use the rest of the center and/or align stuff.
Thank you very much for the reply Norbert, its much appreciated.
Cheers, gene83
Cheers, gene83
- Mike_Eitel
- Thank you received: 185
21 Jan 2018 13:31 #104787
by Mike_Eitel
Replied by Mike_Eitel on topic Glade 3.18.3?
Finally i reinstalled glade 3.20 and followed newbynoby's instructions
Only:
First time command glade-3. throws:
libgladeui-1.so.11 cannot open shared objevt file: No such file or directory.
So how to proceed?
Thx Mike
Only:
So how to proceed?
Thx Mike
- Mike_Eitel
22 Jan 2018 08:23 #104834
by Mike_Eitel
Coud this be a save starting Point, and what to do?
opensuse.pkgs.org/42.3/opensuse-oss/libg...-9.2.x86_64.rpm.html
22 Jan 2018 16:46 #104853
by newbynobi
Replied by newbynobi on topic Glade 3.18.3?
Hallo Mike,
you have missed the notice, that all glade after 3.8.6 will not work with glade-gtk2!
So please install latest 3.8.6 not any later releases.
Norbert
Norbert
- Mike_Eitel
22 Jan 2018 18:31 #104857
by Mike_Eitel
Hi Norbert
I deinstalled the 3.20, as proposed after my "downgrade glade" post,
Then I followed your description, earlier in this post here, by copy paste.
Saw no errors,
But when I first typed glade-3 i got: ibgladeui-1.so.11 cannot open s......
So any Idea what i should do now?
PS.
And I understood from cmorley's post that it is gtk2 and that it is handled till 3.8.6.
and that Gtk3 is not supported.
Mike
Saw no errors,
PS.
Mike
23 Jan 2018 05:46 #104870
Replied by cmorley on topic Glade 3.18.3?
in a terminal type glade-gtk2 <enter>
If glade loads then you have a compatible version.
23 Jan 2018 18:38 #104909
by newbynobi
try:
Norbert
sudo apt-get install libgladeui-1-dev
Norbert
- Mike_Eitel
23 Jan 2018 18:49 #104911
by Mike_Eitel
does not find pack:
cnc@MeBigCNC3:~$ sudo apt-get install libgladeui-1-dev
Paketlisten werden gelesen... Fertig
Abhängigkeitsbaum wird aufgebaut.
Statusinformationen werden eingelesen.... Fertig
E: Paket libgladeui-1-dev kann nicht gefunden werden.
cnc@MeBigCNC3:~$ ^C
cnc@MeBigCNC3:~$ ^C
23 Jan 2018 19:06 #104913
by newbynobi
What distro?
Norbert
Norbert
- Mike_Eitel
23 Jan 2018 19:09 #104914
by Mike_Eitel
stretch
BUT ...
DO NOT ASK ME WHY
When I chose glade from the menu it starts now.
HUREEEY
THX
BUT ...
DO NOT ASK ME WHY
HUREEEY
THX
Time to create page: 0.208 seconds
