Glade 3.20.will not work with LinuxCNC , please follow this for 3.8.6
24 Sep 2017 11:14 #99374
by newbynobi
Replied by newbynobi on topic Glade 3.18.3?
I am working with Jessie and glade 3.8.5 build from sources with 64 bit and all is working fine.
So IMHO it is related to your distro.
Norbert
Norbert
24 Sep 2017 21:07 - 24 Sep 2017 21:51 #99387
by scubawarm
Well I tried 4.9.4 which is stated to be "tested" same issues.
I would much prefer to use Mint over Debian so I'm not chasing drivers all the time. Especially touchscreens.
what kernel are you running?
uname -r
EDIT: That is right why I also really hate Debian. uname, ifconfig etc... commands don't exist.... UGGH
Replied by scubawarm on topic Glade 3.18.3?
Norbert
uname -r
Last edit: 24 Sep 2017 21:51 by scubawarm.
29 Sep 2017 11:59 - 01 Oct 2017 11:20 #99607
by newbynobi
Replied by newbynobi on topic Glade 3.8.5
As there seem to be some problems on installing glade 3.8.6 on Mint 64 bit, I tried and had success. So here is a little HowTO, based on a installed:
to get your kernel version, open a terminal and type:
Check if there is a glade version installed from the package manager, if so, you need to uninstall that release!
You may use synaptic for that purpose.
If you do not know how to do that, do not go on with this How To, as you will not be able to finish this with success!
Make sure you have all the latest updates installed. open a terminal and enter :
(just leave the terminal window opened, as you will need that one very often)
First we need to install some dependencies, just enter in the terminal:
get the source of glade 3.8.6 (Do not use any newer glade release, as they so not support gtk2 any more!)
in the terminal enter:now install it by typing:
to test the glade install, enter in the terminal:
Try to add a main window and in that window any widget you like,
if it does work, then go on
Till now we do not have any hal widgets, so we need to install linuxcnc!
So now fetch the source of LinuxCNC:
as dpkg-checkbuilds needs assess to the source packages and as default the corresponding repositories are not enabled,
open synaptic from main menu, goto settings, packages and enable source code, check the corresponding box
close it and change to the terminal, enter
you should get:
go on in the terminal
should give something like:
so install that dependencies (check what dependencies your system really does need)
Check again, if all dependencies are satisfied:
should give no output!
as in my case ./configure gave some errors of additional missing packages,
I needed to do:
now in the terminal enter:
gave me some warnings, but no error
go on in the same terminal:
if that is also OK, we need to copy the hal widget glade catalog to the correct place.
backup the originals first
now copy/add the missing files to that dir with the following terminal commandsNow test in the terminal you did the command
. ./scripts/rip-environment, just enter
Voila!
You should have a working glade_3.8.6
I would appreciate, if someone could add this tutorial to the official documentation or at least to the glade section.
Regards Norbert
MINT 18.2 'Sonja'
Cinnamon 64-bit
with Kernel:
4.10.0-28-generic
uname -r
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install intltool python-gtk2-dev libxml2-dev gtk-doc-tools gnome-doc-utils liblablgtk2-gnome-ocaml-dev libglade2-dev libgladeui-common python-gtkglext1 itstool
wget ftp://ftp.gnome.org/pub/GNOME/sources/glade3/3.8/glade3-3.8.6.tar.xz
tar -xpf glade3-3.8.6.tar.xz
cd glade3-3.8.6
./configure
make
sudo make install
glade-3
cd
sudo apt-get install git git-gui
git clone https://github.com/LinuxCNC/linuxcnc.git linuxcnc-dev
sudo apt-get update
cd /linuxcnc-dev/debian
./configure uspace
you should get:
successfully configured for 'uspace-LinuxMint-18.2'-'uspace+xenomai'..
cd ..
dpkg-checkbuilddeps
dpkg-checkbuilddeps: Fehler: Nicht erfüllte Bauabhängigkeiten: build-essential:native debhelper (>= 6) libudev-dev libxenomai-dev tcl8.6-dev tk8.6-dev libreadline-gplv2-dev asciidoc (>= 8.5) dblatex (>= 0.2.12) dvipng graphviz groff inkscape source-highlight texlive-extra-utils texlive-font-utils texlive-fonts-recommended texlive-lang-cyrillic texlive-lang-french texlive-lang-german texlive-lang-polish texlive-lang-spanish texlive-latex-recommended w3c-linkchecker python-tk libxmu-dev libglu1-mesa-dev libgl1-mesa-dev | libgl1-mesa-swx11-dev libboost-python-dev libmodbus-dev (>= 3.0) libusb-1.0-0-dev
sudo apt-get install build-essential debhelper libudev-dev libxenomai-dev tcl8.6-dev tk8.6-dev libreadline-gplv2-dev asciidoc dblatex dvipng graphviz groff inkscape source-highlight texlive-font-utils texlive-lang-cyrillic texlive-lang-french texlive-lang-german texlive-lang-polish texlive-lang-spanish w3c-linkchecker python-tk libxmu-dev libglu1-mesa-dev libgl1-mesa-dev libboost-python-dev libmodbus-dev libusb-1.0-0-dev
dpkg-checkbuilddeps
I needed to do:
sudo apt-get install bwidget libtk-img tclx
cd src
./autogen.sh
./configure --enable-simulator
make
sudo make setuid
cd ..
linuxcnc ~/linuxcnc-dev/configs/sim/gmoccapy/gmoccapy.ini
sudo mkdir -p /usr/local/share/glade3/backup/catalogs
sudo mkdir -p /usr/local/share/glade3/backup/pixmaps
sudo cp /usr/local/share/glade3/catalogs/* /usr/local/share/glade3/backup/catalogs
sudo cp -r /usr/local/share/glade3/pixmaps/* /usr/local/share/glade3/backup/pixmaps
sudo cp ~/linuxcnc-dev/lib/python/gladevcp/*.xml /usr/local/share/glade3/catalogs
sudo cp ~/linuxcnc-dev/lib/python/gladevcp/*.png /usr/local/share/glade3/pixmaps
glade-3
Voila!
Regards Norbert
Last edit: 01 Oct 2017 11:20 by newbynobi. Reason: Updated to fetch release 3.8.6 and corrected the install procedure of glade3
29 Sep 2017 12:23 - 29 Sep 2017 12:25 #99609
by scubawarm
Replied by scubawarm on topic Glade 3.8.5
Thanks Norbert will try it.
You do have the order of things differently. And did not try 3.8.5
BUT please test this. Issue was not widgets. It was this.
Open glade-3
Add a main window
Add an About window (or any other window I tried)
Instant crash
Yours doesn't?
Open glade-3
Add a main window
Instant crash
Yours doesn't?
Last edit: 29 Sep 2017 12:25 by scubawarm.
29 Sep 2017 22:46 #99646
by newbynobi
Hallo,
I tested as rip environment with GladeVCP widgets, and also with normal glade without the hal stuff.
In both cases I do not have any crash. I can also open i.e. gmoccapy.glade and add stuff.
As said, I am using 3.8.5 and haven't tried jet 3.8.6
Norbert
Norbert
30 Sep 2017 12:06 #99673
by scubawarm
Please pardon my continued questions... Just trying to fully understand. To me a RIP is meant more to test something rather then install it. Is there a reason you are doing rip with the HAL and regular without? Or just stating what you tried?
Hallo,
Norbert
30 Sep 2017 12:16 #99674
Replied by rodw on topic Glade 3.18.3?
I use RIP for everything. If I'm compiling from source, there is no need to create a deb to install it when it might change next week.
30 Sep 2017 12:37 #99679
by scubawarm
So when you guys say RIP... You are simply saying installation without using a DEB? Acronyms... So many Acronyms
30 Sep 2017 15:11 #99684
Replied by PCW on topic Glade 3.18.3?
RIP means Run In Place
Basically it means run LinuxCNC without installing it in the normal locations
but rather running it from where ever it was built
This has the advantage the you can easily run multiple versions of LinuxCNC on the same host
and test versions without disturbing a working system.
The minor disadvantage of RIP installs is that you must run the RIP script that sets up the paths
and environment variables before launching LinuxCNC. I'm pretty sure the GUI launcher does this
however
however
30 Sep 2017 17:55 #99692
by newbynobi
Hallo subawarm,
i do it with a rip installed LinuxCNC, because on this machine I have not installed a realtime kernel. I am not sure, but starting glade-3 without doing the rip-environment step, IMHO will not allow to load the hal widgets. That's the only reason I do it this way. My machine is running with Jessie and realtime kernel and on that machine I have it is working in both ways, but I compiled on that machine LinuxCNC with relatime Preempt kernel.
Norbert
Norbert
Time to create page: 0.249 seconds
