Glade 3.20.will not work with LinuxCNC , please follow this for 3.8.6
28 Jan 2018 21:17 #105115
by newbynobi
Replied by newbynobi on topic Glade 3.8.3
Glad you got it working.
- Mike_Eitel
- Thank you received: 185
28 Jan 2018 21:52 #105120
by Mike_Eitel
Replied by Mike_Eitel on topic Glade 3.8.3
Never ever without your patient help!
16 May 2019 23:29 - 16 May 2019 23:38 #134019
by Mavili74
Replied by Mavili74 on topic Glade 3.8.3
Hi Norbert,
I hope this is the right place to right my problem.
I installed and used gmoccapy with linuxcnc 2.7.14 without problem. I also installed glade 3.8.6 and followed your instructions to edit gmoccapy.glade file with glade 2 all was good so far but my problem started when i upgraded to linuxcnc 2.8 via synaptic from buildbot repo.
now, gmocccapy does not work. It gives me these error what ever i do to make it work. I hope you can help me.
I even built linuxcnc master from source then started as rip but no luck.
Berkdan
The error message :
Found an error!
The following information may be useful in troubleshooting:
File "/usr/lib/python2.7/dist-packages/gladevcp/tooledit_widget.py", line 103, in __init__
self.set_col_visible(list='spyabcuvwdijq', bool= False, tab= '2')
File "/usr/lib/python2.7/dist-packages/gladevcp/tooledit_widget.py", line 401, in set_col_visible
renderer.set_property('visible', bool)
AttributeError: 'NoneType' object has no attribute 'set_property'
it gives me this error first when i press OK Gmoccapy screen appear below an error message again then when i click ok it shuts down.
the next error message is :
ound an error!
Found an error!
File "/usr/bin/gmoccapy", line 4755, in <module>
app = gmoccapy(sys.argv)
File "/usr/bin/gmoccapy", line 303, in __init__
self._init_tooleditor()
File "/usr/bin/gmoccapy", line 1055, in _init_tooleditor
self.widgets.tooledit1.set_filename(toolfile)
File "/usr/lib/python2.7/dist-packages/gladevcp/tooledit_widget.py", line 233, in set_filename
self.reload(None)
File "/usr/lib/python2.7/dist-packages/gladevcp/tooledit_widget.py", line 240, in reload
self.model.clear()
AttributeError: 'ToolEdit' object has no attribute 'model'
Berkdan
The error message :
Found an error!
ound an error!
Found an error!
self.reload(None)
self.model.clear()
Last edit: 16 May 2019 23:38 by Mavili74. Reason: I have added some more infos.
17 May 2019 00:18 - 17 May 2019 00:25 #134020
by Grotius
Replied by Grotius on topic Glade 3.8.3
Hi Mavi,
github.com/LinuxCNC/linuxcnc/releases you will see : on Jun 18, 2018 presented version : 2.7.14
This will work.
If i look in the files : /usr/lib/python2.7/dist-packages/gladevcp/tooledit_widget.py
Your lines 103 and 401 aren't even presented. So much is changed in v2.8 for sure.
Why don't stay at the stable 2.7.14 version? At git you can't download 2.8 so far as i can see.
I see you post on Git the same question with other user name... github.com/LinuxCNC/linuxcnc/issues/592
Python version up to : ls /usr/bin/python*
v3.5
Is the file tool.tbl presented in your linux gmocappy directory?
This will work.
v3.5
Last edit: 17 May 2019 00:25 by Grotius.
17 May 2019 04:09 - 17 May 2019 04:10 #134026
Are you trying to use the modified GLADE file from 2.7.x screen in master?
I'm pretty sure enough has changed that you would be better off taking the master version GLADE file and modifying it.
Chris M
Replied by cmorley on topic Glade 3.8.3
Hi Norbert,
Berkdan
Chris M
Last edit: 17 May 2019 04:10 by cmorley.
17 May 2019 07:20 #134029
by newbynobi
It seems you are trying to use the tooledit widget from 2.7 in master release, that will not work.
Does the error also apear, if you start a gmoccapy sim config?
Norbert
Norbert
17 May 2019 07:24 #134030
by Mavili74
Hi again.
I answer your questions Norbert.
<Why don't stay at the stable 2.7.14? >
I think trajectory planner has changed a lot in 2.8. when I use 2.7.14 stepper motors so much noise like something is hitting the machine very fast while machining a relief. Very similar what you hear when you drive a car with abs brake system and you make sudden brake. I don't know if I can describe that. The motors run very smooth if i make pockets or profiles. Whenever Z axis makes small moves constantly then the noise i described starts. The same machine the same computer the same motors same gcode with mach3 runs very smooth. I tried everything but couldn't make it run smoother. I upgraded to 2.8 and now motors works very smooth.
<At git you can't download 2.8 so far as i can see.>
I meant 2.8.0-pre1-4728-g26311513b
Isn't master branch is 2.8.pre...? Because when I run axis it says so.
I can even see gmoccapy screen below the error message and it is upgraded version for sure with + and - indicators on orange speed control. I followed a tutorial how to build linuxcnc from source. as i said axis works very well.
<Python version up to : ls /usr/bin/python*
v3.5>
Python versions 2.7and 3.5 are installed.
<Is the file tool.tbl presented in your linux gmocappy directory?>
Yes it is.
Thank you very much for your quick replies btw.
Is it possible to see the version number of gladevcp?
v3.5>
Yes it is.
17 May 2019 07:30 #134031
by Mavili74
Since i dont know how to find gladevcp version the only reasonable cause seems that glade version is wrong in my system. Isnt it updated version of gladevcp on linuxcnc master branch?
I mean linuxcnc-dev/lib/python/gladevcp does not contain newer version?
Is there any place where i get newest gladevcp?
17 May 2019 07:34 #134032
by Mavili74
Yes it does appear with sim config.
The only reason that make sense for me is wrong gladevcp version. But even i copied it with manually from linuxcnc-dev folder. No luck.
Regards,
Berkdan
Norbert
Regards,
Berkdan
17 May 2019 08:36 #134035
by Mavili74
related part of tooledit_widget.py as follows
388 def set_col_visible(self, list, bool= False, tab= '1'):
389 #print list,bool,tab
390 for i in range(0, len(tab)):
391 if tab in ('1','2','3'):
392 #print tab
393 for index in range(0, len(list)):
394 colstr = str(list[index])
395 #print colstr
396 colnum = 'stpxyzabcuvwdijq;'.index(colstr.lower())
397 #print colnum
398 name = KEYWORDS[colnum].lower()+tab
399 #print name
400 renderer = self.wTree.get_object(name)
401 renderer.set_property('visible', bool)
392 #print tab
395 #print colstr
397 #print colnum
399 #print name
Time to create page: 0.384 seconds
