How can I get GladeVCP?
12 Nov 2021 07:47 #226199
by yi2580
Replied by yi2580 on topic How can I get GladeVCP?
Hello, I am programming in the VM virtual machine, but when I transplant the. Galde file and py code to my industrial computer, it cannot run. It can run well in the virtual machine. I don't know what to do. The error he reported to me was that I couldn't find the library import gladevcp.makepinsThis isn't a good answer, but it is the simplest solution for me. I have one of the older Wheezy based Linuxcnc ISO installed in a VM on the PC I develop my configs on. It has the right version of Glade installed by default. I set up the UI files there then copy them over to the machine where I want to use them.
There may be a solution for installing the GTK2 version of Glade on Buster, but I don't know it.
16 Nov 2021 16:51 #226662
Replied by andypugh on topic How can I get GladeVCP?
You might need to install the linuxcnc-dev package
17 Nov 2021 08:28 #226710
by yi2580
I have installed Linux CNC dev
17 Nov 2021 10:00 #226719
What OS is the problem PC running?
Which version of LinuxCNC is it running?
18 Nov 2021 00:50 #226815
by yi2580
Both PC and controller are Ubuntu systems, and PC is Linux CNC
2.8 controller is 2.9
21 Nov 2021 17:25 #227204
LinuxCNC 2.9 is in the middle of converting to Python3, so there might be some issues there.
It might be best to run 2.8 on both machines.
24 Nov 2021 01:04 #227463
by yi2580
OK, I'll try to change it back to Linux CNC 2.8. Thank you very much for your suggestion
20 Dec 2021 04:29 #229538
by lrak
Replied by lrak on topic How can I get GladeVCP?
For some reason, I decided to shoot myself in the foot and upgrade to bullseye without thinking -- I think I need to build the glade-gtk2 package - perhaps - but I can't find the sources?
glade-gtk2
The following packages have unmet dependencies:
libglib2.0-0 : Breaks: libgladeui-2-6 (< 3.22.2) but 3.22.1-4 is to be installed
glade-gtk2
21 Dec 2021 20:50 #229653
You can try installing glade-gtk2 using the deb package here:
www.linuxcnc.org/dists/buster/base/binary-amd64/
Download the file and then sudo apt-get install ./path-to-downlaoded-file.deb
The ./ is important, it tells apt to install from a file, not from a repository.
The following user(s) said Thank You: lrak
29 Dec 2021 02:13 - 29 Dec 2021 02:15 #230190
by lrak
Andy - I was looking for the sources - never did find them. I ended up going back to 'buster' for now.
There is a way to change dependencies using /etc/apt/preferences and update-alternatives, but I'm going to wait for things to end up on build-bot first.
Really appreciate all the bits you have worked on here.
Last edit: 29 Dec 2021 02:15 by lrak.
Time to create page: 0.212 seconds
