How can I get GladeVCP?
27 Dec 2020 20:40 #193309
by zz912
How can I get GladeVCP? was created by zz912
I would like change Gmoccapy. So I need GladeVCP.
In manual is written:
linuxcnc.org/docs/2.8/html/gui/gladevcp....adevcp:prerequisites
butdont work.
Could you help me, please?
but
sudo apt-get install glade-gtk2
pi@linuxcnc: $ uname -a
Linux linuxcnc 4.19.71-rt24-v7l+ #4 SMP PREEMPT RT Thu Apr 30 22:00:15 CDT 2020 armv7l GNU/Linux
The following user(s) said Thank You: macsddau@linuxcnc
- macsddau@linuxcnc
- Thank you received: 28
29 Dec 2020 17:29 #193441
by macsddau@linuxcnc
Replied by macsddau@linuxcnc on topic How can I get GladeVCP?
Up ! Same for me
21 Jan 2021 14:22 #196092
by skrap58
Replied by skrap58 on topic How can I get GladeVCP?
Same for me
- Thank you received: 1370
21 Jan 2021 17:17 #196115
Replied by Todd Zuercher on topic How can I get GladeVCP?
This isn't a good answer, but it is the simplest solution for me. I have one of the older Wheezy based Linuxcnc ISO installed in a VM on the PC I develop my configs on. It has the right version of Glade installed by default. I set up the UI files there then copy them over to the machine where I want to use them.
There may be a solution for installing the GTK2 version of Glade on Buster, but I don't know it.
22 Jan 2021 23:16 #196294
Replied by andypugh on topic How can I get GladeVCP?
There is a package called imply "glade" though that might only work with gtk3.
On the Pi there is a package called "glade-3" which is glade-gtk2, though that might not help.
LinuxCNC did back-port glade-gtk2 on Wheezy, so you could try the deb package here: www.linuxcnc.org/dists/wheezy/base/binary-amd64/ though it might refuse to run on Buster.
23 Jan 2021 10:52 - 23 Jan 2021 10:53 #196323
by newbynobi
Replied by newbynobi on topic How can I get GladeVCP?
you will need to compile glade 3.8.6 from source code.
In this post I described how to install Mint 19 with glade 3.8.6, the part of installing glade should fit your needs. Please uninstall all glade using synaptic prior to installing glade 3.8.6
Norbert
Norbert
Last edit: 23 Jan 2021 10:53 by newbynobi.
24 Jan 2021 17:31 #196434
Not any more
For Buster / amd64 I have put a package "glade-gtk2" on the LinuxCNC repository.
And there is a pre-existing package for Raspbian.
For Buster with the LinuxCNC 64-bit kernel:For Raspbian on Pi
Not any more
sudo apt-get install glade-3
26 Jan 2021 16:21 - 26 Jan 2021 16:22 #196632
by probotix
Replied by probotix on topic How can I get GladeVCP?
I cannot install glade2 on Buster:
E: Unable to locate package glade-gtk2
This is in my sources.list:
deb http://www.linuxcnc.org/ buster 2.8-rtpreempt base
deb-src http://www.linuxcnc.org/ buster 2.8-rtpreempt base
Last edit: 26 Jan 2021 16:22 by probotix.
26 Jan 2021 17:02 #196635
sudo apt-get update and try again?
26 Jan 2021 22:44 #196670
by joekline9
Replied by joekline9 on topic How can I get GladeVCP?
Ok it worked for me after the 'update'
