How can I get GladeVCP?
28 Jan 2021 14:52 #196945
by probotix
Replied by probotix on topic How can I get GladeVCP?
Has the LED widget been removed?
28 Jan 2021 16:01 #196957
by probotix
So, I had followed someone else's advise and compiled my own 3.8.6 from source, and that works, but none of the HAL widgets are there. I removed that install and re-installed using apt, and it also works, but still no HAL widgets. I tried to set the GLADE_CATALOG_PATH to /usr/lib/python2.7/dist-packages/, and still no HAL widgets. Any ideas?
28 Jan 2021 16:21 #196959
by probotix
Ok, one step closer... found the catalogs and set the path to GLADE_CATALOG_PATH=/usr/share/glade3/catalogs/, now it throws all kinds of "Tried to include undefined widget class EMC_*****" errors.
28 Jan 2021 23:59 #197002
Replied by andypugh on topic How can I get GladeVCP?
Try
sudo apt-get install linuxcnc-uspace-dev
(After installing Glade)
29 Jan 2021 00:13 #197008
by probotix
actually, I had already done that *before I got to this point. But then I tried apt-get remove, then apt-get install, and still no widgets
29 Jan 2021 00:35 #197013
<clutching at straws>
apt-get reinstall?
apt-get reinstall?
29 Jan 2021 16:09 - 29 Jan 2021 16:10 #197067
by joekline9
Replied by joekline9 on topic How can I get GladeVCP?
In a stand alone '.c' program using gtk2
my only problem now is I get error when using sin() or cos().
I have:
#include math.h
it will compile on wheezy OK but not buster.
I have:
#include math.h
Last edit: 29 Jan 2021 16:10 by joekline9.
29 Jan 2021 23:59 #197103
You could try rtapi_math.h. Though there should be no reason to in userspace code (rtapi_math.h is the LinuxCNC threadsafe maths library, for realtime code)
31 Jan 2021 20:25 #197244
by joekline9
OK. I found that you need -lm option in the gcc command. I didn't need that in wheezy.
This is a stand alone program not a Linuxcnc comp.
gcc -Wall -g GraphA2-tty.c -o graphA2-tty -lm `pkg-config --cflags --libs gtk+-2.0`
- robertspark
- Thank you received: 216
07 Mar 2021 16:54 #201313
by robertspark
any change of adding to master? {i installed from 2.8-preempt, but it may be of use going forward?}
Replied by robertspark on topic How can I get GladeVCP?
you will need to compile glade 3.8.6 from source code.
Not any more
For Buster / amd64 I have put a package "glade-gtk2" on the LinuxCNC repository.
And there is a pre-existing package for Raspbian.
For Buster with the LinuxCNC 64-bit kernel:For Raspbian on Pisudo apt-get install glade-gtk2sudo apt-get install glade-3
Time to create page: 0.387 seconds
