GladeVCP
07 Sep 2011 12:53 #13029
by psha
Replied by psha on topic Re:GladeVCP
If you are using gladevcp as right side panel then it's name is fixed 'gladevcp'
See docs
linuxcnc.org/docs/2.5/html/gui/gladevcp....into_axis_like_pyvcp
See docs
07 Sep 2011 15:24 #13031
by piasdom
Replied by piasdom on topic Re:GladeVCP
well, i mean that i have on_est_op_toggled as a pin in glade
and used vcp.on_est_op_toggled in postgui.hal and
it says doesn't exist.
kenneth
kenneth
07 Sep 2011 16:19 #13032
by psha
Pin name is gladevcp.on_est_op_toggled - gladevcp is component name for vcp panel on the right
07 Sep 2011 22:40 #13038
by piasdom
i tried gladevcp.on_est_op_toggled, still not reconized. i'm getting the
signal name from the property signal tab. i click on the name and a drop
down menu appears. i select the first(on_est_op_toggled). is there another
place to get instruction?
i use these;
wiki.linuxcnc.org/emcinfo.pl?GladeVcp
emc.mah.priv.at/docs/html/gui/gladevcp.html
kenneth
i use these;
kenneth
08 Sep 2011 10:35 #13041
by piasdom
i ran emc thru the terminal and got the below error.(lot more than that)
is this looking for a file i don't have ?
/usr/bin/gladevcp:204: RuntimeWarning: missing handler 'on_Right_activate'
builder.connect_signals(handlers)
kenneth
kenneth
08 Sep 2011 15:23 #13043
by piasdom
i ran glade thru the terminal and got the attached errors.
may not be install completely ? (or correctly)
kenneth
kenneth
08 Sep 2011 18:08 #13053
by psha
signals you see in glade editor has nothing in common with HAL singals.
So i guess you pin name is gladevcp.est_op
09 Sep 2011 10:29 #13060
by piasdom
well, that didn't work. but can someone tell me if the info is in the docs i'm
been reading ? if so, thanks i'll continue reading. NP
09 Sep 2011 11:47 #13061
by psha
I hope that everything needed is in docs. Also you have to look at examples.
If it's possible catch me in IRC (#emc @ irc.freenode.net)
09 Sep 2011 11:51 #13062
by piasdom
Thanks psha , gone alooking !
