GladeVCP
13 Sep 2011 13:58 - 13 Sep 2011 14:08 #13169
by piasdom
Replied by piasdom on topic Re:GladeVCP
as far as the estop button, i tried 'control and display toggle and plain button.
and hal python toggleaction and hal_action_estop_reset1 and neither change state.
except toggleaction does turn power off once i turn on with other button.
and i have it connect with emc toggleaction estop in glade.
just to let you know in case a bug.
kenneth
kenneth
Last edit: 13 Sep 2011 14:08 by piasdom.
13 Sep 2011 14:14 #13170
by psha
Replied by psha on topic Re:GladeVCP
Show your UI file please.
And postgui halfile
BTW you are using estop reset action, not toggle action - they are different
ToggleAction consists of two actions - for on-off state change and for off-on
And postgui halfile
13 Sep 2011 14:26 - 13 Sep 2011 14:26 #13171
by piasdom
Last edit: 13 Sep 2011 14:26 by piasdom.
13 Sep 2011 14:27 #13172
by piasdom
piasdom wrote:
kenneth
13 Sep 2011 14:47 #13173
by psha
Yes, you are using estop reset instead of estop toggle, that's why it's only turning off machine and not turning on
13 Sep 2011 14:57 #13175
by piasdom
Thanks, i did use toggle and reset, guess it was reset that i last used.
but i think i found my blunder:) . in my axis.hal i had the
net estop-out => iocontrol.0.emc-enable-in disabled because i used it for
my prvcp button. after enabling it, estop works as should. sorry for giving
you all this trouble. Thanks so much !
kenneth
kenneth
13 Sep 2011 23:13 #13185
by piasdom
the home all, each home XYZ buttons don't go disabled when program running.
letting u no
kenneth
letting u no
kenneth
14 Sep 2011 10:59 #13195
by piasdom
where/how do i disable a button/pin while program is running,as in the attached txt ?
i want the home and move axis buttons to be disabled while program running.
kenneth
kenneth
16 Sep 2011 11:46 #13222
by piasdom
i can edit the the color of a label but not the size. the lettering disappears.
and can i edit the color/size of a button(reg/hal) ?
kenneth
kenneth
19 Sep 2011 10:51 - 19 Sep 2011 10:57 #13285
by piasdom
what do i use for a pyvcp number widget ?
want to setup a DRO in glade. i tried the meter for a feed rate,
but it didn't match the feed.
kenneth
kenneth
Last edit: 19 Sep 2011 10:57 by piasdom.
Time to create page: 0.279 seconds
