THC config that works.
07 Jul 2019 15:20 #138802
by pl7i92
Replied by pl7i92 on topic THC config that works.
the proma we use work at 112V and is set to be 4V+- that workes as for most sheets 1-3mm
P80 nozzels at 35A 1,5mm kerv width at 2400-4800mm/min cut speed
net spindle-on <= motion.spindle-on => thcud.arc-ok thcud.torch-on
net TorchUp thcud.torch-up <= parport.0.pin-15-in-not
net TorchDown thcud.torch-down <= parport.0.pin-10-in-not
net CurVel thcud.current-vel <= motion.current-vel
setp thcud.requested-vel 15.0
setp thcud.vel-tol 8.0
setp thcud.correction-vel 0.001
- Topic Author
- Thank you received: 5945
10 Aug 2019 08:54 #141855
Replied by tommylight on topic THC config that works.
Added links to PlasmaC on the original post.
- Aldenflorio
- Thank you received: 13
01 Jun 2020 18:24 #169692
by Aldenflorio
Replied by Aldenflorio on topic THC config that works.
Hello, I have a Mesa 7i96 board and am using the Proma Compact thc. I wondering if the configuration files still work. Along with that I have a couple wiring questions if you don’t mind answering. Please and thank you!
- Topic Author
01 Jun 2020 18:27 #169693
forum.linuxcnc.org/plasmac/37234-plasmac-documentation
Yes they do work, but it is much better if you use the PlasmaC config fro 7i96, it is more advanced and has a lot of new features.Hello, I have a Mesa 7i96 board and am using the Proma Compact thc. I wondering if the configuration files still work. Along with that I have a couple wiring questions if you don’t mind answering. Please and thank you!
01 Jun 2020 18:28 #169694
Did you read the notes in the first post that this config is superceded and to use Plasmac?
Replied by rodw on topic THC config that works.
- Aldenflorio
01 Jun 2020 23:52 #169738
by Aldenflorio
I’m sorry, I probably did but I’m really not familiar with Linux so I didn’t understand it
- Aldenflorio
01 Jun 2020 23:54 #169740
by Aldenflorio
Thank you. I’m not very familiar with Linux or things like this. Which of the four links would I click?
- Topic Author
02 Jun 2020 00:23 #169744
First 2.
Later you can decide if you want to use 2.8 or 2.9 version of Linuxcnc. 2.8 is stable while 2.9 is still being developed so might have occasional issues but it is very stable so far.
Off topic -- And that reminds me:
On Linux unstable = some issue that needs precise directions just to be able to find it, usually no one notices it,
On windows patch = something has already gone horribly wrong for many, many users.
- Aldenflorio
02 Jun 2020 00:30 - 02 Jun 2020 00:31 #169745
by Aldenflorio
Thank you very much! This may be the wrong place to ask, If it is I’m sorry. Does the proma thc need a relay to help protect if from the Pilot arc? And is a relay board enough isolation or do you suggest more?
Last edit: 02 Jun 2020 00:31 by Aldenflorio.
- Topic Author
02 Jun 2020 00:36 #169748
What type of Proma ?
If THC150, all is good continue reading,
If THC SD, stop reading this and just go make a normal 3 axis config and use the machine after some adjusting of the THC. The SD is self contained so it has nothing to do with software, it just intercepts the step/dir signals going to the Z axis drive and sends it's own signals.
No it does not need anything.Thank you very much! This may be the wrong place to ask, If it is I’m sorry. Does the proma thc need a relay to help protect if from the Pilot arc? And is a relay board enough isolation or do you suggest more?
Time to create page: 0.267 seconds
