XHC-HB04 integration in 2.8.4
24 Feb 2023 18:17 - 24 Feb 2023 19:38 #265258
by Andy123
XHC-HB04 integration in 2.8.4 was created by Andy123
Hi everyone.
I have XHC-HB04 pendant working for many years in ver 2.6.x and parallel port.
Now I am trying to integrate it into Mesa 7i96S setup in version 2.8.4
Mesa board is running without any issues.
I copied HB04 sections from old INI file to the new INI created by pncconf and getting error:
Pin 'halui.axis.0.pos-feedback' does not exist
while executing
"hal net pendant:pos-x halui.axis.0.pos-feedback => xhc-hb04.x.pos-absolute"
("eval" body line 1)
invoked from within
"eval hal net $args"
(procedure "net" line 1)
invoked from within
"net pendant:pos-$coord halui.axis.$axno.pos-feedback => xhc-hb04.$acoord.pos-absolute"
(procedure "wheel_setup" line 58)
invoked from within
"wheel_setup $::XHC_HB04_CONFIG(jogmode)"
(file "./xhc-hb04.tcl" line 409)
invoked from within
"source $filename"
invoked from within
"set result [source $filename]"
(file "/usr/bin/haltcl" line 42)
1139
Any ideas?
Thank you
while executing
invoked from within
invoked from within
invoked from within
invoked from within
"source $filename"
invoked from within
1139
Any ideas?
Thank you
Last edit: 24 Feb 2023 19:38 by Andy123.
24 Feb 2023 19:43 #265270
by Andy123
Replied by Andy123 on topic XHC-HB04 integration in 2.8.4
I think I found some related post, and copy from 2.6 was mistake.
But for newbie hard to follow, it's been many years since I touched configurations.
forum.linuxcnc.org/10-advanced-configura...4-basic-setup-in-2-8
forum.linuxcnc.org/38-general-linuxcnc-q...c-hb04-configuration
Anybody can point me to step-by-step 2.8.4 directions or Wiki?
25 Feb 2023 01:58 #265300
by Andy123
I got it working in 2.8.4 using examples from discussion above.
In reality, I need a very simple setup without any mdi macros, just MPG, Start/Pause, Stop, Reset, Homing and Spindle.
Few things to mention:
- I got much better results without a lowpass filter on MPG, smooth moves.
- It was tricky to setup Start/Pause button but I found an example
- I still want to have a toggle on Spindle button. As of now it just turns it On.
Also, I believe in my old setup, MPG was working before homing, now I can't use it until homed. However, I can jog from Axis screen before homing. Any idea why? Are there different set of pins to connect?
- Thank you received: 5944
25 Feb 2023 02:13 #265301
Before they were hard coded as the same thing, now any axis can have several joints with separate drives/motors, and all work as the same axis after homing.
Sorry i can not be of more help, but i never use pendants or MPG's, just a keyboard is all i need.
Replied by tommylight on topic XHC-HB04 integration in 2.8.4
Probably due to new versions of LinuxCNC using distinct joints and axis, so jog.axis-x???? is not the same as jog.joint-0 anymore.Also, I believe in my old setup, MPG was working before homing, now I can't use it until homed. However, I can jog from Axis screen before homing. Any idea why? Are there different set of pins to connect?
25 Feb 2023 13:10 #265325
Replied by andypugh on topic XHC-HB04 integration in 2.8.4
The conversion script probably fixed your original config, but then when you added the pendant stuff, it won't have know that needed doing.
It's probably all documented somewhere, but if you understand regex all the changes that need to be made between 2.6 and 2.8 are visible in the script code:
github.com/LinuxCNC/linuxcnc/blob/master...i/update_ini.py#L428
26 Feb 2023 02:50 #265380
by Andy123
I think I got all functions working now.
Using joint resolved MPG issue - now I can use it before homing
Thank you
This is a clean install for 2.8.4 on a newer computer, so no script.The conversion script probably fixed your original config
Thank you
Time to create page: 0.149 seconds
