Linuxcnc 2.8.2 XHC-HB04 configuration
  • jaro_p
  • Topic Author
  • Senior Member
  • Senior Member
4 years 8 months ago #235605 by jaro_p
Please help with setting up XHC-HB04.
I am trying to run XHC-HB04 on Linux 2.8.2. to Rpi4 with mesa 7c81 card.
The version of MPG I have is XHC-HB04-L
I followed the instructions published here:
wiki.linuxcnc.org/cgi-bin/wiki.pl?Using_...Wireless_MPG_Pendant
I downloaded the file xhc-hb04.tcl from here:
github.com/LinuxCNC/linuxcnc/blob/master.../hallib/xhc-hb04.tcl
I placed this file in / home / pi / linuxcnc / configs / raspi-cnc / ...
When I try to run Linuxcnc I get an error message:
./xhc-hb04.hal:5: Pin 'halui.home-all' does not exist
4568
When I comment on a line:
net home halui.home-all <= xhc-hb04.button-home
in xhc-hb04.hal, I get the following error message:
./xhc-hb04.hal:9: Pin 'halui.axis.0.pos-feedback' does not exist
5180
And so it continues with the next lines.
I enclose all the files that I think are important.
Thank you in advance for every response.
File Name: raspi-cnc.hal
File Size:12.43 KB
File Name: linuxcnc_info.txt
File Size:3.17 KB
File Name: xhc-hb04.hal
File Size:2.14 KB
File Name: xhc-hb04_tcl.txt
File Size:19.5 KB
File Name: raspi-cnc.ini
File Size:7.8 KB
File Name: linuxcnc.txt
File Size:7.87 KB
File Name: xhc-hb04-layout2.ini
File Size:445 B
4 years 8 months ago - 4 years 8 months ago #235615 by Aciera
Replied by Aciera on topic Linuxcnc 2.8.2 XHC-HB04 configuration
Seems to me you are using Hal commands from before Version 2.8:
linuxcnc.org/docs/html/man/man1/halui.1.html
Note that from 2.8 on there is a separation between 'axis' (designated with letters) and 'joints' (designated with numbers)
[edit]
I think that there is no halui.home-all pin since you have not set a homing sequence in your ini .
Last edit: 4 years 8 months ago by Aciera.
  • jaro_p
  • Topic Author
  • Senior Member
  • Senior Member
4 years 8 months ago #235648 by jaro_p
Replied by jaro_p on topic Linuxcnc 2.8.2 XHC-HB04 configuration
Thank you, can you tell me what such a home-sequence in an .ini file should look like?
  • jaro_p
  • Topic Author
  • Senior Member
  • Senior Member
4 years 8 months ago #235768 by jaro_p
Homing for individual axes works without problems. Something needs to be adjusted for the homing all function. Unfortunately, I don't know what and how. But that probably won't be the main problem, I think.
After the reboot, linuxcnc reports an error in the following line:
net pos-x halui.axis.0.pos-feedback => xhc-hb04.x.pos-absolute
And this continues with an error in the next lines when I comment on the previous one.
4 years 8 months ago #235769 by phillc54
Replied by phillc54 on topic Linuxcnc 2.8.2 XHC-HB04 configuration
I think you need to specify a letter for the axis like below:
net pos-x halui.axis.x.pos-feedback => xhc-hb04.x.pos-absolute
linuxcnc.org/docs/2.8/html/man/man1/halui.1.html
4 years 8 months ago - 4 years 8 months ago #235773 by Aciera
Homing-Sequence:
To create a homing sequence you need to add this to the [JOINT_n] sections of the ini file:
HOME_SEQUENCE = 0
with the number (eg 0 in the above example) defining which joint will be homed first (ie 0), then the joints with sequence number 1 will be homed etc. Joints with identical sequence numbers will home at the same time.
See documentation:
linuxcnc.org/docs/2.8/html/config/ini-ho....html#_home_sequence
As for the other error:
It seems that you have copied some hal code from an earlier version of linuxcnc (ie < 2.8). So your pin names are not valid in version 2.8 anymore and you will need to adjust those as phillc54 has outlined.
  • jaro_p
  • Topic Author
  • Senior Member
  • Senior Member
4 years 8 months ago #235775 by jaro_p
Thanks! Axis jogging is already working.
I had to comment on the lines in which the spindle speed and feedrate change is defined.
# Wheel for feedrate and spindle
#setp halui.feed-override.scale 0.01
#net jog-counts => halui.feed-override.counts
#net jog-feed halui.feed-override.count-enable <= xhc-hb04.jog.enable-feed-override
#net jog-feed2 halui.feed-override.value => xhc-hb04.feed-override
#setp halui.spindle-override.scale 0.01
#net jog-counts => halui.spindle-override.counts
#net jog-spindle halui.spindle-override.count-enable <= xhc-hb04.jog.enable-spindle-override
#net jog-spindle2 halui.spindle-override.value => xhc-hb04.spindle-override
#net spindle-rps motion.spindle-speed-cmd-rps => xhc-hb04.spindle-rps
Can you please advise me what's wrong with these lines?
4 years 8 months ago - 4 years 8 months ago #235776 by Aciera
In the 'halui' documentation linked above you find that in current version all the pins concerning the spindle contain the spindle number as defined in the ini. (ie 0 for SPINDLE_0)
so this:
would need to be:
setp halui.spindle.0.override.scale 0.01
And so on for all the relevant pins.
As for the 'halui.feed-override.' pins, I'm not sure as these should be ok. Maybe try to delete the minus '-' and retype. There have been issues with copy/pasting pin names containing minus-hyphens.
  • jaro_p
  • Topic Author
  • Senior Member
  • Senior Member
4 years 8 months ago #236013 by jaro_p
Thank you for your answers. Unfortunately, when I correct one mistake, 10 more jump out.
It surprises me a little, because the instructions I followed were last edited on January 8, 2022. So it should be up to date.
4 years 8 months ago #236022 by Aciera
In that document there is a large header:
"Versions of LinuxCNC older than 2.6.0"
So if you used any of the links under that header then you get old pin names that will not work in version 2.8 and up or the pins have to be edited in the way pointed out above.
Time to create page: 0.076 seconds
