Another realtime delay question - Mesa card
- chienMouille
01 Jan 2024 15:40 - 01 Jan 2024 15:43 #289479
by chienMouille
Another realtime delay question - Mesa card was created by chienMouille
Hello, happy new year.
I have yet another question about realtime delay.
I have read quite a bunch but I don't seem to put two and two together.
So, I get the error message:
It seems really high doesn't it?
It's the servo thread, in my understanding.
here are my questions:
1- I'm running of a Mesa 7i95, so does this message even matter? I thought the mesa would do all the timing.
2- If it does, what to do? I have disable everything in Bios (or like all that seemed to be what was recommended on this forum).
3 -I have already set the base period of the servo thread much higher than default, as you see in the error message. I can't see any difference in the resulting parts machined. What kind of problem should appear? I'm running a milling machine with AC servos in position mode, with a stepscale of 3000 (and 400 for dirsetup, dirhold, steplen and stepspace). I also get feedback form 1um linear scales.
I don't understand the consequences of this problem, nor what to do at this point, except setting the servo thread even slower.
Thanks in advance!
Unexpected realtime delay on task 0 with period 1500000
Thanks in advance!
Last edit: 01 Jan 2024 15:43 by chienMouille. Reason: formatting
01 Jan 2024 15:50 #289481
Replied by PCW on topic Another realtime delay question - Mesa card
The Mesa card does all the timing _between_ servo thread invocations but does
depend are reliable communications every servo thread.
What host hardware are you running?
What are your ping times:
ping -c 4 -i .2 [ip_add]
sudo chrt 99 ping -i .001 -q [ip_add]
Let the last command run for about a minute and type control C to stop
The statistics after the last command is stopped are what are important'
[ip-add] is the mesa card IP address, probably 192.168.1.121 or 10.10.10.10
- chienMouille
01 Jan 2024 16:16 #289482
by chienMouille
Replied by chienMouille on topic Another realtime delay question - Mesa card
Host hardware is a shuttle XPC nano PC NC1010XA, which I bought new.
It has:
Processor:
Intel Celeron 4205U, Dual Core, 15 W TDP
Intel ULV “Whiskey-Lake-U” Generation
Integrated Intel UHD graphics 610, DX12
RAM:
4GB DDR4 SO-DIMM memory module
SSD:
128 GB M.2-2280 SATA SSD card
Results from the ping tests:
0.391ms
0.152ms
0.151ms
0.150ms
and
89386 packets transmitted, 89386 received, 0% packet loss, time 89386ms, rtt min/avg/max/mdev = 0.064/0.121/0.200/0.007ms
It has:
Processor:
RAM:
SSD:
0.391ms
0.152ms
0.151ms
0.150ms
and
01 Jan 2024 16:25 #289483
Ping looks OK, looks like that PC has an intel MAC, have you tried
disabling irq coalescing? (man hm2_eth)
- chienMouille
01 Jan 2024 16:40 - 01 Jan 2024 16:47 #289484
by chienMouille
ok, just to be sure, now the interfaces file looks like this:
# The loopback network interface
auto lo
iface lo inet loopback
shall I just add the following and reboot?:
auto eth1
iface eth1 inet static
address 10.10.10.10
hardware-irq-coalesce-rx-usecs 0
auto lo
auto eth1
address 10.10.10.10
Last edit: 01 Jan 2024 16:47 by chienMouille.
- chienMouille
01 Jan 2024 17:07 #289485
by chienMouille
So, I changed the interfaces file as I wrote above (not sure it's correct). I now get very similar results when running latency test. (max jitter of 218654 and 91808)
- Thank you received: 5934
01 Jan 2024 18:08 #289488
Replied by tommylight on topic Another realtime delay question - Mesa card
Address wrong, anything BUT 10 at the end, from 1 to 254, pick anything, just not 10.auto eth1
address 10.10.10.10
- chienMouille
01 Jan 2024 19:49 - 01 Jan 2024 20:14 #289504
by chienMouille
Ok, I did that.
I get now (after reboot) 126211 and 86039 jitter on latency test.
Still not great no?
EDIT: I still don't understand how much it matters (like now the servo jitter would be in the range of the timing I set in the ini, which is much higher than the default). Is that OK? When does it become critical? How much the timing of the PC plays in relation to the one of the Mesa card?
Still not great no?
Last edit: 01 Jan 2024 20:14 by chienMouille.
01 Jan 2024 20:29 #289510
The timing servo thread does not matter much, as long as
jitter plus communication delays do not cause loss of
communications from timeouts or real time delays.
02 Jan 2024 07:19 #289540
Replied by rodw on topic Another realtime delay question - Mesa card
Looks like this pc only has 2 cores. typing
echo $(nproc)
will confirm
in the bios, check that cstates is set to the minimum (cstates=1)
Assuming you are using the 2.9.2 ISO on the downloads page, set isolcpus=1
sudo grub-customizer
on the second tab where it says quiet, change it to quiet isolcpus=1
if you can't find cstates in you bios, make it
quiet processor.max_cstate=1 isolcpus=1
Save and reboot
See if latency has improved
echo $(nproc)
will confirm
Save and reboot
Time to create page: 0.094 seconds
