Another realtime delay question - Mesa card
- chienMouille
06 Jan 2024 05:00 #289924
by chienMouille
Replied by chienMouille on topic Another realtime delay question - Mesa card
Yes, no, I said I still get realtime error messages. Every session, at some point.
Should I raise the servo period to like 180000?
06 Jan 2024 07:09 #289931
Replied by rodw on topic Another realtime delay question - Mesa card
You can try my 6.3 kernel and headers
download and install both with sudo dpkg -i
drive.google.com/drive/folders/1NzQIHnf9...chOOxaER?usp=sharing
- Thank you received: 5966
06 Jan 2024 14:33 #289970
Replied by tommylight on topic Another realtime delay question - Mesa card
Servo period should be at least 1000000 ( 1 million), not 180000.Yes, no, I said I still get realtime error messages. Every session, at some point.
- chienMouille
06 Jan 2024 14:40 #289971
by chienMouille
Yes, sorry my bad I meant 1800000.
Would that be OK?
Would that be OK?
06 Jan 2024 16:38 #289979
Replied by PCW on topic Another realtime delay question - Mesa card
up to 2000000 is normally OK unless you have very high acceleration
- chienMouille
06 Jan 2024 19:56 #289993
by chienMouille
What is considered very high acceleration? I have this as max in the INI file:
Servos are set for a step dir command with 2000 pulses per rev (3000 stepscale).
MAX_VELOCITY = 40.0
MAX_ACCELERATION = 750.0
06 Jan 2024 20:35 #289998
That's quite low acceleration (if in mm/s^2) = ~0.08g
- chienMouille
07 Jan 2024 05:33 #290049
by chienMouille
That makes sense. I set up the speed by feel with the machine. It's plenty fast enough, like much faster than when it used to be a manual machine. But it's a dovetail mill, so the work envelop is rather small, say compared to a plasma cutter with long distances or a wood router which would need to be faster.
@rodw: Thank you for the link, I will try it later because I have a couple of time critical jobs to finish right now and don't want to risk to have the machine down for a while. I'll keep you updated!
- chienMouille
11 Jan 2024 10:31 #290416
by chienMouille
I haven't had any more realtime errors since raising the servo thread to 1800000.
Should I still seek to upgrade my HW or install rodw's kernel?
Thanks a lot everyone, your help is very precious.
11 Jan 2024 16:28 #290433
Unless you have an issue with motion, you should be fine.
The lower thread rate has no effect on maximum speed.
If you have very high acceleration the acceleration/
decceleration ramps will have fewer velocity steps at a
longer servo thread period, eventually a potential cause
of stalling.
of stalling.
Time to create page: 0.139 seconds
