- General
- Installing LinuxCNC
- Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
- cncnoob1979
- Topic Author
- Thank you received: 75
05 Apr 2017 02:49 #90911
by cncnoob1979
Replied by cncnoob1979 on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
Yes,
However you need to remove the version requirements and use the package names such as:
sudo apt-get install cdbs gnome-pkg-tools libxml2-dev libart-2.0-dev libglade2-dev libgnomecanvas2-dev libgnomeprint2.2-dev gtk-doc-tools intltool libglib2.0-doc libgtk2.0-doc
As you see I removed them from the names, do you understand that or do I need to clarify further?
- cncnoob1979
- Topic Author
05 Apr 2017 02:51 - 05 Apr 2017 02:52 #90912
by cncnoob1979
I'm not exactly sure why you need those particular dependencies. You have something unique to me.
Your doing fine on the install. I'm happy to help and you're quite welcome. You'll be up in no time. And you can fish all you want.
The trick is to keep asking questions.
Last edit: 05 Apr 2017 02:52 by cncnoob1979.
05 Apr 2017 02:52 #90913
Replied by rodw on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
[quoteelroy@elroy-Lenovo-V570 ~ $ dpkg-checkbuilddeps
dpkg-checkbuilddeps: error: Unmet build dependencies: cdbs (>= 0.4.41) gnome-pkg-tools (>= 0.10) libglade2-dev (>= 2.3.6-4) gtk-doc-tools intltool (>= 0.35.0) libglib2.0-doc libgtk2.0-doc
elroy@elroy-Lenovo-V570 ~ $[/quote]
This is what I kept running into. By using different repositories, you end up installing earlier versions of the packages when something else installs which requires a later version.
05 Apr 2017 03:56 #90914
by fjr122
Replied by fjr122 on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
Cncnoob: To answer your question "what was the solution in the end?" (from page 14ish)
I simply ran this:
After that all the dependencies were solved and everything compiled...
I simply ran this:
sudo apt-get install libgnomeprintui2.2-dev python-support tcl8.4-dev tk8.4-dev
05 Apr 2017 11:13 #90923
Replied by andypugh on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
Just a warning: I was a long way into the install process onto my
8GB SSD DOM drive
when it told me that it needed 9GB of space.
So make sure you have the room before starting the process
The following user(s) said Thank You: cncnoob1979
- cncnoob1979
- Topic Author
05 Apr 2017 12:09 #90927
by cncnoob1979
Thanks Andy,
Ill be sure to add this information to the first post to warn others.
08 Apr 2017 05:42 #91026
by Elroy
Replied by Elroy on topic Complete HOW-TO Linux Mint 18.1 32/64 PREEMPT with RIP or build a .deb
Ok.
Gave up on last installation and reinstalled every thing from scratch. Worked a lot better this time using MATE not CINNAMON. I also checked the registry and checksum before installing.blem
here is the new problem when trying to download Linuc CNC following the steps.
would anyone like to help me?
elroy@elroy-Lenovo-V570 ~ $ cd linuxcnc-dev
elroy@elroy-Lenovo-V570 ~/linuxcnc-dev $ cd debian
elroy@elroy-Lenovo-V570 ~/linuxcnc-dev/debian $ ./configure uspace
successfully configured for 'uspace-LinuxMint-18.1'-'uspace+xenomai'..
elroy@elroy-Lenovo-V570 ~/linuxcnc-dev/debian $ cd ..
elroy@elroy-Lenovo-V570 ~/linuxcnc-dev $ dpkg-checkbuilddeps
elroy@elroy-Lenovo-V570 ~/linuxcnc-dev $ linuxcnc-dev/src
bash: linuxcnc-dev/src: No such file or directory
elroy@elroy-Lenovo-V570 ~/linuxcnc-dev $ git checkout 2.7
Branch 2.7 set up to track remote branch 2.7 from origin.
Switched to a new branch '2.7'
elroy@elroy-Lenovo-V570 ~/linuxcnc-dev $ cd ..
elroy@elroy-Lenovo-V570 ~ $ linuxcnc-dev/src
bash: linuxcnc-dev/src: Is a directory
elroy@elroy-Lenovo-V570 ~ $ cd debian
bash: cd: debian: No such file or directory
08 Apr 2017 06:40 #91028
I think you've forgotten a git pull after the checkout so no folders or files are found but I am no expert.
08 Apr 2017 06:50 #91030
by PKM
Replied by PKM on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
You're trying to execute linuxcnc-dev/src
But you should be entering cd src at that point
08 Apr 2017 12:56 #91041
by Elroy
Replied by Elroy on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
So are the instructions wrong from post 2? I must be misunderstanding the instructions. Which are the following:
Once all build dependencies are satisfied you can complete the process. For a .deb install go into;
linuxcnc-dev/src
NOTE: You can issue a git-checkout to build something other than master. Such as:
git checkout 2.7
linuxcnc-dev/src
git checkout 2.7
- General
Time to create page: 0.270 seconds
