- General
- Installing LinuxCNC
- Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
05 Mar 2017 04:23 #89019
Replied by cmorley on topic Complete HOW-TO Linux Mint 18.1 32/64 PREEMPT with RIP or build a .deb
I just wanted to say I have been a developer for many years for linuxcnc and yet never had compiled a kernel.
This how to was excellent.
I actually think it should be added to the manual official.
Thanks for the hard work.
Chris M
Chris M
- cncnoob1979
- Topic Author
- Thank you received: 75
06 Mar 2017 13:25 #89093
by cncnoob1979
Replied by cncnoob1979 on topic Complete HOW-TO Linux Mint 18.1 32/64 PREEMPT with RIP or build a .deb
Thanks Chris, you're welcome,
I hope this help individuals get the installation complete without much trouble. Then they can concentrate on configuration of LinuxCNC.
Any suggestions or feedback is welcomed!
10 Mar 2017 02:30 #89315
by steveg
Replied by steveg on topic Complete HOW-TO Linux Mint 18.1 32/64 PREEMPT with RIP or build a .deb
Hi James I am having exactly the same problem ,first with 64 bit and now with 32 bit. I did find tcl8.4-dev and tk8.4-dev
quite easily though.
What do i need to do to find and install the other dependencies ?
Steve
Steve
- cncnoob1979
- Topic Author
10 Mar 2017 02:36 #89316
by cncnoob1979
Which dependencies are you looking for Steve?
If 32bit or 64 I can help you out
10 Mar 2017 02:48 #89317
by steveg
sorry for the incomplete post, libgnomeprintui2.2-dev and python-support and 32 bit
Steve
Steve
- cncnoob1979
- Topic Author
10 Mar 2017 02:54 - 10 Mar 2017 02:56 #89318
by cncnoob1979
Steve I have that covered in the first part of the first posting.
It's the preface of the posts
Add the repository listed there. The apt get install those your missing.
If you need further clarification or instructions let me know. You probably just missed it since it's not listed in the rest of the posts below it.
Last edit: 10 Mar 2017 02:56 by cncnoob1979.
10 Mar 2017 03:08 #89319
by steveg
Ah yes I did not see that as I'm doing a pre-empt install, and I do have an AMD64.
Thank You again
Steve
Thank You again
Steve
- cncnoob1979
- Topic Author
10 Mar 2017 03:17 #89320
by cncnoob1979
You're quite welcome.
10 Mar 2017 13:41 #89327
by PKM
Replied by PKM on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
Thanks for the excellent guide!
I eventually managed to get LinuxCNC running, but I've encountered some problems on the way.
First, I installed Mint 18.1 64-bit. It revealed severe problems with repositories, so I did not manage to install dependencies or compile the kernel. I tried sudo add-apt-repository 'deb mirrors.kernel.org/ubuntu precise main universe' but no success either.
So I surrendered and installed Mint 18.1 32-bit.
I chose the latest kernel with RT patch 4.9.13-rt12. It showed a few errors at make install stage (other than the described problem with intel drivers), but surprisingly the kernel installed OK!
When installing linuxcnc from source, dpkg-checkbuilddeps did not work at all.
Other than that, everything turned out pretty well.
Latency test shows 28K / 46K.
Thanks again!
Thanks again!
- cncnoob1979
- Topic Author
10 Mar 2017 14:58 #89332
by cncnoob1979
Replied by cncnoob1979 on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
What dependencies issue were you having? Was it libgnomeprintui2.2-dev and python-support? After adding the repo did you issue a [sudo apt-get update] to refresh the package listing?
The errors could be from virtual box, did you install 3rd party software during install? If so then these pass errors on the kernel build.
For the checking dependencies [dpkg-checkbuilddeps], will only work if you enable source code repositories and update the package listing, after configuring linuxcnc [in the /linuxcnc-dev/debian/ folder]
If you would like to go through this again I can help walk you through it.
- General
Time to create page: 0.204 seconds
