- General
- Installing LinuxCNC
- Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
16 Mar 2017 03:49 #89716
by fjr122
Replied by fjr122 on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
I'm sorry, but I'm still having issues..
I did as you instructed:
In the last step I get
Then I tried the following, because I don't really know the syntax.. anyways
The following packages have unmet dependencies:
linux-headers-3.4-9-rtai-686-pae:i386 : Depends: gcc-4.6:i386 but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
linuxcnc@linuxcnc ~ $ sudo apt-get install gcc-4.6:i386
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
gcc-4.6:i386 : Depends: binutils:i386 (>= 2.21.1) but it is not going to be installed
- cncnoob1979
- Topic Author
- Thank you received: 75
16 Mar 2017 03:54 #89718
by cncnoob1979
Replied by cncnoob1979 on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
You added the repo listed above first?
Then
sudo apt-get update prior to trying that step?
Then
16 Mar 2017 03:57 #89719
by fjr122
Yes, as instructed.. and gcc 4.6 installed successfully ..
I ran this command after typing the above post..
gcc-4.6 is already the newest version (4.6.3-1ubuntu5).
0 upgraded, 0 newly installed, 0 to remove and 547 not upgraded.
- cncnoob1979
- Topic Author
16 Mar 2017 03:57 - 16 Mar 2017 04:15 #89720
by cncnoob1979
Edit
Last edit: 16 Mar 2017 04:15 by cncnoob1979.
16 Mar 2017 04:01 #89721
by fjr122
Running another apt-get update, should be able to do that in 15min or so..
- cncnoob1979
- Topic Author
16 Mar 2017 04:07 - 16 Mar 2017 04:16 #89722
by cncnoob1979
Seems you might have a corruption issue with your wifi dongle. Are you able to connect hardwire for testing?
Can you take a picture of your repos listed in the package manager?
If you have the time update to the latest software via apt
Disable the repo you enabled earlier to prevent any possibilities of an issue. You can do that by unchecking the repo listed in the package manager.
Then run:
sudo apt-get dist-upgrade
You have 500+ packages that need updated.
Then run:
Last edit: 16 Mar 2017 04:16 by cncnoob1979.
- cncnoob1979
- Topic Author
16 Mar 2017 04:14 #89724
by cncnoob1979
Disregard the binutils above. gcc 4.6 is installed.
Try the kernel install again. It should install this time. (I would still update wether successful or not).
I didn't notice the :386 at the end of the apt command previously.
16 Mar 2017 04:28 #89725
by fjr122
Running the upgrade now: ... possibly should have been the first thing I did.. this should take a while..
~ $ sudo apt-get dist-upgrade
Calculating upgrade... Done
The following NEW packages will be installed:
autoconf automake autopoint dh-autoreconf gir1.2-appindicator3-0.1 gist
libgdm1 libruby2.3 libtag1v5:i386 libtool rake ruby ruby-did-you-mean
ruby-json ruby-minitest ruby-net-telnet ruby-power-assert ruby-test-unit
ruby2.3 rubygems-integration xapps-common
The following packages will be upgraded:
accountsservice apt apt-transport-https apt-utils apt-xapian-index
archdetect-deb base-files bash-completion bind9-host brasero brasero-cdrkit
brasero-common brltty bsdutils casper cinnamon cinnamon-common
command-not-found command-not-found-data console-setup console-setup-linux
cpp-5 cups-browsed cups-filters cups-filters-core-drivers curl dbus dbus-x11
debhelper desktop-file-utils dh-python distro-info-data dkms dmidecode
dnsmasq-base dnsutils dosfstools dpkg dpkg-dev ecryptfs-utils file-roller
firefox firefox-locale-en fontconfig fontconfig-config fonts-noto-cjk
fonts-opensymbol fuse fwupd g++-5 gcc-5 gcc-5-base gcc-5-base:i386 gdb
ghostscript ghostscript-x gimp gimp-data gir1.2-accountsservice-1.0
gir1.2-dbusmenu-glib-0.4 gir1.2-gdkpixbuf-2.0 gir1.2-gmenu-3.0
gir1.2-gst-plugins-base-1.0 gir1.2-gstreamer-1.0 gir1.2-gtk-3.0
gir1.2-javascriptcoregtk-3.0 gir1.2-networkmanager-1.0 gir1.2-nmgtk-1.0
gir1.2-packagekitglib-1.0 gir1.2-upowerglib-1.0 gir1.2-webkit-3.0
gir1.2-webkit2-3.0 glib-networking glib-networking:i386
glib-networking-common glib-networking-services gnome-calculator
gnome-font-viewer gnome-menus gnome-panel gnome-panel-data gnome-session-bin
gnome-settings-daemon gnome-settings-daemon-schemas gnome-system-monitor
gnupg gpgv graphviz grep grub-common grub-pc grub-pc-bin grub2-common
gstreamer0.10-gconf gstreamer0.10-plugins-good
gstreamer0.10-plugins-good:i386 gstreamer0.10-pulseaudio gstreamer1.0-alsa
gstreamer1.0-plugins-base gstreamer1.0-plugins-base-apps
gstreamer1.0-plugins-good gstreamer1.0-pulseaudio gstreamer1.0-tools
gstreamer1.0-x gtk2-engines-murrine gtk2-engines-murrine:i386 gufw gvfs
gvfs:i386 gvfs-backends gvfs-bin gvfs-common gvfs-daemons gvfs-fuse
gvfs-libs gvfs-libs:i386 ifupdown im-config imagemagick imagemagick-6.q16
imagemagick-common init init-system-helpers initramfs-tools
initramfs-tools-bin initramfs-tools-core isc-dhcp-client isc-dhcp-common kbd
keyboard-configuration klibc-utils kpartx kpartx-boot krb5-locales
language-pack-en language-pack-en-base language-pack-gnome-en
language-pack-gnome-en-base less libaccountsservice0 libapparmor1
libappindicator0.1-cil libappindicator1 libappindicator3-1
libappstream-glib8 libapt-inst2.0 libapt-pkg5.0 libarchive13 libasan2
libatomic1 libbind9-140 libblkid1 libboost-date-time1.58.0
libboost-filesystem1.58.0 libboost-iostreams1.58.0 libboost-python1.58-dev
libboost-python1.58.0 libboost-regex1.58.0 libboost-system1.58.0
libboost1.58-dev libbrasero-media3-1 libbrlapi0.6 libc-bin libc-dev-bin
libc6 libc6:i386 libc6-dbg libc6-dev libcaja-extension1 libcc1-0 libcdt5
libcgraph6 libcilkrts5 libcupsfilters1 libcupsfilters1:i386 libcurl3-gnutls
libdbus-1-3 libdbus-1-3:i386 libdbusmenu-glib4 libdbusmenu-gtk3-4
libdbusmenu-gtk4 libdebian-installer4 libdfu1 libdns-export162 libdns162
libdpkg-perl libdrm-amdgpu1 libdrm-amdgpu1:i386 libdrm-dev libdrm-intel1
libdrm-intel1:i386 libdrm-nouveau2 libdrm-nouveau2:i386 libdrm-radeon1
libdrm-radeon1:i386 libdrm2 libdrm2:i386 libecryptfs1 libegl1-mesa
libegl1-mesa-drivers libevent-2.0-5 libexiv2-14 libexpat1 libexpat1:i386
libexpat1-dev libfdisk1 libfontconfig1 libfontconfig1:i386
libfontconfig1-dev libfontembed1 libfuse2 libfwupd1 libgail-3-0 libgbm1
libgc1c2 libgcc-5-dev libgcrypt20 libgcrypt20:i386 libgd3 libgd3:i386
libgdk-pixbuf2.0-0:i386 libgdk-pixbuf2.0-0 libgdk-pixbuf2.0-common
libgdk-pixbuf2.0-dev libgfortran3 libgif7 libgimp2.0 libgl1-mesa-dev
libgl1-mesa-dri libgl1-mesa-dri:i386 libgl1-mesa-glx:i386 libgl1-mesa-glx
libglapi-mesa libglapi-mesa:i386 libgles1-mesa libgles2-mesa
libglib2.0-0:i386 libglib2.0-0 libglib2.0-bin libglib2.0-data libglib2.0-dev
libgnome-menu-3-0 libgnutls-openssl27 libgnutls30 libgnutls30:i386 libgomp1
libgs9 libgs9-common libgssapi-krb5-2 libgssapi-krb5-2:i386
libgstreamer-plugins-base1.0-0 libgstreamer-plugins-base1.0-0:i386
libgstreamer-plugins-good1.0-0 libgstreamer1.0-0 libgstreamer1.0-0:i386
libgtk-3-0 libgtk-3-bin libgtk-3-common libgvc6 libgvpr2 libgweather-3-6
libgweather-common libharfbuzz-dev libharfbuzz-gobject0 libharfbuzz-icu0
libharfbuzz0b libharfbuzz0b:i386 libhogweed4 libhogweed4:i386 libicu55
libicu55:i386 libidn11 libidn11:i386 libimobiledevice-utils
libimobiledevice6 libisc-export160 libisc160 libisccc140 libisccfg140
libitm1 libjavascriptcoregtk-1.0-0 libjavascriptcoregtk-3.0-0
libjavascriptcoregtk-4.0-18 libjpeg-progs libjpeg9 libk5crypto3
libk5crypto3:i386 libklibc libkrb5-3 libkrb5-3:i386 libkrb5support0
libkrb5support0:i386 libksba8 libldap-2.4-2 libllvm3.8 libllvm3.8:i386
liblsan0 liblwres141 libmagick++-6.q16-5v5 libmagickcore-6.q16-2
libmagickwand-6.q16-2 libmetacity-private3a libmount1 libmpx0
libnautilus-extension1a libndp0 libnettle6 libnettle6:i386 libnm-glib-vpn1
libnm-glib4 libnm-gtk-common libnm-gtk0 libnm-util2 libnm0 libnma-common
libnma0 libnspr4 libnspr4:i386 libnss3 libnss3:i386 libnss3-1d libnss3-nssdb
libnux-4.0-common libopenobex2 libp11-kit0 libp11-kit0:i386
libpackagekit-glib2-16 libpam-systemd libpanel-applet0 libpathplan4
libpcsclite1 libplymouth4 libpoppler-glib8 libpoppler58 libprocps4
libpulse-mainloop-glib0 libpulse-mainloop-glib0:i386 libpulse0
libpulse0:i386 libpulsedsp libpulsedsp:i386 libpurple-bin libpurple0
libpython2.7 libpython2.7-dev libpython2.7-minimal libpython2.7-stdlib
libpython3.5 libpython3.5-minimal libpython3.5-stdlib libqt5core5a
libqt5dbus5 libqt5gui5 libqt5network5 libqt5opengl5 libqt5printsupport5
libqt5sql5 libqt5sql5-sqlite libqt5widgets5 libqt5xml5 libquadmath0
libreoffice-avmedia-backend-gstreamer libreoffice-base libreoffice-base-core
libreoffice-base-drivers libreoffice-calc libreoffice-common
libreoffice-core libreoffice-draw libreoffice-gnome libreoffice-gtk
libreoffice-help-en-us libreoffice-impress libreoffice-java-common
libreoffice-math libreoffice-ogltrans libreoffice-pdfimport
libreoffice-sdbc-firebird libreoffice-sdbc-hsqldb libreoffice-writer
libservlet3.1-java libsmartcols1 libsmbclient libssl-dev libssl1.0.0
libssl1.0.0:i386 libstdc++-5-dev libstdc++6 libstdc++6:i386 libsystemd0
libsystemd0:i386 libtasn1-6 libtasn1-6:i386 libtevent0 libtiff5
libtiff5:i386 libtsan0 libubsan0 libudev-dev libudev1 libudev1:i386
libunity-protocol-private0 libunity-scopes-json-def-desktop libunity9
libupower-glib3 libusbmuxd4 libuuid1 libuuid1:i386 libwayland-egl1-mesa
libwbclient0 libwebkit2gtk-3.0-25 libwebkit2gtk-4.0-37 libwebkitgtk-1.0-0
libwebkitgtk-1.0-common libwebkitgtk-3.0-0 libwebkitgtk-3.0-common
libwnck-common libwnck22 libxatracker2 libxml2 libxml2:i386 libxml2-utils
libxpm-dev libxpm4 libxpm4:i386 linux-firmware linux-libc-dev locales
lsb-base lsb-release lshw mesa-common-dev metacity metacity-common
mint-artwork-common mint-meta-cinnamon mint-meta-core mint-mirrors
mint-themes-gtk3 mint-upgrade-info mint-x-icons mint-y-theme mintbackup
mintdrivers mintinstall mintsources mintsystem mintupdate mintupload
mintwelcome mount mtools mtr-tiny multiarch-support nano nautilus-data
network-manager network-manager-gnome network-manager-openvpn
network-manager-openvpn-gnome ntfs-3g ntp ntpdate nux-tools
nvidia-prime-applet openjdk-8-jre openjdk-8-jre-headless openssh-client
openssl os-prober p11-kit p11-kit-modules pidgin pidgin-data pix pix-data
plymouth plymouth-label plymouth-theme-ubuntu-text poppler-utils
printer-driver-brlaser procps pulseaudio pulseaudio-module-bluetooth
pulseaudio-module-x11 pulseaudio-utils python-crypto python-cryptography
python-imaging python-libxml2 python-pil python-pil.imagetk python-samba
python2.7 python2.7-dev python2.7-minimal python3-brlapi
python3-commandnotfound python3-crypto python3-cryptography python3-pil
python3-uno python3-urllib3 python3.5 python3.5-minimal resolvconf
samba-common samba-common-bin samba-libs shared-mime-info smbclient sni-qt
ssh-askpass-gnome sudo systemd systemd-sysv tar tcpdump thermald thunderbird
thunderbird-gnome-support tzdata ubuntu-drivers-common
ubuntu-system-adjustments udev unattended-upgrades uno-libs3 upower upstart
ure util-linux uuid-runtime vim-common vim-tiny vino virtualbox-guest-dkms
virtualbox-guest-utils virtualbox-guest-x11 wget xdg-utils xinit
xserver-common xserver-xorg-core xserver-xorg-video-amdgpu
xserver-xorg-video-intel xviewer
546 upgraded, 21 newly installed, 0 to remove and 0 not upgraded.
Need to get 652 MB of archives.
After this operation, 131 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
16 Mar 2017 05:24 #89728
by fjr122
Ok, I did the dist-upgrade..
The problem still persists..
16 Mar 2017 10:28 #89736
Replied by rodw on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
When I go back and review your original post about this error
It seems to me you are trying to install a 64 bit 686 library on a 32 bit 386 system but I am really a Linux noob so could be way off.
I think if you do have a 386 system, you would be better sticking with the standard Wheezy ISO. It implies you have older hardware that is most likely to be supported by the older OS. I found on a 32 bit system that when I moved from Wheezy to Jessie, to install the PREEMPTIVE kernel, the latency rendered the system unusable. I suspect that Mint may put some stress on old hardware so you may end up retreating away from Mint anyway. To solve my problems, I upgraded to 64 bit hardware but then had ongoing issues with Jessie due to lack of driver support. Based on all sorts of advice, I ended up with broken dependencies and realised I had to reinstall the OS. The switch to Mint solved this totally. So don't give up yet, others have also had a rocky journey to get a working system.
linux-headers-3.4-9-rtai-686-pae:i386 : Depends: gcc-4.6:i386 but it is not installable
- General
Time to create page: 0.209 seconds
