- General
- Installing LinuxCNC
- Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
16 Mar 2017 18:27 #89762
by fjr122
Replied by fjr122 on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
I don't think it's my hardware being too old or slow or not 64bit compatible.
I'm using a Dell Optiplex 380 with a 3ghz Core2Duo processor and 4gb of ram.
I could have a better video card (using the motherboard at the moment).
Mint itself works fine and is entirely as responsive as you would hope.
I am a little confused that I am hung up on an i386 package with a 64bit OS and processor though...
16 Mar 2017 19:52 #89779
Replied by PCW on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
Is this because you are trying to install a 32 bit RTAI kernel on a 64 bit OS?
The following user(s) said Thank You: cncnoob1979
16 Mar 2017 20:23 #89782
PCW might be on to something
Which of these 2 lines did you choose in Post 3 or did you run both lines?
You should run the first and only the first on your 64 bit PC.....
Replied by rodw on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
sudo apt-get install linux-image-4.1.0-1-rtai-amd64 [64bit only]
sudo apt-get install linux-image-4.1.0-1-rtai-686-pae [32bit only]
- cncnoob1979
- Topic Author
- Thank you received: 75
16 Mar 2017 22:09 #89784
by cncnoob1979
Replied by cncnoob1979 on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
After a phone call we did determine the issue was in fact 32bit RTAI kernel being installed into a 64bit Linux Mint distro.
To fix the issue we do have to install the 64bit rtai kernel or install a 32bit Linux Mint edition.
Any 64bit OS must use a 64bit kernel and vice versa for 32bit.
The problem with gcc 6.4 is/was still valid since I found this on my own rig with 4.0 RTAI kernel installed. But I had not installed the 3.4.9 since originally testing it.
17 Mar 2017 00:36 #89786
Its good combined wisdom drilled down to the issue. If it were me, at this stage, I would start right from the beginning and reinstall Linux Mint 64 bit from scratch. Whilst it will take time, the risk of broken dependencies may remain so a bit of time spent now might be better in the long run.
- cncnoob1979
- Topic Author
17 Mar 2017 00:40 - 17 Mar 2017 00:47 #89787
by cncnoob1979
His dependencies are ok. None are broken.
He just needs to start at x64 RTAI install. I suggested he try 4.1.0. I'm using it myself so far. But I'm on 32 bit. Anyone else try the 64bit 4.1.0?
If he really wants it easy I would just do 32 bit 18.1 mate.
It's really easy on you
Last edit: 17 Mar 2017 00:47 by cncnoob1979.
17 Mar 2017 00:53 #89788
- Thank you received: 5935
17 Mar 2017 00:55 #89789
Replied by tommylight on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
I did, i did all the installs from your tutorial, always with the newest kernel you listed. Had no problems with any of them. A 64bit version imstill have on a core2quad, did a lot of testing on it with a Mesa 7i92, litle with 7i76E. The only issue i noticed and could not get rid off was with google chrome and playing youtbe, it would freeze as soon as it started to play. Reboot.
On firefox i have youtube all the time listening to music, rock solid editing configs and runing Linuxcnc while playing. Also did a torture test playing 3 4k hd videos on youtube, a hd movie on movie player, another on vlc, latency histogram with 20 glxgears, not a single issue, running Linuxcnc with all those videos no issues and no real time delays for hours.
Again, thank you very much for a very clear and concise tutorial, it saved me a lot of time.
- cncnoob1979
- Topic Author
17 Mar 2017 01:04 #89790
by cncnoob1979
Was there a 3.4.9 amd64 bit kernel? I thought there was??
At one point I thought amd64 was breaking build bot... but I believed we had a 64bit RTAI kernel.
17 Mar 2017 01:11 #89791
Never seen that. I had to install 3.18.x on one of my laptops last year, it was the only one i could install on Linux Mint 17.2 64 bit, stil have it in use every day......till i get some time to do a 18.1.
- General
Time to create page: 0.131 seconds
