LinuxCNC on Debian Stretch
- Thank you received: 5246
RTAI is still better for software step systems in most cases, though Preempt-RT can be very good on faster hardware.
Where external hardware does step generation, PWM generation,encoder counting etc RTAI doesn't really have
any advantages over Preempt-RT and is significantly harder to support
- tjmarch
- Thank you received: 22
sudo apt-key adv --keyserver hkp://keys.gnupg.net --recv-key E0EE663E
I get error;
gpg: keyserver receive failed: no dirmngr
so I did
sudo apt-get install dirmngr
and tried again
and got error;
gpg: ketserver receive failed: Server indicated a failure
Tried to find a cure on Web with no luck, also tried it with Debian Cinnamon Live edition same failed twice same results
Tim
- 10K
- Thank you received: 33
LIke you, I installed Stretch. I then added the rt kernel. I put in linuxcnc-uspace, but not from the buildbot. Here's what I did, in case it helps.
sudo apt-key adv --keyserver hkp://keys.gnupg.net --recv-key 3cb9fd148f374fef
Required version of libboost-python is not in stretch repository. Temporarily point to jessie
sudo nano /etc/apt/sources.list with nano to contain:
deb http://ftp.us.debian.org/debian jessie main
sudo apt-get update
sudo apt-get install linuxcnc-uspace
Now remove the pointer to jessie in sources.list
sudo apt-get updateI did get it all working.
- Thank you received: 1454
Monday morning I want to try plugging that HD into another old P4 system with an ISA card, and see if it works. That system has been running Lucid fine for a long time, but I can't get the Wheezy ISO to work at all on that machine.
- tjmarch
Thanks Mr Kennedy
Tim March
- grump
- Thank you received: 10
Without failure to this date, why mess with a struggle when there is no need to?
I too was installing from here, there and everywhere, adding and deleting as was my want.
The latest version 7 has even picked up mt wifi card which until now I always had to install separately.
I would recommend this route above all at the moment.
Still not so keen on the xfce DE and all the other stuff that comes with it but that is only personal preference and soon changed.
www.linuxcnc.org/testing-stretch-amd64-rtpreempt/
- 10K
I have the following versions:
Debian 4.11.6-1 (i386)
Kernel 4.11.0-1-rt-686-pae
LinuxCNC 1.2.7.9
Gmoccapy 1.5.7
I'm getting really good latency times. The new 4.11 RT kernel works a little better than the 4.9 that I was using. I'm getting latencies around 2,500 average and infrequent peaks of 15,000.
I was getting occasional latency spikes of over 1,000,000 that played havoc with LinuxCNC. I had to do three things to address this:
Change GRUB to boot with isocpus=1
BIOS - Disable Intel Dynamic Power Technology
BIOS - Set the fan speed to constant instead of adaptive. (Thanks to arceye for mentioning this in a post. I had never seen it anywhere else.)
I have one additional problem that I think I understand. If I load up LinuxCNC right after booting, I may get a latency spike and error message. I don't get this (yet) it I wait a couple of minutes for Linux to do whatever it does after it first boots. I just got this working last week, so I'm still in testing mode. In any case, doing the three things above has improved the problem immensely.
Like you, I've had trouble with Intel network drivers. I've had to round up iwlwifi-7265D-23.ucode, -24, -25, and -26 driver files. With the latest Debain update, it now wants -27 and -28 drivers. (These can be found at github.com/NetBit73/NeteXt73_pakiety/tree/master/iwlwifi) I'll have to install those when I get a chance.
Just for shits and giggles I gave the new Stretch ISO a whirl on an old P4 system, and I actually got better latency score numbers than I had been seeing with the Wheezy RTAI ISO. (Not great, but possibly usable numbers).
This was a dismal failure, for me The machine (an old 2.8GHz P4 with ISA slots 1G ram) performed pathetically with the HD I set up on another old 2.4GHz P4. The ISA slotted machine would not even plot lines on the latency plot screen, everything was either over or under runs. By comparison the slower machine I setup the disk on, was showing max latency of about 35us. So I plugged the Lucid disk back in. I wish I understood why that old machine refuses to work with any of the newer kernels.
- grump
Since this resource has been made available I have tried and tested every edition to the current version 7.
Looks like it has been taken down, didn't last long did it?
- skunkworks
- Thank you received: 152
