LinuxCNC on Debian Stretch
25 Oct 2017 14:00 #100793
Replied by PCW on topic LinuxCNC on Debian Stretch
Did you use this exact command line?
./configure --with-realtime=uspace
The following user(s) said Thank You: emcPT
25 Oct 2017 16:11 #100798
by emcPT
Replied by emcPT on topic LinuxCNC on Debian Stretch
Thank you very much
16 Nov 2017 08:37 #101882
by vre
Replied by vre on topic LinuxCNC on Debian Stretch
I had a wheezy rtai kernel linuxcnc 2.7 installation and i had base thread jitter 15us.
My hdd died and i have installed to the same system stretch rt-preempt kernel and now i have 140us jitter.
The system is an atom board asrock Q1900M pro 3.
My question is if there is rtai kernel for stretch ?
- Thank you received: 1369
16 Nov 2017 15:12 #101899
Replied by Todd Zuercher on topic LinuxCNC on Debian Stretch
No there is not (that I'm aware of.)
Why do you think you need Stretch over Wheezy?
There was an experimental RTAI kernel for testing in Jessie, but it had some issues and you will need to compile Linuxcnc yourself if you want up to date versions of Linuxcnc, because it isn't currently supported on buildbot. But there are old outdated (pre J/A Master) builds for it there, that you could at least use for testing latency.
26 Nov 2018 00:25 #121357
by dvina
Replied by dvina on topic LinuxCNC on Debian Stretch
I also have the value of Jitter increased from 7,000 to 40,000 when moving from Debian Wheezy i386 to Stretch amd64
- Thank you received: 5943
26 Nov 2018 22:59 - 28 Nov 2018 09:32 #121415
Replied by tommylight on topic LinuxCNC on Debian Stretch
For whoever is using Stretch with preempt-rt, add more memory, a lot more memory.
This was tested on a Dell Optiplex 790, with 2Gb or ram it did 110000 in latency, with 8 GB it does 44000.
Edited the model number, it was written as 780.
Last edit: 28 Nov 2018 09:32 by tommylight. Reason: Error in model number
27 Nov 2018 19:43 #121485
by Zuikkis
Replied by Zuikkis on topic LinuxCNC on Debian Stretch
Memory should have no effect, unless it's some memory bank issue that 8GB allows parallel access to different banks and 2GB doesn't? Many motherboards have two different colored memory slots, you need to fill them in correct order to get full memory speed.
I have been using stretch for a year now. I too needed to increase jitter values quite a lot. But this is my daily desktop machine, so it's a trade off between linuxcnc and other work, and I feel that it's still worth it.
28 Nov 2018 09:37 #121518
Fixed the model number of the Dell computer, i own plenty of 780 so i wrote that by mistake.
The test was done on a 790.
Unfortunately leaving the latency test on while the PC is on an in use for several days, it occasionally gets the 200000 range spikes.
Time to create page: 0.139 seconds
