Keeping Linuxcnc 2.9 current on Debian Bookworm
12 Jun 2023 01:55 - 19 Jun 2023 02:31 #273362
Keeping Linuxcnc 2.9 current on Debian Bookworm was created by rodw
This is now superceded as its in the 2.9 documents now.
Please refer to this link instead. linuxcnc.org/docs/2.9/html/getting-start...etting-linuxcnc.html
Debian Bookworm is now the official stable release of Debian. Yay!!!
But the version of linuxcnc in Bookworm is not current due to the freeze policy leading up to the release.
Lets fix that so you can upgrade to the latest 2.9 at any time.
These steps assume you already have installed linuxcnc from the Debian Bookworm
1. Download the attached file.
2. Rename it to delete the .txt extension which is just there to fool the forum
3. Open a terminal window
4. Follow the steps in the comments at the top of the file repeated here for convenience:
[/code]
cd ~/Downloads
wget http://buildbot2.highlab.com/buildbot-archive-key.gpg
sudo cp ./buildbot-archive-key.gpg /etc/apt/trusted.gpg.d
sudo cp ./99linuxcnc-uspace /etc/apt/preferences.d/
sudo echo "deb http://buildbot2.highlab.com/debian/ bookworm 2.9-uspace" | sudo tee -a /etc/apt/sources.list
sudo apt update
sudo apt upgrade
Anytime you want to update to the latest version of Linuxcnc 2.9 all you have to do is type
[code]sudo apt update
sudo apt upgrade
Note:
1. Bullsye users can also enjoy this method by substituting the 5th line with the Bullseye line above
2. You can update to Master branch Version 2.10 by changing 2.9-uspace to master-uspace in the 5th line above
3. If you have already used this method to install V 2.9, edit the /etc/apt/sources.list manually as it won't be cool to have duplicate lines in this critical linux config file.
3. Please take care to follow these steps precisely so you don't erase your sources.list file like I did!
Last edit: 19 Jun 2023 02:31 by rodw.
12 Jun 2023 01:58 #273363
Replied by rodw on topic Keeping Linuxcnc 2.9 current on Debian Bookworm
If you have not yet installed linuxcnc from the repos, after the steps above, simply type these commands
sudo apt update
sudo apt install linuxcnc-uspace linuxcnc-uspace-dev
The following user(s) said Thank You: tommylight, DanRoscigno
- Thank you received: 5932
13 Jun 2023 20:16 #273512
Replied by tommylight on topic Keeping Linuxcnc 2.9 current on Debian Bookworm
Made this sticky for now.
Sorry for the delay, family health issues.
The following user(s) said Thank You: rodw, my1987toyota
- my1987toyota
- Thank you received: 271
13 Jun 2023 22:02 #273517
by my1987toyota
Replied by my1987toyota on topic Keeping Linuxcnc 2.9 current on Debian Bookworm
I hope things get better tommylight.
13 Jun 2023 23:01 - 19 Jun 2023 02:36 #273522
Please refer to this link instead. linuxcnc.org/docs/2.9/html/getting-start...etting-linuxcnc.htmlI hope things get better tommylight.
x 2
Last edit: 19 Jun 2023 02:36 by rodw.
14 Jun 2023 09:33 #273538
by xu
Replied by xu on topic Keeping Linuxcnc 2.9 current on Debian Bookworm
敬爱的 rodw
Debian Bookworm 全新安装后 网络安装 ethercat1.5 失败 您能查找下原因吗?
14 Jun 2023 20:36 #273552
by aabtech
Replied by aabtech on topic Keeping Linuxcnc 2.9 current on Debian Bookworm
sudo apt update
please can you use the above command
To install LinuxCNC on Linuxmint 21.1
15 Jun 2023 00:15 #273560
I don't believe so. The instructions are for Debian Bookworm. This method may let you install from the Linuxcnc Buildbot on mint.with some modifications.sudo apt update
17 Jun 2023 22:00 #273753
@Rod,
There is the line with 99linuxcnc-uspace that fails since there is no info on creating that file.
The installation works without it, and updates work properly.
For anyone interested in creating that file, go to Rod's howto
vmnet.com.au/linuxcnc/getting-linuxcnc.h...an_bookworm_x86_only
On a side note:
I HATE DEBIAN!
Why the hell does it have (and insists on using) Raspberry Pi stuff???
To be clear, i used the Hybrid version with Mate desktop environment, so others versions might not have this issue.
The issue:
-Installs OK
-Updates and upgrades OK
-While installing LinuxCNC, it also installs the RT kernel.
-LinuxCNC installs and works OK
-It hangs on kernel install complaining about "raspi" stuff missing
Solution:
-Open terminal
-type sudo caja
-open /etc/ folder
-Press ctrl+f and type z50*
-it will find 3 files, delete all 3
-do a sudo apt upgrade again
Everything works, so far.
On a side note:
I HATE DEBIAN!
The issue:
-Installs OK
Solution:
-Open terminal
-type sudo caja
-open /etc/ folder
17 Jun 2023 22:29 #273754
Thanks for the feedback Tommy. the file name with 99 in the line below is deliberate and apparently follows best practice.
Nano will create the file when you save it.
The old 2.8 docs included Pi installation so we retained it. I see many people struggling with the Pi, yet Debian has a solution to install it and latency is acceptable. This has worked since the release of Bullsye so hardly new.
The pull request to put this in the 2.9 docs is here
github.com/LinuxCNC/linuxcnc/pull/2522
Yes, I am not too fond of the Debian desktop but have stuck with xfce which is what Linuxcnc has always used.
sudo nano /etc/apt/preferences.d/99linuxcnc-uspace
Time to create page: 0.133 seconds
