Problem install linuxcnc 2.9.1 RTAI on linux mint debian 6
- Thank you received: 5946
19 Dec 2023 06:23 #288548
Replied by tommylight on topic Problem install linuxcnc 2.9.1 RTAI on linux mint debian 6
Might be just that RTAI does not like some hardware you have, it is especially picky about graphic cards, had several instances where it would stick to lower resolution and no amount of editing xorg helped. Once, only on one PC it would boot fully but the screen would be totaly black.
The following user(s) said Thank You: Ismacr63
19 Dec 2023 22:31 #288621
by Ismacr63
I am using a gigabyte h110m ds2 motherboard with i3 6100 processor and 16gb ram. here linuxcnc rtai blocks the pc when starting the latency test or linuxcnc rtai itself. I have installed a pci graphics card but with the rtai kernel it does not start linux. If you start with the grain broth. I have tested on a gigabyte h61m s2pv motherboard with i3 3220 processor, 8gb of ram and linuxcnc 2.9.1 rtai works perfectly with a latency of 9k. Is there an easy way to tell what hardware is causing the problem?
Replied by Ismacr63 on topic Problem install linuxcnc 2.9.1 RTAI on linux mint debian 6
19 Dec 2023 23:17 #288625
Replied by rodw on topic Problem install linuxcnc 2.9.1 RTAI on linux mint debian 6
RTAI is old and unmaintained. Its a credit to the guys that they haev been able to keep it going for Linuxcnc for so long.
I would revert to the Debian version on the lhe downloads page linuxcnc.org/downloads/
Please read what it says about RTAI
You will note that is on Debian buster. LMDE is a much more recent kernel and I doubt it would be compatible with LMDE6
19 Dec 2023 23:51 #288627
by cornholio
Replied by cornholio on topic Problem install linuxcnc 2.9.1 RTAI on linux mint debian 6
The latest RTAI kernel packages are dated October 29 of this year, so I wouldn't call that old or unmaintained. In actual fact Rod I installed LMDE6 and the RTAI kernel packages on linuxcnc.org in a virtual machine and it booted fine.
I'd start latency-histogram form the command line and see what messages you get. Like I said when I first tried start latency histogram I got an error message, but after running halrun -U then rerunning it the latency-histogram started fine.
20 Dec 2023 00:29 #288631
by Ismacr63
that's how it is. My problem is with the gigabyte h110m ds2 motherboard.
With the gigabyte h61m s2pv motherboard it worked the first time and everything was perfect without errors with a latency of 9k, as I said before, which for me using a parallel port is very necessary.
I need to try to get it to work on the h100m board since the other motherboard is not mine.
20 Dec 2023 00:51 #288634
Since you already have it installed, enter the BIOS settings and try disabling stuff, one by one, it would be nice if you bump into something that helps with these situations.
On very old PC's there was a BIOS setting named "A12 gate" and when left at normal it would cause all kinds of weird stuff in Windows, setting that to fast was a must back then.
20 Dec 2023 05:33 - 20 Dec 2023 05:34 #288642
by cornholio
Geesh I haven't seen mention of that option in years.....The Acer Core 2 Duo I have from 2007 doesn't even have that option.
Wasn't your last play with windows was Win11 on a 486 or some such act of self harm ?
Last edit: 20 Dec 2023 05:34 by cornholio.
20 Dec 2023 07:43 #288643
Did you read this on the downloads page?
The more adventurous can install the Bookworm ISO and then install the experimental RTAI kernel as described in 2.9 documents The kernel-mode RTAI installation can not be used with Mesa Ethernet-interfaced cards. There is not currently a packaged LinuxCNC application image for RTAI (work in progress) but building from source is supported and working.
I have got no interest in the RTAI kernel. I have never attempted to use it.
I think you will find it was reworked in October by one of the linuxcnc devs.The latest RTAI kernel packages are dated October 29 of this year, so I wouldn't call that old or unmaintained.
20 Dec 2023 08:10 - 20 Dec 2023 08:11 #288649
by cornholio
Sure are RTAI packages.
www.linuxcnc.org/dists/bookworm/2.9-rt/binary-amd64/
Even linked to them here forum.linuxcnc.org/9-installing-linuxcnc...ian-6?start=0#288532
dsc file lists linux-headers-5.4.258-rtai-amd64 as a dep.
Last edit: 20 Dec 2023 08:11 by cornholio.
20 Dec 2023 16:23 #288672
Got most views from it, despite failing, so people love failures!?!?!
LOL, it was XP on 486!
Time to create page: 0.182 seconds
