26 Dec 2017 10:48 #103631 by andypugh
This is interesting (And a little surprising as gmoccapy is a German GUI :-)
Can you try one of the sim/axis configs and see if the same problem exists there? I think it probably will as both use the same preview widget (hal_gremlin)
If it does, then I think it is something for the bug tracker:
github.com/LinuxCNC/linuxcnc/issues
26 Dec 2017 13:40 - 26 Dec 2017 13:40 #103648 by kjacobs
This German is surprised too :)
Axis is actually fine with de_DE.utf8, as I said in my P.S. It seems to be an issue of gmoccapy only. Actually, gmoccapy shows a period as the decimal separator everywhere inspite of the de_DE locale setting (and even complains about G0 X10,5), but the G5X page shows commas and gets confused with a period.
A quick fix is of course to set LC_NUMERIC=en_US.utf8 or LC_NUMERIC=C and leave the rest of the locale settings as is.
Maybe the german author of gmoccapy can chime in sometime.
Last edit: 26 Dec 2017 13:40 by kjacobs. Reason: typo
26 Dec 2017 14:20 #103651 by Weiler810T
My Weiler Lathe with Sinumerik 810t I have to go too G0 X5.0 Z-1.0 nix shows commas ;)
27 Dec 2017 07:11 #103732 by newbynobi
Hallo,
That is the first hint to go on searching the offset in the preview. If that is really a "komma" bug, it should be possible to find. Could you please test if the offset also happen with gscreen?
IMHO Axis uses a slightly different preview but gscreen and gmoccapy do share the same code.
Unfortunately I must tell you, that I will not invest too much time in this, as actually I am building gmoccapy to support 9 axis and at the same time, I am separating GUI and handling code. This will result in gmoccapy 3.0 or even "minos" (the future replacement).
You may ask why to change all the code? Because after this it is much easier to change the GUI part and replace also the underlaying widget base, i.e. from glade to Qt.
Norbert
The following user(s) said Thank You: giz
27 Dec 2017 08:50 #103739 by kjacobs
Hallo Norbert,
I just checked that gscreen has the same offset issue with de_DE.utf8 as gmoccapy. There is really no need to put much work into this as setting LC_NUMERIC differently is not a problem at all, at least for my application. Exciting news that you are working on a new version and going from glade to Qt. I am looking forward to that!
Cheers,
Karl
01 Jan 2018 02:19 #103919 by grijalvap
hi
does anybody know how I can connect the DRO input to a different pin other than the default Z axis?
01 Jan 2018 11:21 #103921 by newbynobi
What are you trying to do?
All can be done in the gmoccapy python file,
but without more details no one will be able to help.
What gmoccapy release?
What config?
What distro?
What purpose?
Norbert
01 Jan 2018 19:20 - 01 Jan 2018 20:56 #103935 by grijalvap
HI
Happy new year to all.
I have created a kind of stand-alone THC component for plasma.
forum.linuxcnc.org/plasma-laser/32555-do...nent?start=20#103768
This component does not work with the motion controller.
However, I really like to show the step generator feedback on the DRO & Plot
I'm working on the master branch with the debian distro.
thanks...
Last edit: 01 Jan 2018 20:56 by grijalvap.
02 Jan 2018 09:57 #103948 by newbynobi
I just looked in the sample INI you referenced too.
It is an axis config, so may your comment is in the wrong thread?
Norbert
02 Jan 2018 15:50 #103952 by grijalvap
Well, I have a very limited knowledge of the Gmocaapy GUI.
As I see in a normal configuration the feedback from step generator should be connected to
joint.x.motor-post-fb
net x-pos-fb <= hm2_5i25.0.stepgen.00.position-fb
net x-pos-fb => joint.0.motor-pos-fb
however, I don't want to connect mine to a joint, I want to connect directly to DRO
thanks..
Moderators: newbynobiHansU
Time to create page: 0.201 seconds
