15 Feb 2017 21:59 #88016
by Patrik T
Replied by Patrik T on topic Gmoccapy - A new screen for linuxcnc
Hi Norbert
Thanks for making Gmoccapy, and thanks for helping me.
I thought this would be easy to fix when i knew what to look for, but I have removed all the custom hal files like this:
I don't think I have made any changes in emco-lathe-gmoccapy.hal. Anyway, I have commented out everything but this:
Still getting the startup warning. I don't know what else I can disable to locate the error.
Patrik
[HAL]
HALUI = halui
HALFILE = emco-lathe-gmoccapy.hal
;HALFILE = joypad.hal
;HALFILE = custom.hal
;POSTGUI_HALFILE = custom_postgui.hal
# I also commented out the ui handler python script.
[DISPLAY]
;EMBED_TAB_NAME = xbox_1
;EMBED_TAB_LOCATION = box_left
;EMBED_TAB_COMMAND = gladevcp -u myuihandler.py -x {XID} xboxgui.ui
# Generated by stepconf 1.1 at Sun Jan 22 06:31:44 2017
# overwritten when you run stepconf again
loadrt trivkins
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt hal_parport cfg="0x378 out"
setp parport.0.reset-time 1000
loadrt stepgen step_type=0,0
loadrt encoder num_chan=1
loadrt abs count=1
loadrt scale count=1
loadrt lowpass count=1
#My stuff.
#loadusr -W hal_input -KRAL Gamepad
#loadusr io, was already loaded.
addf encoder.update-counters base-thread
addf encoder.capture-position servo-thread
addf stepgen.update-freq servo-thread
addf abs.0 servo-thread
addf scale.0 servo-thread
addf lowpass.0 servo-thread
#net spindle-cmd-rpm <= motion.spindle-speed-out
#net spindle-cmd-rpm-abs <= motion.spindle-speed-out-abs
# The rest is also commented out.
Patrik
03 Mar 2017 22:01 - 03 Mar 2017 22:05 #88965
by Patrik T
Hi
New information:
I have managed to get rid of the startup warning by commenting out one line in the ini file,
[EMC] MACHINE = my-emco-lathe, see below.
What does this mean? Where is this information used? Any ideas of where to go next?
Best regards
Patrik
New information:
# Generated by stepconf 1.1 at Sun Jan 22 06:21:10 2017
[EMC]
;MACHINE = my-emco-lathe
DEBUG = 0
Best regards
Patrik
Last edit: 03 Mar 2017 22:05 by Patrik T. Reason: Edited, I do not have full functionality on the machine as I erroneously stated initially.
03 Mar 2017 22:36 #88969
by Patrik T
Excuse my mildly confusing last post. I mistakenly thought EMC was an abbreviation for EMergenCy (stop).
03 Mar 2017 23:10 #88971
by Patrik T
Axis does not give any startup warnings if I switch to axis by doing this in the ini file, see below, and commenting some Gmoccapy stuff in the postgui.hal file.
If I switch back to Gmoccapy with (or without) the same stuff commented out in the postgui.hal file, then the startup warning is still there.
[DISPLAY]
DISPLAY = axis
# CYCLE_TIME = 150
05 Mar 2017 09:59 - 05 Mar 2017 10:00 #89031
by Patrik T
This seems to be a workaround.
In a comp:
In a comp:
// Hack the startup warning.
if (!is_manual && is_idle && !is_paused && warning_hack_counter++ < 200) // Overflow will not annoy.
mode_manual = true;
Last edit: 05 Mar 2017 10:00 by Patrik T. Reason: Preview does not look like the actual post.
05 Mar 2017 11:35 #89035
by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Hallo Patrik,
could you please post your complete config?
I will check what happen.
Norbert
Norbert
05 Mar 2017 17:33 #89047
by Patrik T
Thank you.
This is one configuration that generates the startup warning.
The .ini file emco-lathe-gmoccapy.ini
The .hal file emco-lathe-gmoccapy.hal
Don't spend too much time on it, I have found a workaround. There are other things in Gmoccapy that I would rather have fixed.
Best regards
Patrik
# File name emco-lathe-gmoccapy.ini
[EMC]
DEBUG = 0
[DISPLAY]
DISPLAY = gmoccapy
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
ARCDIVISION = 64
GRIDS = 10mm 20mm 50mm 100mm 1in 2in 5in 10in
MAX_FEED_OVERRIDE = 4.0
MIN_SPINDLE_OVERRIDE = 0.3
MAX_SPINDLE_OVERRIDE = 2.2
# DEFAULT_SPINDLE_SPEED = 1000
;DEFAULT_LINEAR_VELOCITY = 5.0
;MIN_LINEAR_VELOCITY = 0.0
;MAX_LINEAR_VELOCITY = 8.0
INTRO_TIME = 5
PROGRAM_PREFIX = /home/patrik/linuxcnc/nc_files
# OPEN_FILE = /home/patrik/linuxcnc/nc_files/g76_test_1.ngc
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
LATHE = 1
BACK_TOOL_LATHE = 0
CYCLE_TIME = 150
;# EMBED_TAB_LOCATION = box_custom_1
;EMBED_TAB_NAME = pyngcgui
;EMBED_TAB_LOCATION = ntb_preview
;EMBED_TAB_COMMAND = gladevcp -x {XID} pyngcgui_touchy_popupkeyboard.ui
;NGCGUI_FONT = Helvetca -12 normal
;NGCGUI_PREAMBLE = mm_lathe_std.ngc
;NGCGUI_SUBFILE = id.ngc
;NGCGUI_SUBFILE = od.ngc
;NGCGUI_SUBFILE = taper-od.ngc
;NGCGUI_SUBFILE = g76base.ngc
;NGCGUI_SUBFILE = g76diam.ngc
;NGCGUI_SUBFILE = ""
;NGCGUI_OPTIONS = nom2
;GCMC_INCLUDE_PATH = ../../nc_files/gcmc_lib
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
RS274NGC_STARTUP_CODE = G7 G18 G21 G90 G92.2 G95 F0.03 G97 S1000 G64 P.01
SUBROUTINE_PATH = ../../nc_files:../../nc_files/ngcgui_lib/lathe:../../nc_files/ngcgui_lib/utilitysubs
USER_M_PATH = ../../nc_files/ngcgui_lib/mfiles
[MACROS]
MACRO = go_to_position X-pos Y-pos Z-pos
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
BASE_PERIOD = 50000
SERVO_PERIOD = 1000000
[HAL]
HALUI = halui
[HALUI]
# add halui MDI commands here (max 64)
MDI_COMMAND = g90 g0 x40
MDI_COMMAND = g91 g0 x5
[TRAJ]
AXES = 3
COORDINATES = X Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
NO_FORCE_HOMING = 1
# These make squat in axis! But something in Gmoccapy.
DEFAULT_VELOCITY = 5.0
MAX_VELOCITY = 8.0
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
HOME_SEQUENCE = 0
MAX_VELOCITY = 5.70003648023
MAX_ACCELERATION = 60.0
STEPGEN_MAXACCEL = 75.0
SCALE = 3200.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -50.0
MAX_LIMIT = 0.1
HOME_OFFSET = 1.0
HOME_SEARCH_VEL = 5.000000
HOME_LATCH_VEL = -0.156250
HOME_IGNORE_LIMITS = YES
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
HOME_SEQUENCE = 1
SCALE = 3200.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -100.0
MAX_LIMIT = 100.0
HOME_OFFSET = 0.0
[SPINDLE]
MAX_RPS = 37.5
MAX_RPSS = 70
[JOYPAD]
DEADBAND_X = 0.13
OFFSET_X = -0.05
DEADBAND_Y = 0.09
OFFSET_Y = 0.12
SLOW_PERCENTAGE = .01
# File name emco-lathe-gmoccapy.hal
loadrt trivkins
loadrt abs count=1
# My stuff.
# loadusr -W hal_input -KRAL Gamepad
# loadusr -W hal_input -KRAL Keyboard
# loadusr io, was already loaded.
net spindle-cmd-rps <= motion.spindle-speed-out-rps
net spindle-cmd-rps-abs <= motion.spindle-speed-out-rps-abs
net spindle-at-speed => motion.spindle-at-speed
setp encoder.0.position-scale 76.6512
# setp encoder.0.position-scale 76.000000
net spindle-position encoder.0.position => motion.spindle-revs
net spindle-velocity-feedback-rps encoder.0.velocity => motion.spindle-speed-in
net spindle-index-enable encoder.0.index-enable <=> motion.spindle-index-enable
net spindle-phase-a encoder.0.phase-A
net spindle-phase-b encoder.0.phase-B
net spindle-index encoder.0.phase-Z
net estop-out => parport.0.pin-01-out
net xstep => parport.0.pin-02-out
setp parport.0.pin-02-out-reset 1
net xdir => parport.0.pin-03-out
net ystep => parport.0.pin-04-out
setp parport.0.pin-04-out-reset 1
net ydir => parport.0.pin-05-out
net zstep => parport.0.pin-06-out
setp parport.0.pin-06-out-reset 1
net zdir => parport.0.pin-07-out
net astep => parport.0.pin-08-out
setp parport.0.pin-08-out-reset 1
net adir => parport.0.pin-09-out
net estop-ext <= parport.0.pin-10-in
net max-home-x <= parport.0.pin-11-in-not
net spindle-phase-a <= parport.0.pin-12-in
net spindle-phase-b <= parport.0.pin-13-in
net spindle-index <= parport.0.pin-15-in
setp stepgen.0.position-scale [AXIS_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 0
setp stepgen.0.dirhold 12000
setp stepgen.0.dirsetup 12000
setp stepgen.0.maxaccel [AXIS_0]STEPGEN_MAXACCEL
net xpos-cmd axis.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => axis.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable axis.0.amp-enable-out => stepgen.0.enable
net max-home-x => axis.0.home-sw-in
net max-home-x => axis.0.pos-lim-sw-in
setp stepgen.1.position-scale [AXIS_2]SCALE
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 0
setp stepgen.1.dirhold 12000
setp stepgen.1.dirsetup 12000
setp stepgen.1.maxaccel [AXIS_2]STEPGEN_MAXACCEL
net zpos-cmd axis.2.motor-pos-cmd => stepgen.1.position-cmd
net zpos-fb stepgen.1.position-fb => axis.2.motor-pos-fb
net zstep <= stepgen.1.step
net zdir <= stepgen.1.dir
net zenable axis.2.amp-enable-out => stepgen.1.enable
net estop-ext => iocontrol.0.emc-enable-in
# setp iocontrol.0.emc-enable-in 1
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed-clicked hal_manualtoolchange.changed
Best regards
Patrik
05 Mar 2017 18:27 #89050
by newbynobi
Hallo Patric,
I just copied the files in gmoccapy, and saved them in my config dir. I can start the config, without any warning!
What release of gmoccapy do you use?
Norbert
Norbert
05 Mar 2017 21:26 #89062
by Patrik T
Thanks for checking.
I use Gmoccapy 1.5.6.8.
I noticed that if I start with the wireless xbox controller turned off, I do not get any warning. But if I disable it altogether, like in the config I posted, I do get the warning. These are the changes I have made to linux since the install.
After the warning is reset it does not come back or cause any further problems.
So, I can live with the workaround I posted.
Best regards
Patrik
patrik@debian:~$ sudo nano /etc/default/grub
GRUB_CMDLINE_LINUX_DEFAULT="lapic quiet rootdelay=5 idle=poll nomodeset grub_gfxmode=1280x1024x24"
patrik@debian:~$ sudo update-grub
patrik@debian:~$ apt-get update
patrik@debian:~$ sudo apt-get install gedit
patrik@debian:~$ sudo apt-get install gedit-plugins
patrik@debian:~$ sudo apt-get install xboxdrv
patrik@debian:~$ sudo nano /etc/rc.local
xboxdrv --silent --detach-kernel-driver
patrik@debian:~$ sudo nano /etc/modprobe.d/fbdev-blacklist.conf
blacklist xpad
patrik@debian:~$ less /proc/bus/input/devices
patrik@debian:~$ sudo apt-get install linuxcnc-dev
patrik@debian:~$ sudo halcompile --install myxpadlathe.comp
patrik@debian:~$ sudo apt-get install gawk lm-sensors binutils mesa-utils hddtemp
patrik@debian:~$ cd /usr/local/bin/
patrik@debian:~$ sudo wget -Nc smxi.org/inxi
patrik@debian:~$ sudo chmod +x inxi
patrik@debian:~$ sudo inxi -F all
patrik@debian:~$ sudo apt-get install mesa-utils
patrik@debian:~$ glxgears
Best regards
Patrik
20 Mar 2017 22:58 #89973
by Patrik T
Hi again.
May i ask if it is possible to access the Gmoccapy Gremlin preview from a python script?
I am using an embedded tab with a python handler like so:
I want to be able to clear, pan and zoom from my python script.
Best regards
Patrik
Best regards
Patrik
Time to create page: 0.683 seconds
