13 May 2015 03:19 #58609 by mariusl
Ok see what these are like. Again rename the .txt to .svg on all files.
I can only add eight so see the next post for the rest
File Name: bot.txt
File Size:4 KB
File Name: bot_left.txt
File Size:6 KB
File Name: bot_right.txt
File Size:6 KB
File Name: hole.txt
File Size:7 KB
File Name: right.txt
File Size:4 KB
File Name: right_2015-05-12.txt
File Size:4 KB
File Name: round_outside.txt
File Size:7 KB
File Name: top.txt
File Size:4 KB
Regards
Marius
www.bluearccnc.com
13 May 2015 03:21 #58610 by mariusl
And the rest
File Name: top_left_2...5-12.txt
File Size:6 KB
File Name: top_right.txt
File Size:6 KB
File Name: x_inside.txt
File Size:6 KB
File Name: y_inside.txt
File Size:6 KB
Regards
Marius
www.bluearccnc.com
13 May 2015 14:15 - 13 May 2015 14:17 #58621 by verser
Would you please send me the code of your touch off macro page? I thing that would be a good beginning to introduce some stuff to standard. Or better, just write a WIKI page about how you did it.
Norbert
More рay attention to this
Last edit: 13 May 2015 14:17 by verser.
13 May 2015 23:00 #58642 by mariusl
I tried to download your work but the file is of unknown type and it cannot be opened.
Regards
Marius
www.bluearccnc.com
13 May 2015 23:12 #58644 by verser
Replace txt on rar :) .
13 May 2015 23:28 #58645 by mariusl
Thanks that worked. I wonder if I tried rar?
Regards
Marius
www.bluearccnc.com
14 May 2015 00:32 #58649 by verser
This application can be easily connected to Gmoccapy
EMBED_TAB_NAME=Probe Screen
EMBED_TAB_LOCATION = ntb_user_tabs
EMBED_TAB_COMMAND = gladevcp  -x {XID} -u python/probe_screen.py probe_icons/probe_screen.glade
The following user(s) said Thank You: balestrino, nilsht
21 Sep 2015 05:21 #62827 by FernV
Hi Verser,
I see you have been using LinuxCNC-Features for some time with an old release by Nick. I am about to release a new update with a virtual keypad, better grouping and more.
About the last issue I have is with reloading the file in gmoccapy after some changes. It will reload automatically some times but not always and I have to press the Refresh button many times and sometimes I can only reload with the File button in gmoccapy.
How is your experience with it ? Could something not be configured right on my computer or do you experience the same as I ?
Regards
Fern
14 Nov 2015 18:55 #65251 by probamo
@Norbert
recently I bought a second hand touch screen for piece of money :laugh: and tried gmoccapy. Everything was brilliant. Touch here, touch there, perfect. However, I noticed one thing that could be improved.
I am cutting MDF very offten, though I get very good dedusting system, small particles still flies in the room. Sometimes, my fingers are coated with fine duct as well. This does not allow me to slide feedrate, jog and spindle speed slide bars. Is it possible, instead of having slidebars, to have "-" & "+" buttons, to decrease/increase parameters, but 100% to remain as such.
Thank you!
14 Nov 2015 21:29 #65258 by DaBit
In that case I would seriously consider using external controls for that. Up/down buttons are slow, rotary encoders (the 'volume up/down' variant and not the '2500 line servo type') are cheap, and so is an extra parallel port card if you do not use Mesa hardware. A single LPT-card can interface 5 encoders or so.
Adding a small box with rapid/feed/spindle override potmeters at a handy spot on the machine is still on my todo-list.. It is a highly endmill-and-stock saving practice to start a program with rapid speeds reduced.
Moderators: newbynobiHansU
Time to create page: 1.362 seconds
