Need testers for gmoccapy_5_axis
12 Oct 2015 00:10 - 12 Oct 2015 00:12 #63692
by newbynobi
Need testers for gmoccapy_5_axis was created by newbynobi
Hallo everybody out there
I have been forced by different users to make a gmoccapy 5 axis version.
Here it is. I made this in a way, so it can be used as lathe, as 3 axis as 4 axis and 5 axis version, It will recognize from INI file what widgets to be shown or hidden.
So it should work on every existing gmoccapa config. Who is willing to test?
Just get the branch gmoccapy_5_axis from git server.
Do we need the touch off button to set zero directly, as I throwed them out, because of space reasons.
Is someone using the DRO button? If not, I would like to get rid of them.
What do you thinl about the new location of the "file loaded" information?
Waiting for feedback!!!
Norbert
Norbert
Last edit: 12 Oct 2015 00:12 by newbynobi.
The following user(s) said Thank You: bjames28
The topic has been locked.
12 Oct 2015 02:09 - 12 Oct 2015 02:10 #63695
by cncbasher
Replied by cncbasher on topic Need testers for gmoccapy_5_axis
i'll test it Norbert,
hopefully tomorrow as it's becoming late here ,
looks excellent as always ! ,
Last edit: 12 Oct 2015 02:10 by cncbasher.
22 Oct 2015 22:59 #64147
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Need testers for gmoccapy_5_axis
Hi Norbert
I am trying to get a copy of your branch but there are changes to a python library that will not allow me to get the branch. I think it is the linuxcnc-features stuff. Must I do a complete new pull of the linuxcnc-dev to get around this?
Regards
Marius
www.bluearccnc.com
23 Oct 2015 04:38 #64163
by newbynobi
Replied by newbynobi on topic Need testers for gmoccapy_5_axis
Marius,
Do not merge the branch, just pull it, there should not be any problem.
For sure you will need to change to the new branch and compile it.
What python lib, and what have you done?
Norbert
Norbert
- auto-mation-assist
- Thank you received: 81
21 Nov 2015 09:31 #65594
by auto-mation-assist
Replied by auto-mation-assist on topic Need testers for gmoccapy_5_axis
I had installed gmoccapy_5 axis and my biggest problem right now is with the dro's not changing from mm to inch on the four original axis that were set up in mm before installing gmoccapy_5 during the initial linuxcnc install. When I enabled the 5th axis Its dro displayed in inch mode as my ini file directed. I have tried everything to change axis X, Y, Z, A to display the dro angles in inch mode and not in mm with no luck.. They just continue to display 2.5400 for every inch of movement.
21 Nov 2015 16:10 #65611
by newbynobi
So your machine config is in inch, right?
axis A is angular, so it should display angle units.
What is the 5-th axis?
What code is active? G20 or G21?
Norbert (checking on your problem)
21 Nov 2015 21:23 #65626
I found G21 in the .ini file and changed it to G20. Axis X,Y,Z and A now display in inches. But the dro part of the front panel shows axis A angles in +/- values while the white angle indicators in the preview screen show the correctly in degrees. My B axis is linear and its dro displayed in inches even when the G21 code was in the .ini file. Should it not have displayed in mm with the G21 code?
I test each axis individually on the bench with just one motor and encoder feedback going a Leadshine DCS810 and also feeding the encoder a.b and index signal to the appropriate quad decoder for routing to each axis pid function. The quad decoder inputs on X,Y,Z and B inputs will later be fed by the glass scales that are on those axis already and parameters adjusted as required. The machine this system is going on is not quite ready since it does not have all the required limit and home switches installed..
22 Nov 2015 20:41 #65669
by newbynobi
A,B and C can not be linear!!!!
This are the rotation axis around the linear axis.
If you need aditional linear axis you have to use U, V or W.
So this seems not to be gmoccapy specific.
Norbert
Norbert
The following user(s) said Thank You: auto-mation-assist
25 Nov 2015 10:52 #65769
Norbert I have lost my file to configure your 5 axis version of Gmocappy during my computer swamp. I have searched for hours trying to find a link to download the file with no success. If possible can you provide me with a link to where I can download a copy?
25 Nov 2015 19:51 - 25 Nov 2015 19:52 #65792
by newbynobi
Can you follow?
If you have git installed, you may not need all steps.
All out of memory, I am not sure with the git checkout command, you can do that one also using git gui
Norbert
sudo apt-get install git-core gitk git-gui
git config --global user.name "Your full name"
git config --global user.email "you@example.com"
git clone git://git.linuxcnc.org/git/linuxcnc.git linuxcnc-dev
sudo apt-get install libboost-python1.49-dev libmodbus-dev libusb-1.0-0-dev libxmu-dev libglu1-mesa-dev libgl1-mesa-dev libreadline-dev tcl8.5-dev tk8.5-dev
cd linuxcnc-dev
git checkout gmoccapy_5_axis
cd src
./autogen.sh
./configure
make
sudo make setuid
cd ..
. ./scripts/rip-environment
linuxcnc
Can you follow?
Norbert
Last edit: 25 Nov 2015 19:52 by newbynobi.
Time to create page: 0.232 seconds
