Gmoccapy Bug?
14 Jan 2017 11:36 #85740
by newbynobi
Replied by newbynobi on topic Gmoccapy Bug?
Hallo Timmert,
please change you HOME = 0 to a smal value away from your home switches or give a HOME_OFFset value.
Otherwise your machine may still be on the mome switch after homing, leading to an error if you try to home again.
I use on my mill both (METRIC!!)
HOME = 10
HOME_OFFSET = -0,5
HOME_SEARCH_VEL = -25
HOME_LATCH_VEL = 3
What error do you get?
Norbert
HOME = 10
HOME_OFFSET = -0,5
HOME_LATCH_VEL = 3
Norbert
14 Jan 2017 11:39 #85741
by timmert
Replied by timmert on topic Gmoccapy Bug?
Hi Norbert
My home offset is working fine never had problems.
I also don't get any error.
The problem is that after I home the machine I go to the MDI screen.
If I home again I can't switch between jog and MDI screen. I can click MDI, but the screen doesn't switch from the jog mode.
Homing is working fine.
14 Jan 2017 11:51 #85742
by newbynobi
OK,
What release number does the GUI show?
Please start from a terminal and watch for outputs.
I am not able to reproduce that, are you able to make a screen video?
I recommend "RecordMyDesktop" for that purpose.
Norbert
Norbert
14 Jan 2017 11:58 #85743
by timmert
Ok will make a video
14 Jan 2017 14:17 #85748
by thor44
Replied by thor44 on topic Gmoccapy Bug?
Norbert
I have not tested yet, I am still waiting for someone to help me install the update.
can you help?
can you help?
14 Jan 2017 15:22 - 14 Jan 2017 15:25 #85755
by timmert
1.1 updating LinuxCNC
And add one of the master branch (depending on what you're using, Wheezy, Precise etc)
buildbot.linuxcnc.org/
The master = development
if you want to rollback:
Remove the master branch repository from the Synaptic Manager.
Remote LinuxCNC
Add the stable release
Reload
Install
Make sure to backup your config first
Follow linuxcnc.org/docs/html/getting-started/updating-linuxcnc.htmlNorbert
can you help?
Remote LinuxCNC
Reload
Install
Last edit: 14 Jan 2017 15:25 by timmert.
15 Jan 2017 11:25 #85812
by timmert
I start the machine
1. home
2. enter MDI and enter a G30 (doesn't matter which command I enter)
3. home
4. MDI screen doesn't open, have to completely restart lcnc.
OK,
Norbert
I start the machine
1. home
3. home
15 Jan 2017 13:04 - 15 Jan 2017 13:20 #85814
by newbynobi
OK, that is strange. I can see, that your system is not getting out of MDI mode, because of the terminal output.
I checked the code as much as possible, but could not find a solution. The only I did not test, is using gmoccapy together with hal-manual Toollchange.
So please do three tests and report:
1. go to settings page and uncheck reload tool on startup (advanced settings)
2. change from hal_manual toolchange to gmoccapy toolchange (you are using the axis one at the moment)
3. after leaving the MDI mode, before homing the second time, just push any of the jog button, does the machine jog?
And please post your complete config folder.
Norbert
Norbert
Last edit: 15 Jan 2017 13:20 by newbynobi.
15 Jan 2017 13:45 - 15 Jan 2017 16:38 #85816
by timmert
Thanks for the quick reply.
1. Once I uncheck reload tool on startup. It works fine. But that was the reason I updated to the master haha.
2. Changed it to Gmoccapy tool changer. But doesn't solve it.
3. Machine jogs fine
I added my config
I added my config
Last edit: 15 Jan 2017 16:38 by timmert.
15 Jan 2017 16:40 #85823
by timmert
Editted my previous post
Tested and configured the gmoccapy tool changer, works.
But the 'reload tool' setting seems to be the problem.
MDI works fine when it's turned off.
Time to create page: 0.220 seconds
