Gmoccapy Bug?
09 Jan 2017 09:16 - 09 Jan 2017 09:17 #85505 by racedirector
Replied by racedirector on topic Gmoccapy Bug?
We are at -9 degree celsius?
Minus 13 C here, last night went to -22.
I miss the sun..........who was complaining about to hot????? Wana trade?
:cheer: :cheer:
Me, complaining about our impending heatwave week... today 36C, tomorrow 37C, Wed 40C, Thursday 37C, Friday 42C
If it was possible to trade I would do so in a flash, love cold, HATE heat.
This is 50km north west of Sydney, Australia
Last edit: 09 Jan 2017 09:17 by racedirector.
10 Jan 2017 06:41 #85557 by rodw
Replied by rodw on topic Gmoccapy Bug?
:cheer: :cheer:
And me, Another 1000 km further north and closer to the equator in Brisbane Australia.
11 Jan 2017 17:38 #85619 by newbynobi
Replied by newbynobi on topic Gmoccapy Bug?
@racedirector,
could you test?
I need a result to update also the other releases.
Norbert
13 Jan 2017 03:47 #85679 by thor44
Replied by thor44 on topic Gmoccapy Bug?
I downloaded the file from github.com/LinuxCNC/linuxcnc now how do I install it?
Sorry I'm still very new to Linux.
Orson
13 Jan 2017 18:14 #85708 by timmert
Replied by timmert on topic Gmoccapy Bug?
I'm using the new Gmoccapy UI with the master release and came across a bug that happens each time.
I start Linuxcnc -> home all -> go to MDI -> if I home again the screen doesn't switch from the jog screen to MDI.
I need to completely restart LinuxCNC to get it working again.
14 Jan 2017 08:49 #85732 by racedirector
@racedirector,
could you test?
Norbert
Sorry Norbert
Too hot to go in the garage (46C) but got to update today. Did a git pull and ran the same code - no change other than maybe a little less distance.
14 Jan 2017 11:13 - 14 Jan 2017 11:13 #85734 by newbynobi
I am not able to reproduce that. If I test with sim, I can home the machine, go to MDI, go back to manual and if I try to home again, I get the message, that the axis is on a limit switch, that is OK, because of simulated home switches.
I can jog all axis to negative values and press home all. All axis get homed and I can switch modes again.
So, what are you doing exactly?
Post the part of homing of you INI.
On my basement mill I can home as much times I like, also no error.
Norbert
Last edit: 14 Jan 2017 11:13 by newbynobi.
14 Jan 2017 11:15 #85735 by newbynobi
Sorry Norbert
Could you send me your gcode? I have tested on different machines with different codes and I am not able to see so large movements. What release number does the GUI show? Should be 2.2.3 by now.
Norbert
14 Jan 2017 11:18 - 14 Jan 2017 11:19 #85736 by newbynobi
Orson
build from source
For newbies it is much easier to use buildbot .
Norbert
Last edit: 14 Jan 2017 11:19 by newbynobi.
14 Jan 2017 11:19 - 14 Jan 2017 11:20 #85737 by timmert
Norbert
See attachment.
This is a 2.7 config though. Because I just rolled back.
Last edit: 14 Jan 2017 11:20 by timmert.
Moderators: newbynobiHansU
Time to create page: 0.374 seconds
