encoder configuration help for threading
12 Nov 2022 19:47 - 12 Nov 2022 19:48 #256524
by Ismacr63
encoder configuration help for threading was created by Ismacr63
Hello, I am trying to configure an encoder and an index sensor to be able to make a thread on my lathe converted to cnc.
I am very new to linuxcnc, I am having a hard time understanding the linuxcnc environment and I would need a little help to configure it.
I am using a 600prr 2 phase (A - B ) encoder and an inductive proximity sensor as the index sensor.
I have the encoder connected to pin 12 as phase A and the proximity sensor to pin 13 as spindle index.
in gmoccapy it doesn't show anything in rpm. in hal meter it shows as true and false when moved.
forgive my bad english
Thanks. All the best.
Last edit: 12 Nov 2022 19:48 by Ismacr63.
12 Nov 2022 20:58 #256535
Replied by PCW on topic encoder configuration help for threading
If you have a single pin encoder (just "A") you need to
set the encoder into counter mode, something like:
setp encoder.N.counter-mode true
The following user(s) said Thank You: Ismacr63
12 Nov 2022 21:02 #256536
by Ismacr63
Replied by Ismacr63 on topic encoder configuration help for threading
thanks for your reply. I have to add that line to the main file hal?
12 Nov 2022 21:18 #256538
Its possibly already there (though set to 0 or false)
12 Nov 2022 21:31 - 12 Nov 2022 21:39 #256541
by Ismacr63
I think it appears correctly.
attached my hal file.
in the file it appears with "N" but it was with 0. with N it does not start the program.
Last edit: 12 Nov 2022 21:39 by Ismacr63.
12 Nov 2022 23:01 #256547
Can you verify that the "A" pin (encoder.0.phase-A)
toggles when you rotate the spindle slowly?
13 Nov 2022 00:43 #256552
by Ismacr63
As you can see in the screenshots, the value changes when I move the spindle slowly. the other catch the spindle was turning.
13 Nov 2022 00:49 - 13 Nov 2022 00:53 #256553
OH, OK, I misunderstood, the encoder is working but just not displayed in gmoccapy
looking at:
linuxcnc.org/docs/html/gui/gmoccapy.html#_spindle_feedback_pins
it seems you must connect the pin gmoccapy.spindle_feedback_bar to the spindle RPM signal
in a hal file
looking at:
in a hal file
Last edit: 13 Nov 2022 00:53 by PCW.
13 Nov 2022 01:02 - 13 Nov 2022 01:05 #256554
by Ismacr63
These would be the 2 lines that must be put in postgui or are they incomplete?
gmoccapy.spindle_at_speed_led
On the other hand, the index sensor also returns true and false, but what is its function? or how do I know that it is doing its job?
looking at:
in a hal file
Last edit: 13 Nov 2022 01:05 by Ismacr63.
13 Nov 2022 01:15 #256555
Yes, these need to be connected in your postgui.hal file with net statements
probably something like
net spindle-at-speed => gmoccapy.spindle_at_speed_led
the gmoccapy.spindle_feedback_bar connection in the postgui.hal file needs
a new signal in the normal hal file:
net spindle-velocity-feedback-rpm encoder.0.velocity-rpm
and then
net spindle-velocity-feedback-rpm => gmoccapy.spindle_feedback_bar
The index connection resets the spindle position to 0 when
LinuxCNC requires a spindle synchronized move (like threading)
and then
Time to create page: 0.178 seconds
