encoder configuration help for threading
13 Nov 2022 01:44 #256557
by Ismacr63
wow you are great, now it is showing the rpm. the problem is that they are a bit unstable. however in the axis interface the rpm is stable.
Replied by Ismacr63 on topic encoder configuration help for threading
Yes, these need to be connected in your postgui.hal file with net statements
probably something like
net spindle-at-speed => gmoccapy.spindle_at_speed_led
the gmoccapy.spindle_feedback_bar connection in the postgui.hal file needs
a new signal in the normal hal file:
net spindle-velocity-feedback-rpm encoder.0.velocity-rpm
and then
net spindle-velocity-feedback-rpm => gmoccapy.spindle_feedback_bar
The index connection resets the spindle position to 0 when
LinuxCNC requires a spindle synchronized move (like threading)
13 Nov 2022 02:30 - 13 Nov 2022 02:31 #256558
Replied by PCW on topic encoder configuration help for threading
Often a low pass filter component is added to the measured spindle
RPM to make it more stable
(Your Axis setup may also show the commanded rather than actual RPM)
Last edit: 13 Nov 2022 02:31 by PCW. Reason: sp
The following user(s) said Thank You: Ismacr63
13 Nov 2022 09:34 - 13 Nov 2022 09:34 #256564
by Ismacr63
I get a little lost there, I don't know exactly how to do that.
Last edit: 13 Nov 2022 09:34 by Ismacr63.
13 Nov 2022 15:36 #256577
by HansU
Replied by HansU on topic encoder configuration help for threading
Somehow like so:
Set the "lowpass.0.gain" according to your desired frequency, more here: linuxcnc.org/docs/html/man/man9/lowpass.9.html
loadrt lowpass
addf lowpass.0 servo-thread
setp lowpass.0.gain 0.466
net encoder-out lowpass.0.in <= encoder.0.velocity
net spindle-velocity-feedback-rpm <= lowpass.0.out
13 Nov 2022 15:47 #256579
by Ismacr63
I've been looking at the link but the truth is that everything sounds Chinese to me: S I'm starting with linuxcnc and it's been quite an odyssey.
How can I know the frequency I need?
Those lines of code go in the postgui hal file or the main hal?
Thanks for your reply.Somehow like so:
loadrt lowpass addf lowpass.0 servo-thread setp lowpass.0.gain 0.466 net encoder-out lowpass.0.in <= encoder.0.velocity net spindle-velocity-feedback-rpm <= lowpass.0.out net spindle-velocity-feedback-rpm => gmoccapy.spindle_feedback_bar Set the "lowpass.0.gain" according to your desired frequency, more here: http://linuxcnc.org/docs/html/man/man9/lowpass.9.html
13 Nov 2022 18:51 #256594
by HansU
Yes the lines have to be in the postgui HAL file.
The filter frequency you get by trying out. If you set a lower frequency the velocity display might respond slower. You can start by trying out the example values in the man page.
13 Nov 2022 21:43 #256611
by Ismacr63
I get it. I'll try tomorrow and I'll tell you.
Thanks a lot.
Thanks a lot.
14 Nov 2022 19:56 - 14 Nov 2022 20:14 #256718
by Ismacr63
I get this error and the program closes:
(gmoccapy:1374): GtkSourceView-CRITICAL **: 20:51:08.801: gtk_source_language_manager_set_search_path: assertion 'lm->priv->ids == NULL' failed
lowpass: already exists
custom_postgui.hal:5: waitpid failed /usr/bin/rtapi_app lowpass
custom_postgui.hal:5: /usr/bin/rtapi_app exited without becoming ready
custom_postgui.hal:5: insmod for lowpass failed, returned -1
1337
1370
Stopping realtime threads
Unloading hal components
Note: Using POSIX realtime
Yes the lines have to be in the postgui HAL file.The filter frequency you get by trying out. If you set a lower frequency the velocity display might respond slower. You can start by trying out the example values in the man page.
1337
1370
Last edit: 14 Nov 2022 20:14 by Ismacr63.
14 Nov 2022 22:05 - 14 Nov 2022 22:06 #256731
by HansU
You already load a lowpass in mi-maquina.hal.
Change that toand usein your postgui Hal file
Change that to
loadrt lowpass count=2
lowpass.1
Last edit: 14 Nov 2022 22:06 by HansU.
15 Nov 2022 18:50 #256793
by Ismacr63
custom_postgui.hal:5: Pin 'encoder.0.velocity' was already linked to signal 'spindle-velocity-feedback-rps'
6193
6226
now i am getting this error:(gmoccapy:6230): GtkSourceView-CRITICAL **: 19:43:45.173: gtk_source_language_manager_set_search_path: assertion 'lm->priv->ids == NULL' failedYou already load a lowpass in mi-maquina.hal.
Change that to
[/code]loadrt lowpass count=2 and use [code]lowpass.1 in your postgui Hal file
6193
6226
Time to create page: 0.187 seconds
