encoder configuration help for threading
15 Nov 2022 21:27 - 15 Nov 2022 21:31 #256801
Replied by PCW on topic encoder configuration help for threading
in the postgui.hal file:
net encoder-out lowpass.1.in <= encoder.0.velocity
should be
net spindle-velocity-feedback-rpm => lowpass.1.in
should be
Last edit: 15 Nov 2022 21:31 by PCW.
The following user(s) said Thank You: Ismacr63
16 Nov 2022 18:38 #256875
by Ismacr63
I don't know if I still have something wrong...
Replied by Ismacr63 on topic encoder configuration help for threading
Currently with this configuration the program starts, but I don't notice any change. I have tried several frequencies but without success. The rpm bar keeps bobbing up and down a lot.in the postgui.hal file:
should be
16 Nov 2022 19:10 #256879
try
setp lowpass.1.gain 0.005
16 Nov 2022 19:20 #256881
by Ismacr63
exactly the same thing happens you can see it in the video.
try
16 Nov 2022 19:47 - 16 Nov 2022 19:48 #256887
That's actually expected because you are not using the lowpass filter output
I would change the postgui.hal to this:
# Incluya sus comandos HAL custom_postgui aquÃ
# Este archivo no se sobrescribirá cuando vuelva a ejecutar stepconf
addf lowpass.1 servo-thread
net spindle-velocity-filtered <= lowpass.1.out => gmoccapy.spindle_feedback_bar
net spindle-at-speed => gmoccapy.spindle_at_speed_led
Note that the velocity may have other issues as it seemed to have
dropped to 0 some times which may mean an encoder reading issue.
Last edit: 16 Nov 2022 19:48 by PCW.
16 Nov 2022 20:24 #256893
by Ismacr63
Something that I have observed is that the rpm does not go above 375 and I think it is due to my encoder which is 600ppr. My lathe has 2500rpm. Do you think a 100ppr encoder would be better, for example?
now it is working fine!!! Now the rpm ranges from 365 to 360-368, for example. Do you think that's right?That's actually expected because you are not using the lowpass filter output
16 Nov 2022 20:36 #256897
Yes, the RPM limit is due to the combination of
basethread rate and encoder resolution. A 100 PPR
encoder should allow ~2250 RPM, with the same
base thread rate, though its unlikely that you would
need to thread at that speed...
16 Nov 2022 20:48 #256898
by Ismacr63
my lathe may be able to allow me to thread over 500 rpm. I was just wondering if it is better or not to have an encoder with 100ppr. In the future I want to put a more powerful motor with a frequency inverter to control the spindle from linuxcnc, would the encoder affect something?
16 Nov 2022 21:48 #256901
I guess it depends on how fast you really need to thread
(or have an actual speed readout)
On a parallel port system, the encoder maximum count rate is
dependent the base thread rate and encoder PPR.
The spindle drive system doesn't affect this limit.
17 Nov 2022 18:49 #256945
by Ismacr63
I wanted to thank you very much for your help. thanks greetings.
Time to create page: 0.363 seconds
