LinuxCNC Features - a kind of NGCGUI
15 Nov 2014 00:25 #53086
by cparsons
Replied by cparsons on topic LinuxCNC Features - a kind of NGCGUI
I have attached my corrected mill.xml file from subroutines/catalogs if it helps anyone?
Incidentally, the English word is 'Rapid' - only one 'p'
Best wishes
Chris
Best wishes
Chris
19 Nov 2014 03:34 #53196
by kjacobs
Replied by kjacobs on topic LinuxCNC Features - a kind of NGCGUI
Hello,
I installed LinuxCNC features in 2.7.0~pre0 and it works nicely in principle, but it seems to ignore any G54 offset (touching off from the workpiece). Features (e.g. OD) always seem to start at the machine zero instead of the G54 offset. When I use the NGCGUI OD feature instead, that does indeed respect the G54 offset as I expected. Am I doing something wrong in LinuxCNC features?
Cheers,
Karl
Cheers,
Karl
19 Nov 2014 16:42 #53200
by Nick
Replied by Nick on topic LinuxCNC Features - a kind of NGCGUI
Try to add Gcode feature with a line "G54"...
I'm not sure but possibly it'll help...
19 Nov 2014 19:44 - 20 Nov 2014 00:03 #53210
by cparsons
I still cannot see anything in LinuxCNC when I run the 'Features' plugin - do I have to change the LinuxCNC configuration to show a different interface to 'Axis'?
The software does appear to run standalone now I have corrected the paths but I cannot see anything shown in LinuxCNC when I create an object - all the screenshots I have seen show an additional window docked to the right hand side of the Axis interface, and when and object is created it appears in the 'preview' window and this should happen with the standalone too?
The other thing I have noticed is that in the standalone the 'Open' button does not appear to be working?
I get an error message
File "./features.py" line 1282, in load
filter.set_name("XML")
AttributeError: 'builtin function of method' object has no attribute 'set_name'
Chris
UPDATE: This was caused by some missing code - in features.py, in the routine load(...) the line 1280 should be preceded by a line 'filter = gtk.FileFilter()'
The following line(s) try to call methods on a 'filter' object that had not been created...
Regards
Chris
Chris
Regards
Chris
Last edit: 20 Nov 2014 00:03 by cparsons. Reason: Found solution
19 Nov 2014 21:06 #53212
by kjacobs
Hi Nick,
it is not quite as simple, but after trying to understand your code better (and found that everything needed is there already!), I found a solution that makes it work exactly like NGCGUI for me:
in subroutine lathe-multipass, after these two lines
G92.1 (disable G92 offsets)
O<coordinate-sys-to-num> CALL [#<coord>]
you replace this line:
G10 L2 P[#<_coordinate-to-num>] X[#<x>+ #<xstep>*#<l>] Z[#<z> + #<zstep>*#<l>]
with this line:
G10 L2 P[#<_coordinate-to-num>] X[#<x> + #<_get_offsets_x> + #<xstep>*#<l>] Z[#<z> + #<_get_offsets_z> + #<zstep>*#<l>]
Now the feature follows the G54 touchoff coordinates. I tested it for the OD feature and have not yet looked into the others.
with this line:
20 Nov 2014 00:14 #53214
by cparsons
I have also worked out why my LinuxCNC interface had not changed - there is an additional entry required in the ini file for your machine, in the [DISPLAY] section (I put my entry at the bottom)
[DISPLAY]
GLADEVCP = myname.ui
and a 'myname.ui' file needs creating in the config directory in LinuxCNC for your machine, or some other suitable place -
I called my file 'features.ui' and have attached it
Chris
[DISPLAY]
Chris
The following user(s) said Thank You: BigG
- Russianwolf
13 Jan 2015 11:46 #54960
by Russianwolf
Replied by Russianwolf on topic LinuxCNC Features - a kind of NGCGUI
Privet Nick
I would love to work on this from the view of a completely new user (I am new to CNC, Linux, LinuxCNC and to your efforts here).
I have copied the files from GitHub onto my Linux computer that also has LinuxCNC installed. I only just got my machine up and running.
If you can provide simple instructions on how to install (remember that Linux and LinuxCNC are new to me so the instructions need to be pretty basic), I am more than willing to complete the install and see what I can get to work and what I can't.
Mike
Ya izuchil ryskie yazik kogda ya beil na flote, no ya amerikanskie
Sorry, my Russian is VERY rusty.
Mike
13 Jan 2015 21:41 #54972
by Nick
Hi!
Have you tried to do installation instructions from readme.md?
See here at the bottom of the page.
github.com/cnc-club/linuxcnc-features
25 Jan 2015 06:38 #55315
by FernV
Replied by FernV on topic LinuxCNC Features - a kind of NGCGUI
Hi Nick,
I have a little problem that needs your help :
When I copy a Feature the new Feature has the same ID and if it uses #<self_id-.....> I end up with 2 features with the same ID and it bugs. If I simply add a new feature, it gives it a new ID which is OK.
In this function
def copy(self, *arg) :
f,iter = self.get_selected_feature()
if f :
path = self.treestore.get_string_from_iter(iter)
xml = self.treestore_to_xml()
src = xml.find(".//*[@path='%s']"%path)
cp = deepcopy(src)
parent = src.getparent()
parent.insert(parent.index(src)+1, cp)
self.treestore_from_xml(xml)
self.action(xml)
after deepcopy it should give a new ID. I do not know python enough so I am asking you how I should do it ?
Regards
Fern
In this function
if f :
cp = deepcopy(src)
self.action(xml)
Regards
Fern
- turbospeedskater
05 Feb 2015 14:51 #55709
by turbospeedskater
Replied by turbospeedskater on topic LinuxCNC Features - a kind of NGCGUI
Hi Nick,
first of all: many thanks for writing this great tool and releasing it to the public!!!!
I spent the last days playing with the software and porting all subroutines I had written for
ngcgui to it. That job is mostly done, and when 100% finished, I would like to release it to
the public.
During my tests I have found two things that don't work as expected (at least not the way I expect )
1.) The issue with copying features and the #<self-id... FernV mentioned in another post,
and
2.) A grouping problem:
To make it simple: Try from scratch to make two groups each having two pocket elements:
1st add two pockets to the 1st group, then add two pockets to the 2nd group. During this will
find the 1st pocket you have put into the 2nd group will move from the 2nd group to the 1st
group. ... and there is no way to bring it back to the 2nd... Same issue is is with arrays....
I have spend some days now to understand your python code (and I tried to find a working
IDE for python without success...), but you are using too many external functions and libraries
that I don't know. So I have a basic idea how your code works, but no chance to solve the a.m.
problems on my own. (Normally I write software for microcontrollers for machine control, so
I am not an expert when it comes to "XML", "User interface", "Windows" etc... )
If you need more info, please give me a hint, but I think that should explain what I mean...
BTW: How do you debug your python code? I am still looking for a good way to work on
bigger python projects....
best regards,
Martin.
the public.
and
best regards,
Martin.
Time to create page: 0.244 seconds
