LinuxCNC Features - a kind of NGCGUI
04 Jun 2014 02:39 #47665
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic LinuxCNC Features - a kind of NGCGUI
Done that now but I am still having some problems. I can add settings feature. The gcode is updated in axis but as soon as I add a face cut it gives n error "Named parameter #<_z>not defined" Nothing works after that.
Regards
Marius
www.bluearccnc.com
09 Jun 2014 13:21 #47796
by phillc54
Replied by phillc54 on topic LinuxCNC Features - a kind of NGCGUI
I cannot do item 6 from the readme
as there are no locale files other than ru
I have got 'features' appearing in 'axis' but I cannot update 'axis' from 'features', I get the following:
Any help would be appreciated.
Cheers, Phill
cd /usr/share/locale/<<<YOUR LOCALE>>>/LC_MESSAGES
sudo ln /<full path to features sourse>/locale/<<<YOUR LOCALE>>>/LC_MESSAGES/linuxcnc-features.mo -s
File "/usr/lib/pymodules/python2.7/gladevcp/features.py", line 912, in refresh
f.write(self.to_gcode())
File "/usr/lib/pymodules/python2.7/gladevcp/features.py", line 894, in to_gcode
g,d = self.refresh_recursive(iter)
File "/usr/lib/pymodules/python2.7/gladevcp/features.py", line 871, in refresh_recursive
gcode_def += f.get_definitions()
File "/usr/lib/pymodules/python2.7/gladevcp/features.py", line 257, in get_definitions
s = self.process(self.attr["definitions"])
File "/usr/lib/pymodules/python2.7/gladevcp/features.py", line 324, in process
s = re.sub(r"(?i)(<eval>(.*?)</eval>)", eval_callback, s)
File "/usr/lib/python2.7/re.py", line 151, in sub
return _compile(pattern, flags).sub(repl, string, count)
File "/usr/lib/pymodules/python2.7/gladevcp/features.py", line 287, in eval_callback
return str( eval(m.group(2), globals(),{"self":self}) )
File "<string>", line 1, in <module>
File "/usr/lib/pymodules/python2.7/gladevcp/features.py", line 274, in include_once
return self.include(src)
File "/usr/lib/pymodules/python2.7/gladevcp/features.py", line 265, in include
f = open(search_path(SUBROUTINES_PATH,src))
TypeError: coercing to Unicode: need string or buffer, NoneType found
Cheers, Phill
09 Jun 2014 20:11 #47809
by Nick
Can you attach your ini file. It seems it does not have SUBROUTINES_PATH parameter...
Replied by Nick on topic LinuxCNC Features - a kind of NGCGUI
you can skip this step... currently there are no translations except Russian.as there are no locale files other than ru
10 Jun 2014 15:52 #47837
by phillc54
Attached is my ini file.
If I do only a facing function it will refresh to 'axis'.
If I do multiple facing functions it will refresh to 'axis'.
If I do a od-simple function it errors as per my previous post.
If I try to open a file it errors as follows:
File "/usr/lib/pymodules/python2.7/gladevcp/features.py", line 1279, in load
filter.set_name("XML")
AttributeError: 'builtin_function_or_method' object has no attribute 'set_name'
10 Jun 2014 16:49 - 10 Jun 2014 16:50 #47842
by mariusl
Regards
Marius
www.bluearccnc.com
I concur with Phill, I can do a face action but as soon as I do an OD, the system no longer works. See my previous post about the variable #<_z> not being present. It would seem that there are uninitialized variables under certain conditions.
Regards
Marius
www.bluearccnc.com
Last edit: 10 Jun 2014 16:50 by mariusl.
10 Jun 2014 17:18 #47843
#<_z> is a convenience variable but only defined in 2.6 / master.
www.linuxcnc.org/docs/devel/html/gcode/o...d_named_parameters_a
Replied by andypugh on topic LinuxCNC Features - a kind of NGCGUI
10 Jun 2014 18:27 #47847
by phillc54
I am currently using 2.6.0-pre3-37-gd131cf1.
10 Jun 2014 20:39 #47850
Do the other named parameters exist?
(You can test in the MDI window with (debug, #<_motion_mode>) for example. You need the brackets and braces, and no space before the comma)
11 Jun 2014 16:16 #47881
by phillc54
Yes, they appear to exist. ( I tested using your example plus #<_x>, #<_y> & #<_z>)
More version numbers if it helps (or hinders...)
phill@lcnc:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 12.04.4 LTS
Release: 12.04
Codename: precise
phill@lcnc:~$ uname -a
Linux lcnc 3.4.55-rtai-2 #1 SMP PREEMPT Sun Dec 15 23:40:48 MST 2013 i686 i686 i386 GNU/Linux
phill@lcnc:~$
11 Jun 2014 18:39 #47890
I think we have become confused.
Mariusl said that #<_z> didn't exist, then Phillc54 said that it did.
Both could be true.
Both could be true.
Time to create page: 0.182 seconds
