LinuxCNC Features - a kind of NGCGUI
29 May 2014 12:44 #47504
by Nick
You can try at least pack it to Gnomocapy, then we will thik of how to make it reload the Gcode...
Replied by Nick on topic LinuxCNC Features - a kind of NGCGUI
Hmmm... Features is based on GladeVCP so probably it can be packed into Gmoccapy, but it calls axis-remote to reload the file - so that can cause problem...Hi Nick
Have you tested this with Gmoccapy or do you know if anyone has?
subprocess.call(["axis-remote",PROGRAM_PREFIX + "/features.ngc"])
Can you attach your xml file...I have no calculators widgets in my xml files. Am I missing something to install?
30 May 2014 13:03 #47537
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic LinuxCNC Features - a kind of NGCGUI
Hi Nick
Sorry for the delay. I attached the xml
Regards
Marius
www.bluearccnc.com
30 May 2014 13:19 #47538
by Nick
Hmm strange....where did you get LinuxCNC from?
anyway, first pack of code should be placed beforeSecond inside tag glade-widget-group
<!-- Actions -->
<glade-widget-group name="python" title="HAL Python">
30 May 2014 13:34 #47540
by mariusl
Regards
Marius
www.bluearccnc.com
Live CD then updated via package manager and then installed master.
Regards
Marius
www.bluearccnc.com
03 Jun 2014 16:19 #47648
by mariusl
Regards
Marius
www.bluearccnc.com
Hi Nick
Could you give a sample ini file that call features when axis is loaded please?
Regards
Marius
www.bluearccnc.com
03 Jun 2014 19:37 #47655
by craig
Replied by craig on topic LinuxCNC Features - a kind of NGCGUI
Have a look at my post #44102 one page back, there is everything you need to get features running.
Hope that helps
Hope that helps
03 Jun 2014 19:56 #47657
by mariusl
Regards
Marius
www.bluearccnc.com
Craig
I read that post several times. I dont know how I missed the actual file
It loads ok so now I have to try and get it to work. (actually not it but me)
Regards
Marius
www.bluearccnc.com
03 Jun 2014 20:00 #47658
by craig
Glad I could help, I really like the features that Nick has created.
03 Jun 2014 20:04 #47659
by mariusl
Regards
Marius
www.bluearccnc.com
It loads fine but it seems that here could be a permissions problem as I cannot save anything nor will it post to axis. Must I set something somewhere that I missed maybe?
Regards
Marius
www.bluearccnc.com
03 Jun 2014 23:29 - 03 Jun 2014 23:35 #47664
by craig
If I were you I'd start over my install instructions, you need to start the Linuxcnc configuration as below
- First start by going into the Linuxcnc configuration selector and choose ngcgui -- comprehensive example and let it copy all the files
I can't recall but I think I did all that as my normal user, not as root or sudo
heres a page that shows a screen shot of the initial Linuxcnc configuration selector
click here
click here
Last edit: 03 Jun 2014 23:35 by craig.
Time to create page: 0.237 seconds
