Native CAM - How To Install?
29 Oct 2018 21:10 #119625
by Askjerry
Native CAM - How To Install? was created by Askjerry
I see many posts on Native CAM... but I am not finding anything on HOW
to install it.
I'm trying to help out a friend.
Jerry
Jerry
- Thank you received: 5959
29 Oct 2018 22:31 #119627
Replied by tommylight on topic Native CAM - How To Install?
forum.linuxcnc.org/nativecam/31659-nativ...-is-features-renamed
forum.linuxcnc.org/nativecam/31659-nativ...atures-renamed#81373
It is mentioned several times in that thread, and in the included HOWTO.
29 Oct 2018 22:47 #119629
by Askjerry
Replied by Askjerry on topic Native CAM - How To Install?
Awesome... I was searching "How to Install" and wasn't finding anything... so hopefully this post will direct others as well.
Thanks!
Jerry
Thanks!
Jerry
- eFalegname
- Thank you received: 30
30 Oct 2018 07:34 - 30 Oct 2018 07:37 #119636
by eFalegname
Replied by eFalegname on topic Native CAM - How To Install?
It's been a while since Fernand don't let us know any news, I guess some things are changing around NativeCAM, now it is not possible to install NativeCam through synaptic. I have many requests for improvement, but I would not like to bother him because I feel that Fern will update us soon (perhaps... with the release of linuxcnc 2.8??? maybe )
Floris
Floris
Last edit: 30 Oct 2018 07:37 by eFalegname.
- eFalegname
30 Oct 2018 12:53 - 30 Oct 2018 12:55 #119641
by eFalegname
Jerry here you have the link to the .deb NativeCam installer from my dropbox:
stretch_nativecam_0.1.14b_all.deb ยท 1.76 MB
Just use gdebi.
Floris
Just use gdebi.
Floris
Last edit: 30 Oct 2018 12:55 by eFalegname.
31 Oct 2018 00:47 - 31 Oct 2018 00:49 #119678
by Askjerry
Thank you!
I was able to download the file... and I extracted it to a directory.
Unfortunately... I'm still fairly new to Linux... so I have no idea what to do now.
Apparently I have Axis 2.6.13 currently installed. I suppose I should go to the synaptic package manager and search for AXIS and/or LinuxCNC to look for an upgrade.
Jerry
Jerry
Last edit: 31 Oct 2018 00:49 by Askjerry.
- eFalegname
31 Oct 2018 08:47 - 31 Oct 2018 08:48 #119690
by eFalegname
After lunch I'll record a small video with step-by-step instructions so that it can also be a guide for those who make the first steps with LinuxCNC. NativeCam is the LinuxCNC "must have".
Floris
Floris
Last edit: 31 Oct 2018 08:48 by eFalegname.
- eFalegname
31 Oct 2018 14:15 - 20 Feb 2019 21:00 #119711
by eFalegname
please switch on captions (my english, my spanish...)
Link to NativeCAM: www.dropbox.com/s/4hkekh4bxfv14x3/stretc...0.1.14b_all.deb?dl=0
1) Standalone Usage:
ncam [Options]
Options :
-h | --help this text
(-i | --ini=) inifilename inifile used
(-c | --catalog=) catalog valid catalogs = mill, plasma, lathe
-t | --tab axis and gmoccapy only, put NativeCAM in a new tab
2) To prepare your inifile to use NativeCAM embedded,
a) Start in a working directory with your LinuxCNC configuration ini file
cd /home/"user"/linuxcnc/configs/"yourfolder"
b) Type this command :
ncam -i = "inifilename" -c = "valid catalog for this configuration"
A backup of your inifile will be created before it is modified.
After success, you can use it embedded :
linuxcnc inifilename
ncam [Options]
Options :
Last edit: 20 Feb 2019 21:00 by eFalegname.
- franstrein
06 Feb 2019 09:50 #125792
by franstrein
Replied by franstrein on topic Native CAM - How To Install?
Thanks for the good video.
I used NativeCam in the past, and want to rebuild it on my current image.
However the link to dropbox in the entries above is not working for me, getting a not found message.
Any chance on getting to that file, in order to follow your instructions??
Thanks,
Frans
Thanks,
Frans
- eFalegname
20 Feb 2019 20:59 #126832
by eFalegname
here you have the link: www.dropbox.com/s/4hkekh4bxfv14x3/stretc...0.1.14b_all.deb?dl=0
I noticed that Fern reactivated the NativeCAM's official page
