Native CAM - How To Install?
31 May 2019 15:02 #135474
by MJPfin
Replied by MJPfin on topic Native CAM - How To Install?
Holly cow latency has jumped to 3903790 on 25us base thread. It seems thats a no go too.
This is getting more difficult than I expected, last machine run three years without missing a beat. And was not even that hard to get working. How come everything is so difficult now?
31 May 2019 15:23 #135477
LinuxCNC depends on RTAI for good realtime performance, and RTAI development has lagged badly.
Replied by andypugh on topic Native CAM - How To Install?
31 May 2019 16:22 #135481
by MJPfin
Can someone help with the curl problem, my linux skills are depleted, so step by step for 10 iq people kind of solution needed.
I installed curl from some swedish link I found but still Ncam wont install.
tried on another computer clean install and same deal my time is going on this as I should be making everything else. what am I missing?
Used to love linuxcnc but now I dont like it one bit anymore fourth day going by with this.
Checking for curl...
Detected curl...
Running apt-get update... done.
Installing debian-archive-keyring which is needed for installing
apt-transport-https on many Debian systems.
Installing apt-transport-https... done.
Installing /etc/apt/sources.list.d/FernV_NativeCAM.list...curl: error while loading shared libraries: libcurl.so.4: cannot open shared object file: No such file or directory
Unable to run:
curl packagecloud.io/install/repositories/Fer...wheezy&source=script
Detected curl...
Unable to run:
31 May 2019 20:49 #135501
by MJPfin
This is getting down right ridiculous needed manually run ldconfig to get the curl working, another evening gone finding that out by reading countless posts. Still cant see nativecam anywhere no matter what I type in terminal thats on any instructions. How can this be so hard after couple of years?
Should it go like this or what is next to do? What am I doing wrong?
Detected operating system as debian/wheezy.
Detected curl...
Checking for gpg...
Detected gpg...
Installing /etc/apt/sources.list.d/FernV_NativeCAM.list...done.
Importing packagecloud gpg key... done.
The repository is setup! You can now install packages.
cnc@debian:~$ sudo apt-get install nativecamReading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package nativecam
cnc@debian:~$
Detected curl...
Checking for gpg...
Detected gpg...
cnc@debian:~$
31 May 2019 23:38 #135508
by BigJohnT
Replied by BigJohnT on topic Native CAM - How To Install?
Did you update the Wheezy sources file since it hit EOL anything to do with apt install broke until you point to the archives.
forum.linuxcnc.org/29-forum-announcement...-repositories#135506
JT
JT
01 Jun 2019 07:14 - 01 Jun 2019 07:20 #135543
by MJPfin
Done that already, it just wont install nativecam no matter what. Starting to get more than frustrating.
cnc@debian:~/Downloads$ sudo bash ncam_debsetup.txt
[sudo] password for cnc:
Detected curl...
The repository is setup! Installing NativeCAM... done.
cnc@debian:~/Downloads$ ncam
bash: ncam: command not found
WHAT now? it says installed but not a single instruction posted works?
Detected curl...
Last edit: 01 Jun 2019 07:20 by MJPfin.
01 Jun 2019 21:34 #135585
Have you found the ncam executable? You might need an explicit path to it.
Then, even when you find it, it probably needs to be started as ./ncam
01 Jun 2019 23:20 #135595
by BigJohnT
If it gets installed in /home/user/.local/bin Debian may not be able to find it. I know that Debian 9 does not include the path to .local/bin and you have to put a .xrcsession file in the home directory to fix that. See item 3 here
jethornton.github.io/7i96/install.html
JT
JT
02 Jun 2019 04:49 #135610
by MJPfin
Cant find it or even the nativecam folder anywhere. Need to figure this out later as now I'm out of time. I'll get to run my parts at the university machine.
I'll dig around more as I have catch up the time lost with current linux setup fiasco.
06 Jun 2019 15:20 #136063
by MJPfin
Not working, nothing gets downloaded for some reason. Week past and no change. Any step by step guide from start to finish?
Manual download and install? Complete working disk image, something.
I am done with trying. When nothing works.
Gone from good and working to complete useless after all changes and updates. Cnc works every single time, ncam is no where to be found.
It just don't exists anywhere. And it's not my network I can download anything I choose but nativecam.
Time to create page: 0.230 seconds
