Native CAM - How To Install?
- franstrein
21 Feb 2019 12:58 #126858
by franstrein
Replied by franstrein on topic Native CAM - How To Install?
Thanks.
Using the materials in github I was able to install. It is working now embedded within gmoccapy, first on my simulation in VMWare, and now also with my milling machine.
One other thing I stumbled upon, having embedded Nativecam active, is that when I load in gmoccapy an external gcode file, generated from my CAD system, it gives an error on the gcode, because somehow, it assumes that a Nativecam macro needs to be executed for my external gcode ??
I don't have the details now, can post those later, but did anyone run into that?
Frans
Frans
22 Feb 2019 13:59 #126908
by pl7i92
Replied by pl7i92 on topic Native CAM - How To Install?
there is a packet you can install
please tell what system you are on
2,7
Linux Debian Ubuntu Mint
so we can help more precise
and there is a irc live Help channel 24/7 Free
you can access this direct on the Machine
2,7
26 May 2019 13:57 #134998
by MJPfin
Replied by MJPfin on topic Native CAM - How To Install?
Hello, not so new to this linux stuff but I dont have smallest clue what goes wrong in installing.
Had machine up and running and it got fried and now I dont for the life of me get the new one installed properly.
Nativecam wont install, and Im about to give up.
Maybe im just stupid or something this is what I get:
Checking for curl...
Installing curl...
Reading package lists...
Building dependency tree...
Reading state information...
Package curl is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'curl' has no installation candidate
Running apt-get update... done.
Installing debian-archive-keyring which is needed for installing
apt-transport-https on many Debian systems.
Installing apt-transport-https... done.
Installing /etc/apt/sources.list.d/FernV_NativeCAM.list...ncam_debsetup.txt: line 115: curl: command not found
Unable to run:
curl packagecloud.io/install/repositories/Fer...wheezy&source=script
Double check your curl installation and try again.
Installing curl...
Unable to run:
28 May 2019 22:03 #135205
Replied by andypugh on topic Native CAM - How To Install?
31 May 2019 09:24 #135455
by MJPfin
Still the same error, like linux isn't finding updates or something.
Last time I had no trouble installing ncam following the instructions but on this new machine nothing gets done and I am starting to be desperate.
31 May 2019 10:54 #135456
by MJPfin
Installed curl manually and still no go, is there a new liveCD or something else how to for idiots to install, im out of ideas what to do, this was never a problem before and now everything is just error this and error that after liveCD install. Network works just fine, and update cant find a server for anything.
Starting to lean towards mach if this wont work, as I need the machine and Nativecam
"cnc@debian:~/linuxcnc/configs/my_LinuxCNC_machine/NativeCAM-master$ sudo bash ncam_debsetup.txt
[sudo] password for cnc:
Detected operating system as debian/wheezy.
Detected curl...
Installing /etc/apt/sources.list.d/FernV_NativeCAM.list...curl: error while loading shared libraries: libcurl.so.4: cannot open shared object file: No such file or directory
Unable to run:
cnc@debian:~/linuxcnc/configs/my_LinuxCNC_machine/NativeCAM-master$"
Detected curl...
Unable to run:
31 May 2019 11:06 #135458
Which LiveCD are you using?
There is one based on Stretch, if you are still on Wheezy.
31 May 2019 12:26 #135460
by MJPfin
Downloaded from the linuxcnc main page, weezy it looks to be. Where can I find this stretch?
31 May 2019 12:38 - 31 May 2019 12:39 #135462
www.linuxcnc.org/testing-stretch-rtpreempt/
I suggest booting in LiveCD mode and running the latency test first, it may be that preempt-rt isn't good enough on your hardware.
Last edit: 31 May 2019 12:39 by andypugh.
The following user(s) said Thank You: MJPfin
31 May 2019 13:12 #135464
by MJPfin
Latency was something around 4900 running couple of movie files and surfing on wheezy.
I will try that stretch next.
Time to create page: 0.342 seconds
