setting up for Parallel port Tutoral Part 3
09 Jul 2017 06:50 #95528
by JANNOVV
Replied by JANNOVV on topic setting up for Parallel port Tutoral Part 3
HI,
I'm trying a lathe on a parallel port.
Tried several times but no luck.
Please example hall and ini for lathe PP on a parallel port.
Thanks, Jan.
Thanks, Jan.
11 Jul 2017 14:05 #95660
Replied by andypugh on topic setting up for Parallel port Tutoral Part 3
Can you give a more specific description of what is not working?
02 Oct 2017 14:44 #99767
by czu774
Replied by czu774 on topic setting up for Parallel port Tutoral Part 3
I'm a beginner in Linux, but I find your tutorial very useful.
Thank you for the great job.
I have an cnc lathe retrofitted and I'm using my own Visual Basic programs and Mach3.
Now I want to tray the Pathpilot on parallel port.
I followed the instructions an I used the files from archive for the mill_pp example; everything was fine.
Do you have files for lathe_pp also?
Cezar.
Cezar.
12 Dec 2017 16:22 #103007
by emptyhb
Replied by emptyhb on topic setting up for Parallel port Tutoral Part 3
Hi, I've trouble with config limit in pathpilot using parallel port
How to edit hal file for pathpilot accept signal from parallel port - pin?
Thanks!
Thanks!
26 Jan 2018 14:09 #105039
by slipalong
Replied by slipalong on topic setting up for Parallel port Tutoral Part 3 - Migrating working LCNC config
Ive followed the tutorial and now have PP running ok, I have been using LCNC 2.7.11 for some months on a small mill (BF30 type).
Im moving from LCNC and Axis to PP mainly because well its ugly!
As I understand it I need to cut and paste lines from my working hal and ini files into the exampled kindly provided by Blacksheep.
Could anyone let me know what needs to be moved / copied please.
20 Feb 2018 23:18 #106259
by narrab
Replied by narrab on topic setting up for Parallel port Tutoral Part 3
Thank you for posting this PathPilot for Parallel Port Tutorial. I followed the instructions using v 1.9.3 Everything worked except I would get a jog error when setting the Estop. I read else where on this forum this was caused because the Machine OK was not set. So I by trial and error I now have this working by changing the Hal file. I have attached the Hal file that works for me to help others who follow this tutorial in the future.
24 Feb 2018 03:46 #106421
by narrab
I finally tried to hook up my stepper motors/ motor drivers to my BOB. While the Pathpilot is running and the x coordinates move with the Shuttlexpress, I am not getting any motor movement. By the Pathpilot by Tormach logo it says Frank SIM. Does this meant that I am in simulation mode? I have tried to view the signals on the Halscope and the Xstep does not show a signal when I move attempt to jog the x motor.
Any Ideas?
Any Ideas?
13 Feb 2019 18:13 #126367
by slipalong
Replied by slipalong on topic setting up for Parallel port Tutoral Part 3 with PathPilot version 2
Anyone managed to get PP2 working with a parallel port. Been trying for 2 day without success.
- davidimurray
- Thank you received: 5
02 Jul 2019 19:36 #138427
by davidimurray
Replied by davidimurray on topic setting up for Parallel port Tutoral Part 3
Hi
I just received my PPV2 USB stick a couple of days ago and today set about installing. Eventually it will be for my lathe, but in the first instance I am following the mill guidelines to allow me to confirm I can get a working setup.
I've been following the guide, but have come across a strange problem - the config_file.txt does not seem to exist/get created.
If I choose a config, I then get an error that the machine cannot be connected to. The PC then shuts down and when I restart, there is no config_file.txt
I've also tried creating an empty file, named config_file.txt that contains one line of ~/tmc/configs/tormach_mill/mill_pp.ini
However when I boot the PC it just boots into an empty screen with the backdrop showing and PP does not start. I've tried a couple of times now and same result every time/
Any help would be much appreciated
02 Jul 2019 23:48 - 02 Jul 2019 23:48 #138464
by smgvbest
Replied by smgvbest on topic setting up for Parallel port Tutoral Part 3
This guide is for V1 of PP, V2 there is several other posts on getting V2 up and running and the difference in the config files. just search for version 2 here in this forum and you'll find what you need.
You must enable EFI to boot and run the USB Drive correctly
Last edit: 02 Jul 2019 23:48 by smgvbest.
Moderators: cncbasher
Time to create page: 0.240 seconds
