Putting Plasma wiring into cable chain or not?
- Creative25
29 Mar 2021 08:44 #203995
by Creative25
Putting Plasma wiring into cable chain or not? was created by Creative25
I looking for dragchains.
The budget ones are all too small for the plug of the Plasma torch.
So my thought was this feed all the wires for sensors steppers etc through the cable chains and put the torch wiring on a boom above the table.
Advantage I can use budget cable chains.
Second advantage I can quickly remove the torch if I need to cut something by hand.
Question
Are there serious disadvantages to this setup?
What is recommended?
Question
- Thank you received: 5979
29 Mar 2021 13:18 #204023
If the torch cable is shielded, then it can be put together with the other cabling.
Replied by tommylight on topic Putting Plasma wiring into cable chain or not?
No, it is better this way as most plasma cutters do not come with a shielded torch cable, so having that near other sensitive wires causes a lot of issues.Question
- Creative25
29 Mar 2021 13:23 #204024
by Creative25
Replied by Creative25 on topic Putting Plasma wiring into cable chain or not?
Are there any samples of this setup on the forum?
29 Mar 2021 13:31 #204027
29 Mar 2021 17:05 #204072
Replied by rodw on topic Putting Plasma wiring into cable chain or not?
Most cable chains can be opened up to insert the cables. Many commercial machines run the torch with the other cabling. i have never had an issue but I have a machine torch so its not useful to be able to remove it.
- Creative25
04 Apr 2021 11:45 #204744
by Creative25
Thanks lots of info.
I am still reading.
I am still reading.
Moderators: cncbasher
Time to create page: 0.234 seconds
