(SOLVED!!!) Probe Basic - rotary axis jogging
05 Nov 2021 01:17 #225322
by Joco
Replied by Joco on topic Probe Basic - rotary axis jogging
It looks like things are not alligned as while the repo is correct, what is in the site packages is no. So I would suggets the following a terminal within where you have cd'd to the qtpyvcp directory.
python3 -m pip uninstall qtpyvcp
python3 -m pip install -e .
05 Nov 2021 01:49 #225324
by spumco
Replied by spumco on topic Probe Basic - rotary axis jogging
Ok, did that with no errors during install.
Did git pull again, terminal reported up to date.
Now I'm getting new (different) errors starting PB. I've pasted the whole terminal output in case there's something useful.
05 Nov 2021 02:13 #225330
by Joco
you might need to uninstall then install probe basic. Same pattern as you did for qtpyvcp.
However to avoid probe basic complaining about qtpyvco versions either comment out or delete this line:
github.com/kcjengr/probe_basic/blob/4bea...60e28f8/setup.py#L24
05 Nov 2021 02:40 - 05 Nov 2021 02:40 #225336
by spumco
Ok, I'll have a go at it. Before I do, can you review the steps below and let me know at what point I should edit the setup.py file?
cd /probe_basic
python3 -m pip uninstall probe_basic
cd /probe_basic
Last edit: 05 Nov 2021 02:40 by spumco.
05 Nov 2021 02:43 #225337
by Joco
before you redo the install.
05 Nov 2021 02:53 #225338
by spumco
Ugh.
PB shuts down after the last QT error pops up.
05 Nov 2021 03:10 - 05 Nov 2021 03:16 #225341
by Joco
Check one of the other qtpyvcp sims. e.g. mini or brender. If they run up then the issue might be relating to PB not the framework.
And also make sure your probe basic is on the python3 branch.
In fact if you are on that branch then you should not need to edit the setup.py file at all as the install_requires line is correctly set to the repo head and NOT a specific version. i.e. if your probe_basic setup file is reference a need for a >=3.x version of qtpyvcp then that is a red flag you are on the wrong PB branch.
Last edit: 05 Nov 2021 03:16 by Joco.
05 Nov 2021 03:19 #225343
by spumco
The other sims arent showing up in the LCNC launcher.
Since it won't launch, how do I check which branch of PB I'm on?
05 Nov 2021 03:20 #225344
by Joco
I think we have found a bug. Looking into it.
05 Nov 2021 03:32 #225346
by spumco
Time to create page: 0.098 seconds
