(SOLVED!!!) Probe Basic - rotary axis jogging
04 Nov 2021 02:24 #225189
by Joco
Replied by Joco on topic Probe Basic - rotary axis jogging
Here is the snippet out of the sim.qtpyvcp xyz-metric.ini file I am using.
Having the debug level set is useful as when linuxcnc is run from commandline you can see a lot of state changes. Including those relating to the sliders.
As you say, all in machine units/sec.
You might need to crack open designer and see what action text is in those A jog buttons. It is possible they are hard setting that 100 speed. Otherwise I will look later after work (in about 3-4hrs).
Cheers.
[DISPLAY]
DISPLAY = qtpyvcp --log-level=DEBUG
DEFAULT_ANGULAR_VELOCITY = 12.0000
MAX_ANGULAR_VELOCITY = 180.0000
MIN_ANGULAR_VELOCITY = 1.6667
Cheers.
04 Nov 2021 03:35 #225193
by spumco
Replied by spumco on topic Probe Basic - rotary axis jogging
Thanks for the debug tip, that helps.
Other than the text, the A-axis buttons are identical to the other axis buttons in QT designer.
Here's the debug terminal output when with the startup error message:
[qtpyvcp.app.launcher][CRITICAL] Unhandled exception in action_slider.py line 31 (launcher.py:37)
File "/home/mill/.local/lib/python3.9/site-packages/qtpyvcp/actions/__init__.py", line 61, in bindWidget
method = getattr(method, item)
AttributeError: type object 'jog' has no attribute 'angular_speed_percentage'
During handling of the above exception, another exception occurred:
File "/home/mill/.local/lib/python3.9/site-packages/qtpyvcp/widgets/input_widgets/action_slider.py", line 31, in actionName
bindWidget(self, action_name)
File "/home/mill/.local/lib/python3.9/site-packages/qtpyvcp/actions/__init__.py", line 66, in bindWidget
raise InvalidAction("Could not get action method: %s" % item)
qtpyvcp.actions.InvalidAction: Could not get action method: angular_speed_percentage
Poking around a bit...I'm beginning to get suspicious. The machine_actions.py (with the new angular percentage setting) in the above folders doesn't match the newer one in qtpyvcp/qtpyvcp/actions folder.
I really don't understand the qtpyvcp arcitecture, but could it be that when I start PB, qtpyvcp is calling up the 'old' machine_actions.py file - resulting in the error above and no angular jog response from the slider?
04 Nov 2021 04:07 #225195
by Joco
Can you please remind me how you installed qtpyvcp?
The steps I would expect are:
1. cloned the qtpyvcp rep using git to a folder somewhere under your home directory.
2. cd into this git repo directory
3. issued the command:
This will make an editable install. So that when you for a 'git pull' any updates take immediate effect.
If you did not do the above then you should uninstall qtpyvcp using pip then follow steps #2 and #3.
python3 -m pip install -e .
python3 -m pip uninstall qtpyvcp
04 Nov 2021 11:36 #225229
by spumco
James,
Here's how it was installed:
Looks very much like what you posted, with the exception of the specific version number Spi indicated in his instructions.
Yes, I cloned the git repository according to the installation instructions recently posted by Spi:
git clone git://github.com/kcjengr/qtpyvcp qtpyvcp
qtpyvcp master is already Python 3, no need to check out a branch
cd qtpyvcp
This is the part I haven't been able to figure out an elegant solution for
featherpad setup.py
Enable line numbers in: Options-> Line Numbers
Modify line #62 to read version='0.4.0',
python3 -m pip install --editable .
cp ~/qtpyvcp/scripts/.xsessionrc ~/
I'll have a go at 'git pull' in the /qtpyvcp directory first thing after I get back in town.
Thanks again
-Ralph
04 Nov 2021 19:14 #225251
by Joco
I suspect your pull will complain as you have changed a file. You will likely need to discarded that edit, then git pull. If you are using gitkraken discarding the change is easy. You will need to google how to do from cli.
That change was probably done so that the version of qtpyvcp on install was set at that version number. This will likely be due to PB wanting a version of qtpyvcp >= 3.x
i think that value is held wherever the install gets put inside .local. So discarding the change in the repo will have no impact unless you do a reinstall at some point.
04 Nov 2021 20:51 #225266
by spumco
I've no idea what 'gitkraken' or 'cli' are.
So should I uninstall and reinstall without the edit?
04 Nov 2021 21:56 #225280
by Joco
My suggestion would be to cd into the qtpyvcp directory enter this command:
This will dump any of your uncomitted changes. And now that you have PB and qtpyvcp already installed the version checks shouldn't be needed unless you do another install process. As I understand it using 'git pull' will not trigger these version checks again.
git reset --hard
git pull
04 Nov 2021 23:16 #225297
by spumco
Sorry to take up so much time with this, but I did the git reset --hard and git pull and there's no change. Same error message from qtpyvcp on startup.
05 Nov 2021 00:41 #225317
by Joco
could you post as an attachment your machine_actions.py file
You might need to add .txt to the end to make the forum happy
05 Nov 2021 00:48 #225318
by spumco
machine_actions01.txt is located in /qtpyvcp/qtpyvcp/actions/
machine_actions02.txt is located in /.local/lib/python3.9/site-packages/qtpyvcp/actions/
Time to create page: 0.208 seconds
