(SOLVED!!!) Probe Basic - rotary axis jogging
05 Nov 2021 03:35 #225347
by Joco
Replied by Joco on topic Probe Basic - rotary axis jogging
Nope - not you. We know what the issue is and its being dealt with. PB-py3 and the over all py3 conversion is still very new.
05 Nov 2021 03:46 #225348
by Joco
Fixed - git pull the PB repo.
05 Nov 2021 04:02 - 05 Nov 2021 04:15 #225349
by spumco
Replied by spumco on topic (SOLVED!!!) Probe Basic - rotary axis jogging
That's amazing. FIrst time PB has started with no errors in a couple days.
I think I still need to circle back and add the angular jog slider as it's missing from my screen now, and the linear jog slider has no effect.
But the A-axis is now moving at an appropriate speed based on my default settings in INI file.
You all rock.
EDIT - 5 minutes later... adding the slider sorted it out. The add-on slider follows the main jog slider, and the a-axis changes speed appropriately. Unreal.
You all rock.
Last edit: 05 Nov 2021 04:15 by spumco.
The following user(s) said Thank You: Joco
Time to create page: 0.148 seconds
