MESA 7I76 / 7i76e Model
19 Jun 2018 05:56 - 19 Jun 2018 06:06 #112565
by Askjerry
Replied by Askjerry on topic MESA 7I76D
I have been doing many CNC machines... all using a parallel port to date. I just got the 6i25 / 7i76D Plug and Go combo... and i'm attempting to figure it all out so that I can present a detailed instruction video set on you YouTube channel.
I came up with the attached spreadsheet of how I believe the pins should be connected... figuring that since it was in a spreadsheet format, I could add a column to incorporate the actual assignment such as "Mist Coolant" or "Vacuum Table", etc.
Anyway... I'm looking at the way the pins are laid out... and then I run the MESAFLASH utility and I get the following...
And I'm just trying to wrap my head around how this printout aligns with the pins that I have outlined in the spreadsheet.
It looks like PIN-1 of TB-2 should be a step generator output... but my spreadsheet and the drawing at the author's page show PIN-1 as GROUND.
RE: d2t1xqejof9utc.cloudfront.net/screenshot...674c0a5f46/large.png (From Author)
RE: Attached spreadsheet (From me.)
I'm trying to determine how to puzzle them together before I just start connecting stuff. I'm also measuring for voltage between PIN-1 and PIN-6 which should be GND and 5VDC respectively... but getting nothing out. So it looks like the default jumper settings are NOT the ones for having the 6i25 power the board.
Once I get it figured out... I'm sure I'll ramp up quickly and be able to teach it well... but any assistance is greatly appreciated.
Thanks,
Jerry
Configuration pin-out:
IO Connections for P3
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort StepGen 0 Dir/Table2 (Out)
14 1 IOPort StepGen 0 Step/Table1 (Out)
2 2 IOPort StepGen 1 Dir/Table2 (Out)
15 3 IOPort StepGen 1 Step/Table1 (Out)
3 4 IOPort StepGen 2 Dir/Table2 (Out)
16 5 IOPort StepGen 2 Step/Table1 (Out)
4 6 IOPort StepGen 3 Dir/Table2 (Out)
17 7 IOPort StepGen 3 Step/Table1 (Out)
5 8 IOPort StepGen 4 Dir/Table2 (Out)
6 9 IOPort StepGen 4 Step/Table1 (Out)
7 10 IOPort SSerial 0 TXData1 (Out)
8 11 IOPort SSerial 0 RXData1 (In)
9 12 IOPort SSerial 0 TXData2 (Out)
10 13 IOPort SSerial 0 RXData2 (In)
11 14 IOPort QCount 0 Quad-IDX (In)
12 15 IOPort QCount 0 Quad-B (In)
13 16 IOPort QCount 0 Quad-A (In)
IO Connections for P2
1 17 IOPort StepGen 5 Dir/Table2 (Out)
14 18 IOPort StepGen 5 Step/Table1 (Out)
2 19 IOPort StepGen 6 Dir/Table2 (Out)
15 20 IOPort StepGen 6 Step/Table1 (Out)
3 21 IOPort StepGen 7 Dir/Table2 (Out)
16 22 IOPort StepGen 7 Step/Table1 (Out)
4 23 IOPort StepGen 8 Dir/Table2 (Out)
17 24 IOPort StepGen 8 Step/Table1 (Out)
5 25 IOPort StepGen 9 Dir/Table2 (Out)
6 26 IOPort StepGen 9 Step/Table1 (Out)
7 27 IOPort SSerial 0 TXData3 (Out)
8 28 IOPort SSerial 0 RXData3 (In)
9 29 IOPort SSerial 0 TXData4 (Out)
10 30 IOPort SSerial 0 RXData4 (In)
11 31 IOPort QCount 1 Quad-IDX (In)
12 32 IOPort QCount 1 Quad-B (In)
13 33 IOPort QCount 1 Quad-A (In)
Thanks,
Jerry
Last edit: 19 Jun 2018 06:06 by Askjerry.
- robertspark
- Thank you received: 216
19 Jun 2018 06:11 #112566
by robertspark
Replied by robertspark on topic MESA 7I76 / 7i76e Model
The manual is here with the complete pinout
I think i got it right and followed this manual
www.mesanet.com/pdf/parallel/7i76eman.pdf
The following user(s) said Thank You: DanMN
26 Jun 2018 12:41 #112882
Replied by andypugh on topic MESA 7I76D
There are three numbers for each pin.
The IO number, which IO pin of the FPGA it is. (what the software calls it)
The Pin number (which pin it is on the DB25 connector)
The 7i76 number, which terminal it is on the 7i76.
For all practical purposes you only need to worry about the 7i76 numbers. But you can use Mesaflash to check that the DB25 numbers correspond to the DB25 numbers that the 7i76 expects. (basically a firmware compatibility check)
The 7i76 GPIO pins are serially accessed, they _all_ connect to pins 7 and 8 on the DB25 (IO 10 & 11 for P3, 27 & 28 for P2)
06 Jul 2018 15:13 - 06 Jul 2018 15:13 #113574
by Askjerry
Just a follow-up... I got it figured out, and for anyone having issues with not seeing the TB-4, TB-5, TB-6 issues...
you NEED an external power supply (24vcd typical).
RE: forum.linuxcnc.org/38-general-linuxcnc-q...76d-pncconfig-issues
Thanks for the assistance! I think I have enough to go with for now.
Jerry
Jerry
Last edit: 06 Jul 2018 15:13 by Askjerry. Reason: Cleaning
Time to create page: 0.172 seconds
