Manncorp ECM93 Pick and Place
- my1987toyota
- Topic Author
- Thank you received: 271
25 Jul 2020 22:49 #175806
by my1987toyota
Replied by my1987toyota on topic Manncorp ECM93 Pick and Place
WOW. So many great replies . As far as the Arduino, the reason I suggested it was because I am familiar
with it by experimentation. That said even Arduino makes me feel like an idiot a lot of the time.
I was warned Linuxcnc has a bit of a learning curve and it did not disappoint. LOL
- my1987toyota
- Topic Author
25 Jul 2020 23:00 - 25 Jul 2020 23:15 #175808
by my1987toyota
oh one other thing I had noticed in linuxcnc that is MUCH better than Mach3 is the pause command
in Linuxcnc when pause is issued the machine immediately comes to a halt.
in Mach3 when pause is issued the machine eventually comes to a halt when it feels like it.
well since using the auto feeders is dependent on accurate positioning ( everything is actually ) I had better get all the homing
switches hooked up. That will probably be what I work on this coming week.
I have taken a look at the suggested reading from the earlier posts by phillc54 and rodw .
I could have sworn I was looking at Arduino code.
Last edit: 25 Jul 2020 23:15 by my1987toyota.
- Thank you received: 5945
25 Jul 2020 23:35 #175820
But it does mane for some magnificent crashes!
Replied by tommylight on topic Manncorp ECM93 Pick and Place
I got bored of repeating that for a looooong while, so i stopped.oh one other thing I had noticed in linuxcnc that is MUCH better than Mach3 is the pause command
- my1987toyota
- Topic Author
26 Jul 2020 01:55 #175837
by my1987toyota
26 Jul 2020 09:30 #175876
A friend uses it on a Chinese router, his table is full of holes from the spindle ramming into it when setting the Z axis height, it goes pgdown>move>pgdown>move>pgdown>no move>pgdown>no move, release the button and turn to look at the machine >Z axis goes in the table. Witnessed that once, was hilarious.
- my1987toyota
- Topic Author
27 Jul 2020 00:51 - 27 Jul 2020 00:54 #175997
by my1987toyota
( tommylight wrote - release the button and turn to look at the machine >Z axis goes in the table. Witnessed that once, was hilarious. )
and that right there is why I wire in an E-stop button first.
Last edit: 27 Jul 2020 00:54 by my1987toyota.
27 Jul 2020 09:18 #176031
Yup, e-stop is the first thing that should be made functional on machines, then enable, and only then the rest of the stuff.
On my plasma cutters i do not have e-stop, never ever needed one !
- my1987toyota
- Topic Author
27 Jul 2020 22:16 #176152
by my1987toyota
Thank you tommylight for the help that made a big difference.
now I have to get the homing switches set up, they use a phototransistor sensor with a thin blade to brake the beam when
home is reached.
The max_velocity is way to low, that has to be raised by quite a bit for all axis.
Beware that each axis has two instances of them, and that has to be raised also in the "display" and "traj" sections in the ini file.
home is reached.
27 Jul 2020 23:31 #176166
From the sound of it, you can set that much faster, i would test it at 20 and 30.
That also needs to be set in the TRAJ section and for each axis and joint separately.
Let's see if it can fly off the table !
- my1987toyota
- Topic Author
28 Jul 2020 01:58 #176202
by my1987toyota
I will look it over tomorrow when I get to work.
It's current table is particle board so it'll probably become sawdust before the PnP could fly off of it.
Time to create page: 0.251 seconds
