Manncorp ECM93 Pick and Place
- my1987toyota
- Topic Author
- Thank you received: 280
07 Jul 2021 13:02 - 08 Jul 2021 21:45 #213966
by my1987toyota
Replied by my1987toyota on topic Manncorp ECM93 Pick and Place
Last edit: 08 Jul 2021 21:45 by my1987toyota. Reason: updating info
- my1987toyota
- Topic Author
08 Jul 2021 21:47 #214050
by my1987toyota
Well the 7i71 came in today to drive the feed advancers. Time to get to work . Let the head aches begin.
- my1987toyota
- Topic Author
13 Jul 2021 01:09 #214467
by my1987toyota
well that didn't take long . So Headache 1 the 7i71 starts up just fine with the PnP 6i25 and 7i76 over SSerial ( Blinking Green led ).
Unfortunately when I tried it on the 7i76e board at home all I got was a red led and a sneaky suspicion that the 2 boards
aren't talking to each other. The reason I say that is when I checked the debug report it says the pin I am using to turn on
a flood cooling relay ( connected to the 7i71 ) is missing . Sorry I don't have the debug report to post. I will be plugging it in
to the PnP controller when I get to work in the morning to make sure I didn't somehow damage the 7i71 board. ( unlikely )
- Thank you received: 5996
13 Jul 2021 01:34 #214471
Replied by tommylight on topic Manncorp ECM93 Pick and Place
Check both configs, the hal file has a
loadrt hm2_xxx followed by something like 0000xxxx
this is what i use for Mesa 7i92 with 7i77 and 7i74 attached to 7i70 and 7i71
loadrt hm2_eth board_ip="10.10.10.10" config=" num_encoders=6 num_pwmgens=0 num_stepgens=0 sserial_port_0=00000000 sserial_port_0=00010000 sserial_port_1=00200000"
notice the serial port stuff and the changing numbers, although not sure exactly what does what, it was quite a while back when i dealt with that.
The following user(s) said Thank You: my1987toyota
- my1987toyota
- Topic Author
13 Jul 2021 12:38 #214567
by my1987toyota
it no longer gives me the happy blinking green light when I launch any of the PnP's linuxcnc profile's. . I hope I didn't somehow corrupt
the 7i71's PIC.
Thanks tommylight I will look into that as soon as I can. I tested the card out this morning on the 6i26 / 7i76 PnP . UnfortunatelyCheck both configs, the hal file has a
the 7i71's PIC.
- my1987toyota
- Topic Author
14 Jul 2021 01:10 - 14 Jul 2021 01:11 #214661
by my1987toyota
tommylight is there a simple way to ping the 7i71 to tell if it's even being seen by the 7i76 or the 7i76e?
Last edit: 14 Jul 2021 01:11 by my1987toyota.
14 Jul 2021 01:54 #214665
Not that i know off, but pretty sure PCW would have something to say about it.
Still, as far as i know the SSERIAL is either working or it is not, when not usually a cable issue or hal loadrt line.
Also there should be an LED to show a valid connection, there is the "show hal configuration" to check if the card is there and see the pins and their name/numbering, and after all that is OK there are LED's for every output pin on the Mesa 7i71 near the output terminals.
Might want to post this also on the "driver boards" section of the forum as that is where PCW is at.
- my1987toyota
- Topic Author
14 Jul 2021 11:57 #214725
by my1987toyota
Thanks tommylight I will do that later this evening. ( my time )
14 Jul 2021 12:13 #214726
Replied by rodw on topic Manncorp ECM93 Pick and Place
is smart serial enabled in your hal file on the line for hostmot2?
Are you using the same known good cable?
Is the cable a 568-A or 568-B version?. The manual will only give a pinout for one of these. If you have the wrong kind, you need to work out hte changed pinout.
14 Jul 2021 13:55 #214738
Replied by PCW on topic Manncorp ECM93 Pick and Place
1. Do you have field power to the 7I71? (you should get a red fault light if powered)
2. How is the serial cable 7I71 connected to your system?
3. What is the hm2_pci or hm2_eth driver command line?
