I abandoned the idea to map pins from the Sherline controller box A axis, given Sherline does not provide a schematic, I have no oscilloscope, and simply do not want to either play a guessing game or smell molten chips. I added a 2nd parallel card, and configured stepconf to send PWM, STEP, and DIR through the second parallel port on pins 1, 14, and 16 respectively.
I have been working with Arturo Duncan at CNC4Pc and he recommended pin 14 for PWM and 1 for DIR, and if that eases setup I know how to make the changes. AT THIS TIME I have stepconf configured as describe in my first paragraph.
The 2nd aprallel port seems to be working. My reading from pin 1, the PWM, is 2.3v, and Arturo confirmed this is what I ought to see. I am making some progress. I am not however, reading voltage above .008v on the output terminals set by the C6 onboard potentiometer, nor am I seeing the two LEDs located behind the relays light up. 12v power is being applied to the board during this testing.
I believe the issue at this time is my HAL file setup, and therefore a software problem. I have tried a few customized HAL files; the result is a crash of LinuxCNC on startup. I don't know if resolving these customized HAL file problems will solve the voltage output issue; I decided I would start loading customized HAL files to test how LinuxCNC would respond on startup. Arturo assured me I would NOT get voltage readings in the 0-10v range without the correct Stepconf setup.
I am working in Linux 2.6.2
With patience, please, discard the earlier issues I poorly or erroneously described, as I think I have a good understanding of the C6's role in the chain of hardware I am wiring together. The earlier issues I wrote about were the result of not having parallel port pins physically wired into the C6.
Please if you have questions or input, all is welcome. I have pictures and configuration files I will gladly share.
